discov
ANSWERED Not able to connect using Eddie windows client
Please help with this issue. I am unable to connect to vpn servers using eddie windows client. Logs are attached. I have no problems in using airvpn config files with wireguard in the same system. I use windows 10. Thanks a lot
. 2025.05.30 08:35:20 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.19045.0, Mono/.Net: v4.0.30319
. 2025.05.30 08:35:20 - Command line arguments (1): path="home"
. 2025.05.30 08:35:21 - Skipped unknown option 'wireguard.interface.mtu'
. 2025.05.30 08:35:21 - Skipped unknown option 'windows.driver'
. 2025.05.30 08:35:21 - Reading options from C:\Users\kutta\AppData\Local\Eddie\default.profile
. 2025.05.30 08:35:24 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2025.05.30 08:35:24 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2025.05.30 08:35:24 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2025.05.30 08:35:25 - Ready
. 2025.05.30 08:35:26 - Collect information about AirVPN completed
I 2025.05.30 08:35:28 - Session starting.
I 2025.05.30 08:35:28 - Checking authorization ...
. 2025.05.30 08:35:30 - Added new network interface "Eddie", Wintun version 0.12
. 2025.05.30 08:35:30 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2025.05.30 08:35:30 - Connecting to Aljanah (Netherlands, Alblasserdam)
. 2025.05.30 08:35:30 - Routes, add 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)".
. 2025.05.30 08:35:31 - Routes, add 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)", already exists.
. 2025.05.30 08:35:31 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2025.05.30 08:35:31 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2025.05.30 08:35:31 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2025.05.30 08:35:31 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.05.30 08:35:31 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.05.30 08:35:31 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.05.30 08:35:31 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.05.30 08:35:31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.173:443
. 2025.05.30 08:35:31 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2025.05.30 08:35:31 - OpenVPN > UDP link local: (not bound)
. 2025.05.30 08:35:31 - OpenVPN > UDP link remote: [AF_INET]134.19.179.173:443
. 2025.05.30 08:35:31 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.173:443, sid=1800678f 271f5cf9
. 2025.05.30 08:35:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2025.05.30 08:35:31 - OpenVPN > VERIFY KU OK
. 2025.05.30 08:35:31 - OpenVPN > Validating certificate extended key usage
. 2025.05.30 08:35:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2025.05.30 08:35:31 - OpenVPN > VERIFY EKU OK
. 2025.05.30 08:35:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aljanah, emailAddress=info@airvpn.org
. 2025.05.30 08:35:31 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2025.05.30 08:35:31 - OpenVPN > [Aljanah] Peer Connection Initiated with [AF_INET]134.19.179.173:443
. 2025.05.30 08:35:32 - OpenVPN > SENT CONTROL [Aljanah]: 'PUSH_REQUEST' (status=1)
. 2025.05.30 08:35:32 - OpenVPN > AUTH: Received control message: AUTH_FAILED
W 2025.05.30 08:35:32 - Authorization failed. Look at the client area to discover the reason.
. 2025.05.30 08:35:32 - OpenVPN > SIGTERM received, sending exit notification to peer
! 2025.05.30 08:35:32 - Disconnecting
. 2025.05.30 08:35:32 - Sending soft termination signal
. 2025.05.30 08:35:35 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2025.05.30 08:35:35 - Routes, delete 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)".
. 2025.05.30 08:35:36 - Routes, delete 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)", not exists.
. 2025.05.30 08:35:36 - Connection terminated.
I 2025.05.30 08:35:39 - Checking authorization ...
. 2025.05.30 08:35:39 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2025.05.30 08:35:39 - Connecting to Aljanah (Netherlands, Alblasserdam)
. 2025.05.30 08:35:40 - Routes, add 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)".
. 2025.05.30 08:35:40 - Routes, add 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)", already exists.
