Hello i would like to change my password because there's a device i dont recognise when i go into account settings recently used devices. When i click to change my password it says if i change my password it will log me out on all other devices. When i changed my password it didn't log me out on the other devices that i tried with at home. I connected without putting in my new password. Would it be because when i installed Eddie before i clicked the square box remember password ?  I have the same problem with wireguard also i can still connect. If thats the case the device i dont recognise can still connect. Any suggestions ?
Thanks in advance.
3 hours ago, itsmefloraluca said:
Any suggestions ?
Go to https://airvpn.org/devices/ and re-create the device.
Click on Details, then Delete. Click Add a new device.
After that old configs (Eddie, manually generated, etc.) should stop working. In Eddie you'll have to logout and login again (which will download the newly generated device key).
