Ayatsuji 1 Posted ... Hello everyone, thx for your time reading this. I'm using qbittorrent, it's bind to airvpn, I have port forward on website and got the same port on qbittorrent. I unchecked the (use UPnP/NAT...etc). Yet, I cannot seed. I see peers, I've tried multiple torrents.. it's just not seeding. I looked over the reddit, and searched in the community but cannot find a valid solution. ps: I have Malwarebytes and Adguard (I've added both Eddie and qbittorrent to whitelist on malwarebytes) Also, qbittorrent is allowed in windows firewall for both public and private network. thx again in advance. Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... 15 hours ago, Ayatsuji said: it's bind to airvpn I'd like to know the exact setting here, because qB does not bind to apps; it binds to interfaces and/or addresses. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Ayatsuji 1 Posted ... 4 hours ago, OpenSourcerer said: I'd like to know the exact setting here, because qB does not bind to apps; it binds to interfaces and/or addresses. You are right. it's bind to Eddie's interface. Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... The screenshot does not show the referenced setting, which is under Advanced. But even in this little screenshot there's cause for concern. a) Disable uTP. b) Set all those limits, don't disable them. qB'll eat up all your network resources otherwise. Then: Is port 63042 the port you got automatically forwarded in the client area? Is said port in pool :1? Did you try checking the connection to the port in the client area? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Ayatsuji 1 Posted ... 21 minutes ago, OpenSourcerer said: The screenshot does not show the referenced setting, which is under Advanced. But even in this little screenshot there's cause for concern. a) Disable uTP. b) Set all those limits, don't disable them. qB'll eat up all your network resources otherwise. Then: Is port 63042 the port you got automatically forwarded in the client area? Is said port in pool :1? Did you try checking the connection to the port in the client area? a) I set the peer connection protocol to (TCP) only as you mentioned. b) I dont mind.. I will usually seed when not utilizing the pc, and I set them off to see if it will work or not. 3) Yes it is the port number and I did (test port) in the client area and it says (open) on the IPv4 but the others (IPv6) says timeout. what I learned from searching is: when forward a port, you put check mark on (p2p) and create a port, then you put it in the qbit. Quote Share this post Link to post
bluesjunior 46 Posted ... Check out the qBittorrent settings in the link. It has been valid for a few years now and works well. https://www.techjunkie.com/best-qbittorrent-settings/ Quote Share this post Link to post
Ayatsuji 1 Posted ... I dont know what happened, but after two days the upload starts working. Please note that I followed bluesjunior's recommendation (I had everything exactly as mentioned in the website) and followed the recommendations of OpenSourcerer as well. 1 bluesjunior reacted to this Quote Share this post Link to post
