BlackSpart 0 Posted ... (edited) Hello, I use ArchLinux, and I try to build and install the eddie-ui-git 2.24.5 package from the AUR. I use the aurutils tools for the build process, and the build process is executed in a clean chroot (see logs below). When I try to lauch the built and installed package, I have the error message : "The file /usr/lib/mscorlib.dll is an invalid CIL image". I looked at the following thread, and it seems to be a mono dependency issue ? But I think I am using the latest version of each dependency. Thank you in advance for your support. The build logs : :: Synchronizing package databases... core downloading... extra downloading... multilib downloading... aur downloading... :: Starting full system upgrade... there is nothing to do ==> Making package: eddie-ui-git 2.24.5-1 (Fri Dec 13 14:24:16 2024) ==> Retrieving sources... -> Updating Eddie git repo... ==> Validating source files with sha1sums... Eddie ... Skipped ==> Making package: eddie-ui-git 2.24.5-1 (Fri Dec 13 14:24:19 2024) ==> Checking runtime dependencies... ==> Installing missing dependencies... resolving dependencies... looking for conflicting packages... warning: dependency cycle detected: warning: harfbuzz will be installed before its freetype2 dependency warning: dependency cycle detected: warning: mesa will be installed before its libglvnd dependency Package (97) New Version Net Change extra/adobe-source-code-pro-fonts 2.042u+1.062i+1.026vf-2 1.86 MiB extra/adwaita-cursors 47.0-1 10.02 MiB extra/adwaita-icon-theme 47.0-1 1.17 MiB extra/adwaita-icon-theme-legacy 46.2-3 2.23 MiB extra/at-spi2-core 2.54.0-2 3.92 MiB extra/avahi 1:0.8+r194+g3f79789-2 1.88 MiB extra/ayatana-ido 0.10.4-1 0.28 MiB extra/cairo 1.18.2-2 1.57 MiB extra/cantarell-fonts 1:0.303.1-2 0.19 MiB extra/dav1d 1.5.0-1 1.74 MiB extra/dconf 0.40.0-3 0.45 MiB extra/default-cursors 3-1 0.00 MiB extra/desktop-file-utils 0.28-1 0.18 MiB extra/duktape 2.7.0-7 0.78 MiB extra/fontconfig 2:2.15.0-2 1.10 MiB extra/freetype2 2.13.3-1 1.62 MiB extra/fribidi 1.0.16-1 0.24 MiB extra/gdk-pixbuf2 2.42.12-2 2.99 MiB extra/giflib 5.2.2-1 0.27 MiB extra/glib-networking 1:2.80.0-3 0.62 MiB extra/graphite 1:1.3.14-4 0.20 MiB extra/gsettings-desktop-schemas 47.1-1 5.34 MiB extra/gsettings-system-schemas 47.1-1 0.01 MiB extra/gtk-update-icon-cache 1:4.16.7-1 0.04 MiB extra/gtk3 1:3.24.43-4 52.14 MiB extra/harfbuzz 10.1.0-1 4.11 MiB extra/hicolor-icon-theme 0.18-1 0.05 MiB extra/iso-codes 4.17.0-1 20.25 MiB extra/jbigkit 2.1-8 0.16 MiB extra/json-glib 1.10.6-1 1.01 MiB extra/lcms2 2.16-1 0.67 MiB extra/libayatana-indicator 0.9.4-1 0.11 MiB extra/libcloudproviders 0.3.6-1 0.48 MiB extra/libcolord 1.4.7-2 1.24 MiB extra/libcups 2:2.4.11-1 0.77 MiB extra/libdaemon 0.14-6 0.06 MiB extra/libdatrie 0.2.13-4 0.48 MiB extra/libdbusmenu-glib 16.04.0.r498-2 0.68 MiB extra/libdbusmenu-gtk3 16.04.0.r498-2 0.23 MiB extra/libdrm 2.4.124-1 1.23 MiB core/libedit 20240517_3.1-1 0.27 MiB extra/libepoxy 1.5.10-3 2.64 MiB extra/libexif 0.6.24-3 2.64 MiB extra/libgdiplus 6.1-2 0.52 MiB extra/libglvnd 1.7.0-1 3.70 MiB extra/libjpeg-turbo 3.0.4-1 2.31 MiB core/libnl 3.11.0-1 2.08 MiB extra/libpciaccess 0.18.1-2 0.06 MiB extra/libpng 1.6.44-1 0.57 MiB extra/libproxy 0.5.9-1 0.10 MiB extra/librsvg 2:2.59.2-1 11.29 MiB extra/libsoup3 3.6.1-1 1.94 MiB extra/libstemmer 2.2.0-2 0.79 MiB extra/libthai 0.1.29-3 1.22 MiB extra/libtiff 4.7.0-1 1.78 MiB extra/libx11 1.8.10-1 9.78 MiB extra/libxau 1.0.11-3 0.02 MiB extra/libxcb 1.17.0-1 3.87 MiB extra/libxcomposite 0.4.6-2 0.02 MiB extra/libxcursor 