pHxaq 3 Posted ... Hello, it is known that if we use Eddie and configure a setting like "reconnect to last server on start", the server selected is not saved unless we disconnect and close eddie. I would like to suggest that the chosen server gets automatically saved as the "last server" right after we connect to it. Current steps to save a desired server to reconnect on start up: Open Eddie and log in Go to "Settings" Check the option "Reconnect to last server at start" Save Go to the "Servers" menu Select a server and connect to it Go to the "Overview" menu Disconnect Exit Eddie Restart the system Open Eddie Verify that the server selected in Step 6 is being used for the current connection Desired steps: Open Eddie and log in Go to "Settings" Check the option "Reconnect to last server at start" Save Go to the "Servers" menu Select a server and connect to it Restart the system Open Eddie Verify that the server selected in Step 6 is being used for the current connection Thanks. Quote Share this post Link to post