. 2025.05.30 08:35:40 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2025.05.30 08:35:40 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2025.05.30 08:35:40 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2025.05.30 08:35:40 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.05.30 08:35:40 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.05.30 08:35:40 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.05.30 08:35:40 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.05.30 08:35:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.173:443
. 2025.05.30 08:35:40 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2025.05.30 08:35:40 - OpenVPN > UDP link local: (not bound)
. 2025.05.30 08:35:40 - OpenVPN > UDP link remote: [AF_INET]134.19.179.173:443
. 2025.05.30 08:35:40 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.173:443, sid=7325dfff ecad4904
. 2025.05.30 08:35:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2025.05.30 08:35:40 - OpenVPN > VERIFY KU OK
. 2025.05.30 08:35:40 - OpenVPN > Validating certificate extended key usage
. 2025.05.30 08:35:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2025.05.30 08:35:40 - OpenVPN > VERIFY EKU OK
. 2025.05.30 08:35:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aljanah, emailAddress=info@airvpn.org
. 2025.05.30 08:35:40 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2025.05.30 08:35:40 - OpenVPN > [Aljanah] Peer Connection Initiated with [AF_INET]134.19.179.173:443
. 2025.05.30 08:35:41 - OpenVPN > SENT CONTROL [Aljanah]: 'PUSH_REQUEST' (status=1)
. 2025.05.30 08:35:41 - OpenVPN > AUTH: Received control message: AUTH_FAILED
W 2025.05.30 08:35:41 - Authorization failed. Look at the client area to discover the reason.
. 2025.05.30 08:35:41 - OpenVPN > SIGTERM received, sending exit notification to peer
! 2025.05.30 08:35:41 - Disconnecting
. 2025.05.30 08:35:41 - Sending soft termination signal
. 2025.05.30 08:35:44 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2025.05.30 08:35:45 - Routes, delete 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)".
. 2025.05.30 08:35:45 - Routes, delete 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)", not exists.
. 2025.05.30 08:35:45 - Connection terminated.
I 2025.05.30 08:35:48 - Checking authorization ...
. 2025.05.30 08:35:49 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2025.05.30 08:35:49 - Connecting to Aljanah (Netherlands, Alblasserdam)
. 2025.05.30 08:35:49 - Routes, add 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)".
. 2025.05.30 08:35:50 - Routes, add 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)", already exists.
. 2025.05.30 08:35:50 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2025.05.30 08:35:50 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2025.05.30 08:35:50 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2025.05.30 08:35:50 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.05.30 08:35:50 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.05.30 08:35:50 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.05.30 08:35:50 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.05.30 08:35:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.173:443
. 2025.05.30 08:35:50 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2025.05.30 08:35:50 - OpenVPN > UDP link local: (not bound)
. 2025.05.30 08:35:50 - OpenVPN > UDP link remote: [AF_INET]134.19.179.173:443
. 2025.05.30 08:35:50 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.173:443, sid=bf36845c 6b01d2dc
. 2025.05.30 08:35:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2025.05.30 08:35:50 - OpenVPN > VERIFY KU OK
. 2025.05.30 08:35:50 - OpenVPN > Validating certificate extended key usage
. 2025.05.30 08:35:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2025.05.30 08:35:50 - OpenVPN > VERIFY EKU OK
. 2025.05.30 08:35:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aljanah, emailAddress=info@airvpn.org
. 2025.05.30 08:35:50 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2025.05.30 08:35:50 - OpenVPN > [Aljanah] Peer Connection Initiated with [AF_INET]134.19.179.173:443
. 2025.05.30 08:35:51 - OpenVPN > SENT CONTROL [Aljanah]: 'PUSH_REQUEST' (status=1)
. 2025.05.30 08:35:51 - OpenVPN > AUTH: Received control message: AUTH_FAILED
W 2025.05.30 08:35:51 - Authorization failed. Look at the client area to discover the reason.
. 2025.05.30 08:35:51 - OpenVPN > SIGTERM received, sending exit notification to peer
! 2025.05.30 08:35:51 - Disconnecting
. 2025.05.30 08:35:51 - Sending soft termination signal
. 2025.05.30 08:35:54 - OpenVPN > SIGTERM[hard,] received, process exiting
. 2025.05.30 08:35:55 - Routes, delete 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)".
. 2025.05.30 08:35:55 - Routes, delete 134.19.179.173/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)", not exists.
. 2025.05.30 08:35:55 - Connection terminated.
RESOLVED. I logged out from the eddie and logged in as I renewed my private keys. Now everything works. Thanks to the suggestion provided by the staff in another thread.