1.2.3-1 0.07 MiB extra/libxdamage 1.1.6-2 0.02 MiB extra/libxdmcp 1.1.5-1 0.13 MiB extra/libxext 1.3.6-1 0.30 MiB extra/libxfixes 6.0.1-2 0.04 MiB extra/libxft 2.3.8-2 0.13 MiB extra/libxi 1.8.2-1 0.48 MiB extra/libxinerama 1.1.5-2 0.02 MiB extra/libxkbcommon 1.7.0-2 0.79 MiB extra/libxrandr 1.5.4-1 0.07 MiB extra/libxrender 0.9.11-2 0.09 MiB extra/libxshmfence 1.3.2-2 0.02 MiB extra/libxtst 1.2.5-1 0.11 MiB extra/libxxf86vm 1.1.5-2 0.03 MiB extra/llvm-libs 18.1.8-4 128.31 MiB extra/lm_sensors 1:3.6.0.r41.g31d1f125-3 0.46 MiB core/lzo 2.10-5 0.38 MiB extra/mesa 1:24.3.1-3 96.81 MiB core/mpdecimal 4.0.0-2 0.32 MiB core/nspr 4.36-1 0.71 MiB core/nss 3.107-1 5.10 MiB extra/pango 1:1.54.0-1 2.29 MiB extra/pixman 0.44.2-1 0.70 MiB extra/pkcs11-helper 1.30.0-1 0.31 MiB core/python 3.12.7-1 70.07 MiB extra/shared-mime-info 2.4-1 4.55 MiB extra/spirv-tools 2024.4.rc1-1 6.67 MiB extra/tinysparql 3.8.1-1 3.80 MiB extra/wayland 1.23.1-1 0.80 MiB extra/xcb-proto 1.17.0-2 1.02 MiB extra/xkeyboard-config 2.43-1 6.55 MiB extra/xorg-xprop 1.2.8-1 0.05 MiB extra/xorgproto 2024.1-2 1.46 MiB extra/libayatana-appindicator 0.5.93-1 0.32 MiB extra/libnotify 0.8.3-1 0.14 MiB extra/mono 6.12.0.206-1 252.29 MiB extra/openvpn 2.6.12-1 1.69 MiB extra/polkit 125-1 1.88 MiB Total Installed Size: 756.95 MiB :: Proceed with installation? [Y/n] checking keyring... checking package integrity... loading package files... checking for file conflicts... :: Processing package changes... installing libpng... installing graphite... Optional dependencies for graphite graphite-docs: Documentation installing harfbuzz... Optional dependencies for harfbuzz harfbuzz-utils: utilities installing freetype2... installing fontconfig... Creating fontconfig configuration... Rebuilding fontconfig cache... installing xcb-proto... installing xorgproto... installing libxdmcp... installing libxau... installing libxcb... installing libx11... installing libxext... installing libxrender... installing lzo... installing pixman... installing cairo... installing libexif... installing libjpeg-turbo... Optional dependencies for libjpeg-turbo java-runtime>11: for TurboJPEG Java wrapper installing jbigkit... installing libtiff... Optional dependencies for libtiff freeglut: for using tiffgt installing fribidi... installing libdatrie... installing libthai... installing libxft... installing pango... installing giflib... installing libgdiplus... installing mpdecimal... installing python... Optional dependencies for python python-setuptools: for building Python packages using tooling that is usually bundled with Python python-pip: for installing Python packages using tooling that is usually bundled with Python python-pipx: for installing Python software not packaged on Arch Linux sqlite: for a default database integration [installed] xz: for lzma [installed] tk: for tkinter installing mono... Mono Certificate Store Sync - version 6.12.0.0 Populate Mono certificate store from a concatenated list of certificates. Copyright 2002, 2003 Motus Technologies. Copyright 2004-2008 Novell. BSD licensed. Importing into legacy system store: I already trust 0, your new list has 149 Certificate added: CN=ACCVRAIZ1, OU=PKIACCV, O=ACCV, C=ES Certificate added: C=ES, O=FNMT-RCM, OU=AC RAIZ FNMT-RCM Certificate added: C=ES, O=FNMT-RCM, OU=Ceres, OID.2.5.4.97=VATES-Q2826004J, CN=AC RAIZ FNMT-RCM SERVIDORES SEGUROS Certificate added: SERIALNUMBER=G63287510, C=ES, O=ANF Autoridad de Certificacion, OU=ANF CA Raiz, CN=ANF Secure Server Root CA Certificate added: C=IT, L=Milan, O=Actalis