repok21 0 Posted ... (edited) I currently have a AirVPN VPN interface on my Opnsense firewall with my torrent client device correctly routing through the virtual VPN interface. Everything is working except port forwarding. When I ran the OpenVPN client on the torrent machine itself using the OpenVPN client, the port forwarding works. When I route my torrent machine through Opnsense and the virtual gateway (with proper port forwarding rules) then it does not work. Nothing is being blocked at the firewall and when I run sudo tcpdump -i enp2s0 port 62524 -n it shows connections between my torrent machine and external public IPs on that designated listening port so Im a bit confused. Something isnt working because upload speeds are extremely slow and the port forward test fails on the airvpn page. Here is output, am i going crazy? tangodown@seedbox:~$ sudo tcpdump -i enp2s0 port 62524 -n tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on enp2s0, link-type EN10MB (Ethernet), capture size 262144 bytes 00:00:51.814560 IP [REDACTED].25027 > 192.168.1.240.62524: UDP, length 69 00:00:51.814725 IP 192.168.1.240.62524 > [REDACTED].50018: UDP, length 97 00:00:51.948615 IP [REDACTED].50018 > 192.168.1.240.62524: UDP, length 69 00:00:51.948781 IP 192.168.1.240.62524 > [REDACTED].42549: UDP, length 97 00:00:52.071109 IP [REDACTED].42549 > 192.168.1.240.62524: UDP, length 69 00:00:52.071274 IP 192.168.1.240.62524 > [REDACTED].60954: UDP, length 97 00:00:52.196490 IP [REDACTED].60954 > 192.168.1.240.62524: UDP, length 69 00:00:52.199549 IP 192.168.1.240.62524 > [REDACTED].16950: UDP, length 58 00:00:52.199844 IP 192.168.1.240.62524 > [REDACTED].35014: UDP, length 58 00:00:52.202082 IP 192.168.1.240.62524 > [REDACTED].6060: UDP, length 97 00:00:52.238391 IP [REDACTED].6060 > 192.168.1.240.62524: UDP, length 88 00:00:52.300783 IP [REDACTED].16950 > 192.168.1.240.62524: UDP, length 80 00:00:52.586435 IP [REDACTED].6881 > 192.168.1.240.62524: UDP, length 78 00:00:52.586617 IP 192.168.1.240.62524 > [REDACTED].20605: UDP, length 97 00:00:53.201901 IP 192.168.1.240.42007 > [REDACTED].62524: Flags , seq 3101204821, win 7300, options [mss 1460,sackOK,TS val 1168147747 ecr 0,nop,wscale 0], length 0 00:00:53.450746 IP 192.168.1.240.44945 > [REDACTED].62524: Flags , seq 180890020, win 7300, options [mss 1460,sackOK,TS val 1168147996 ecr 0,nop,wscale 0], length 0 00:00:53.573553 IP 192.168.1.240.62524 > [REDACTED].57003: UDP, length 58 00:00:53.666011 IP [REDACTED].57003 > 192.168.1.240.62524: UDP, length 80 00:00:54.200593 IP 192.168.1.240.62524 > [REDACTED].64043: UDP, length 58 00:00:54.218730 IP 192.168.1.240.42007 > [REDACTED].62524: Flags , seq 3101204821, win 7300, options [mss 1460,sackOK,TS val 1168148764 ecr 0,nop,wscale 0], length 0 00:00:54.328205 IP [REDACTED].64043 > 192.168.1.240.62524: UDP, length 80 00:00:54.635322 IP 192.168.1.240.62524 > [REDACTED].51370: UDP, length 58 00:00:54.710765 IP [REDACTED].51370 > 192.168.1.240.62524: UDP, length 80 00:00:55.200119 IP 192.168.1.240.62524 > [REDACTED].30036: UDP, length 58 EDIT: Fixed the issue. under the Firewall -> Rules for both the floating and the VPN interface rules, i had to set the 'reply-to' to the AirVPN gateway Edited ... by repok21 Share this post Link to post
Tech Jedi Alex 1525 Posted ... 11 hours ago, repok21 said: EDIT: Fixed the issue. under the Firewall -> Rules for both the floating and the VPN interface rules, i had to set the 'reply-to' to the AirVPN gateway Fix. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
