smokey420
Certain destination websites bypass vpn
I have a wnr3500l v2 router running Tomato Firmware 1.28.0000 MIPSR2-102 K26 USB AIO. I have both vpn clients set up using lfjeff script found here (http://www.linksysinfo.org/index.php?threads/any-way-to-bypass-vpn-selectively.33468/, post #43) and edited using ?PsychoWolf script found here (https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=5540&Itemid=142). What I would like to do know is have certain destination websites bypass the vpn and go thru the wan gateway. For example if someone typed in google.com it would skip the vpn and go thru with my ISP address. Is this possible and if so how do I do it? I have 5 computers connected to my router and everything is routed where I want it to thru the two vpn clients.Thank you for any help.