S.p.A./03358520967, CN=Actalis Authentication Root CA Certificate added: C=US, O=AffirmTrust, CN=AffirmTrust Commercial Certificate added: C=US, O=AffirmTrust, CN=AffirmTrust Networking Certificate added: C=US, O=AffirmTrust, CN=AffirmTrust Premium Certificate added: C=US, O=AffirmTrust, CN=AffirmTrust Premium ECC Certificate added: C=US, O=Amazon, CN=Amazon Root CA 1 Certificate added: C=US, O=Amazon, CN=Amazon Root CA 2 Certificate added: C=US, O=Amazon, CN=Amazon Root CA 3 Certificate added: C=US, O=Amazon, CN=Amazon Root CA 4 Certificate added: CN=Atos TrustedRoot 2011, O=Atos, C=DE Certificate added: CN=Atos TrustedRoot Root CA ECC TLS 2021, O=Atos, C=DE Certificate added: CN=Atos TrustedRoot Root CA RSA TLS 2021, O=Atos, C=DE Certificate added: C=ES, CN=Autoridad de Certificacion Firmaprofesional CIF A62634068 Certificate added: C=CN, O=BEIJING CERTIFICATE AUTHORITY, CN=BJCA Global Root CA1 Certificate added: C=CN, O=BEIJING CERTIFICATE AUTHORITY, CN=BJCA Global Root CA2 Certificate added: C=IE, O=Baltimore, OU=CyberTrust, CN=Baltimore CyberTrust Root Certificate added: C=NO, O=Buypass AS-983163327, CN=Buypass Class 2 Root CA Certificate added: C=NO, O=Buypass AS-983163327, CN=Buypass Class 3 Root CA Certificate added: C=SK, L=Bratislava, O=Disig a.s., CN=CA Disig Root R2 Certificate added: C=CN, O=China Financial Certification Authority, CN=CFCA EV ROOT Certificate added: C=GB, S=Greater Manchester, L=Salford, O=COMODO CA Limited, CN=COMODO Certification Authority Certificate added: C=GB, S=Greater Manchester, L=Salford, O=COMODO CA Limited, CN=COMODO ECC Certification Authority Certificate added: C=GB, S=Greater Manchester, L=Salford, O=COMODO CA Limited, CN=COMODO RSA Certification Authority Certificate added: C=US, O=Certainly, CN=Certainly Root E1 Certificate added: C=US, O=Certainly, CN=Certainly Root R1 Certificate added: C=FR, O=Dhimyotis, CN=Certigna Certificate added: C=FR, O=Dhimyotis, OU=0002 48146308100036, CN=Certigna Root CA Certificate added: C=PL, O=Asseco Data Systems S.A., OU=Certum Certification Authority, CN=Certum EC-384 CA Certificate added: C=PL, O=Unizeto Technologies S.A., OU=Certum Certification Authority, CN=Certum Trusted Network CA Certificate added: C=PL, O=Unizeto Technologies S.A., OU=Certum Certification Authority, CN=Certum Trusted Network CA 2 Certificate added: C=PL, O=Asseco Data Systems S.A., OU=Certum Certification Authority, CN=Certum Trusted Root CA Certificate added: C=US, O=CommScope, CN=CommScope Public Trust ECC Root-01 Certificate added: C=US, O=CommScope, CN=CommScope Public Trust ECC Root-02 Certificate added: C=US, O=CommScope, CN=CommScope Public Trust RSA Root-01 Certificate added: C=US, O=CommScope, CN=CommScope Public Trust RSA Root-02 Certificate added: C=GB, S=Greater Manchester, L=Salford, O=Comodo CA Limited, CN=AAA Certificate Services Certificate added: C=DE, O=D-Trust GmbH, CN=D-TRUST BR Root CA 1 2020 Certificate added: C=DE, O=D-Trust GmbH, CN=D-TRUST EV Root CA 1 2020 Certificate added: C=DE, O=D-Trust GmbH, CN=D-TRUST Root Class 3 CA 2 2009 Certificate added: C=DE, O=D-Trust GmbH, CN=D-TRUST Root Class 3 CA 2 EV 2009 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Assured ID Root CA Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Assured ID Root G2 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Assured ID Root G3 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Global Root CA Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Global Root G2 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Global Root G3 