Rakray
Port forwarding to service using gluetun in docker container
hi,
I'm trying to get access to service on my homelab the problem is my ISP does not provide public IP addresses,
thats why i tried to setup port forwarding using airvpn.
I created new device and forwarded a port for this device.
Then i added gluetun to my docker compose as below:
services:
  gluetun:
    image: qmcgaw/gluetun:latest
    container_name: gluetun
    cap_add:
      - NET_ADMIN
    devices:
      - /dev/net/tun:/dev/net/tun
    ports:
      - 12345:1234 # manyfold web interface
      - 1234:1234
    volumes:
      - /docker/gluetun:/gluetun
    networks:
      - manyfold
    environment:
      - VPN_SERVICE_PROVIDER=airvpn
      - VPN_TYPE=wireguard
      - WIREGUARD_PUBLIC_KEY= KEY
      - WIREGUARD_PRIVATE_KEY= KEY
      - WIREGUARD_PRESHARED_KEY= KEY
      - WIREGUARD_ADDRESSES= IP_ADDRESS
      - SERVER_REGIONS= Europe
      #- VPN_PORT_FORWARDING= on
      # FREE_ONLY = on
      - FIREWALL_VPN_INPUT_PORTS=12345
      - HEALTH_VPN_DURATION_INITIAL=120s
      - DNS_ADDRESS=127.0.0.11
      #- CLI_ARGS=--run-script /gluetun/post_startup_script.sh
      #- DNS_KEEP_NAMESERVERS=on
    healthcheck:
      test: ping -c 1 www.google.com || exit 1
      interval: 60s
      timeout: 20s
      retries: 5
    restart: unless-stopped
  deunhealth:
    image: qmcgaw/deunhealth
    container_name: deunhealth
    network_mode: "none"
    environment:
      - LOG_LEVEL=info
      - HEALTH_SERVER_ADDRESS=127.0.0.1:9999
      - TZ=Poland/Warsaw
    restart: always
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
  app:
    image: ghcr.io/manyfold3d/manyfold:latest
    #ports:
      #- 1234:1234
    volumes:
      - /library:/library
    labels:
      - deunhealth.restart.on.unhealthy= "true"
    environment:
      DATABASE_ADAPTER: postgresql # mysql2 or sqlite3 are also supported
      DATABASE_HOST: postgres-server
      DATABASE_PORT: 2345 # only needed for non-standard ports
      DATABASE_NAME: manyfold # or the path to the database file if using sqlite3
      DATABASE_USER: USER
      DATABASE_PASSWORD: PASSWORD
      SECRET_KEY_BASE: KEY
      REDIS_URL: redis://redis-server:3456/1
      PUID: 1000
      PGID: 1000
      MULTIUSER: enabled
      MANYFOLD_BIND_ADDRESS: 0.0.0.0
      # For details of other optional environment variables, including features such
      # as multiuser mode, visit https://manyfold.app/sysadmin/configuration.html
	depends_on:
      postgres-server:
        condition: service_started
      redis-server:
      gluetun:
        condition: service_healthy
        restart: true
    #networks:
      #- manyfold
    network_mode: service:gluetun
    # Optional, but recommended for better security
    security_opt:
      - no-new-privileges:true
    cap_drop:
      - ALL
    cap_add:
      - CHOWN
      - DAC_OVERRIDE
      - SETUID
      - SETGID
    healthcheck:
        interval: 60s
        retries: 3
        start_period: 20s
        timeout: 10s
  postgres-server:
    image: postgres:15
    volumes:
      - db_data:/var/lib/postgresql/data
    environment:
      POSTGRES_USER: User
      POSTGRES_PASSWORD: PASSWORD
    networks:
      - manyfold
  redis-server:
    image: redis:7
    networks:
      - manyfold
volumes:
  db_data:
networks:
  manyfold:
    driver: bridge
the problem is i'm getting "Connection Refused(111)" while testing the tunnel in client Area
Additional info:
manyfold is hosted in as docker container inside unpriviliged LXC created in Proxmox
