Has anyone been able to install eddie on bazzite? i am attemping to do research and cannot find any data about using eddie while on bazzite os.
Bazzite is one of those nouveau riche immutable distributions where system directories are read-only. According to the docs, GUI apps are recommended to be installed via Flatpak, but since AppImage is an option and Eddie is distributed via AppImage, too, you can simply use that.
Alternatively, use dpkg/apt or rpm/yum via Distrobox.
