FunThomas
eddie problems maybe with DNS
i have a problem with eddie client and it shows connected and some connections making transfers but no more website is reachable
even in the eddie log i see:
. 2025.05.09 12:45:39 - Collect information about AirVPN ..., 1° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 12:45:39 - Collect information about AirVPN ..., 2° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 12:45:39 - Collect information about AirVPN ..., 3° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 12:45:39 - Collect information about AirVPN ..., 4° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 12:45:39 - Collect information about AirVPN ..., 5° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 12:45:39 - Cannot retrieve information about AirVPN: Fetch url error:Couldn't connect to server
Win10x64, avast antivir without firewall,
firefox and opera gx are not able to connect to webpages
any help would be appreciated
best regards,
Thomas
the whole scenario happens often 😞 and i don't know why
. 2025.05.09 18:25:35 - Collect information about AirVPN ..., 1° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 18:25:35 - Collect information about AirVPN completed
. 2025.05.09 18:55:42 - Collect information about AirVPN ..., 1° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 18:55:42 - Collect information about AirVPN ..., 2° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 18:55:42 - Collect information about AirVPN ..., 3° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 18:55:42 - Collect information about AirVPN ..., 4° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 18:55:42 - Collect information about AirVPN ..., 5° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 18:55:42 - Cannot retrieve information about AirVPN: Fetch url error:Couldn't connect to server
. 2025.05.09 19:25:48 - Collect information about AirVPN ..., 1° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:25:48 - Collect information about AirVPN ..., 2° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:25:48 - Collect information about AirVPN ..., 3° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:25:48 - Collect information about AirVPN ..., 4° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:25:48 - Collect information about AirVPN ..., 5° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:25:48 - Cannot retrieve information about AirVPN: Fetch url error:Couldn't connect to server
. 2025.05.09 19:55:55 - Collect information about AirVPN ..., 1° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:55:55 - Collect information about AirVPN ..., 2° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:55:55 - Collect information about AirVPN ..., 3° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:55:55 - Collect information about AirVPN ..., 4° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:55:55 - Collect information about AirVPN ..., 5° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 19:55:55 - Cannot retrieve information about AirVPN: Fetch url error:Couldn't connect to server
. 2025.05.09 20:26:01 - Collect information about AirVPN ..., 1° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 20:26:01 - Collect information about AirVPN ..., 2° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 20:26:01 - Collect information about AirVPN ..., 3° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 20:26:01 - Collect information about AirVPN ..., 4° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 20:26:02 - Collect information about AirVPN ..., 5° try failed (Fetch url error:Couldn't connect to server)
. 2025.05.09 20:26:02 - Cannot retrieve information about AirVPN: Fetch url error:Couldn't connect to server
connection is established over Wireguard UDP Port 1637
changed the settings for DNS -> Windows only -> to  Force all network interfaces for DNS enabled but nothing changed
The connection is still shown as ok but in the log are the errors above but no reconnect
and even if under advanced settings -> check if tunnel works is enabled the error is not recognised 😞
and in this situation every LAN connection is blocked too even if under Network lock -> allow LAN/private is enabled
cfosssped deinstalled but changed nothing
if someone could help me or tell me what information is further needed to analyse the problem i would be happy
best regards,
Thomas