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert High Assurance EV Root CA Certificate added: C=US, O="DigiCert, Inc.", CN=DigiCert TLS ECC P384 Root G5 Certificate added: C=US, O="DigiCert, Inc.", CN=DigiCert TLS RSA4096 Root G5 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Trusted Root G4 Certificate added: O=Entrust.net, OU=www.entrust.net/CPS_2048 incorp. by ref. (limits liab.), OU=(c) 1999 Entrust.net Limited, CN=Entrust.net Certification Authority (2048) Certificate added: C=US, O="Entrust, Inc.", OU=www.entrust.net/CPS is incorporated by reference, OU="(c) 2006 Entrust, Inc.", CN=Entrust Root Certification Authority Certificate added: C=US, O="Entrust, Inc.", OU=See www.entrust.net/legal-terms, OU="(c) 2012 Entrust, Inc. - for authorized use only", CN=Entrust Root Certification Authority - EC1 Certificate added: C=US, O="Entrust, Inc.", OU=See www.entrust.net/legal-terms, OU="(c) 2009 Entrust, Inc. - for authorized use only", CN=Entrust Root Certification Authority - G2 Certificate added: C=ES, O=Firmaprofesional SA, OID.2.5.4.97=VATES-A62634068, CN=FIRMAPROFESIONAL CA ROOT-A WEB Certificate added: C=CN, O="GUANG DONG CERTIFICATE AUTHORITY CO.,LTD.", CN=GDCA TrustAUTH R5 ROOT Certificate added: C=AT, O=e-commerce monitoring GmbH, CN=GLOBALTRUST 2020 Certificate added: C=US, O=Google Trust Services LLC, CN=GTS Root R1 Certificate added: C=US, O=Google Trust Services LLC, CN=GTS Root R2 Certificate added: C=US, O=Google Trust Services LLC, CN=GTS Root R3 Certificate added: C=US, O=Google Trust Services LLC, CN=GTS Root R4 Certificate added: OU=GlobalSign ECC Root CA - R4, O=GlobalSign, CN=GlobalSign Certificate added: OU=GlobalSign ECC Root CA - R5, O=GlobalSign, CN=GlobalSign Certificate added: C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA Certificate added: OU=GlobalSign Root CA - R3, O=GlobalSign, CN=GlobalSign Certificate added: OU=GlobalSign Root CA - R6, O=GlobalSign, CN=GlobalSign Certificate added: C=BE, O=GlobalSign nv-sa, CN=GlobalSign Root E46 Certificate added: C=BE, O=GlobalSign nv-sa, CN=GlobalSign Root R46 Certificate added: C=US, O="The Go Daddy Group, Inc.", OU=Go Daddy Class 2 Certification Authority Certificate added: C=US, S=Arizona, L=Scottsdale, O="GoDaddy.com, Inc.", CN=Go Daddy Root Certificate Authority - G2 Certificate added: C=GR, O=Hellenic Academic and Research Institutions CA, CN=HARICA TLS ECC Root CA 2021 Certificate added: C=GR, O=Hellenic Academic and Research Institutions CA, CN=HARICA TLS RSA Root CA 2021 Certificate added: C=GR, L=Athens, O=Hellenic Academic and Research Institutions Cert. Authority, CN=Hellenic Academic and Research Institutions ECC RootCA 2015 Certificate added: C=GR, L=Athens, O=Hellenic Academic and Research Institutions Cert. Authority, CN=Hellenic Academic and Research Institutions RootCA 2015 Certificate added: C=TW, O="Chunghwa Telecom Co., Ltd.", CN=HiPKI Root CA - G1 Certificate added: C=HK, S=Hong Kong, L=Hong Kong, O=Hongkong Post, CN=Hongkong Post Root CA 3 Certificate added: C=US, O=Internet Security Research Group, CN=ISRG Root X1 Certificate added: C=US, O=Internet Security Research Group, CN=ISRG Root X2 Certificate added: C=US, O=IdenTrust, CN=IdenTrust Commercial Root CA 1 Certificate added: C=US, O=IdenTrust, CN=IdenTrust Public Sector Root CA 1 Certificate added: C=ES, O=IZENPE S.A., CN=Izenpe.com Certificate added: C=HU, L=Budapest, O=Microsec Ltd., CN=Microsec e-Szigno Root CA 2009, E=info@e-szigno.hu Certificate added: C=US, O=Microsoft Corporation, CN=Microsoft ECC Root Certificate Authority 2017 Certificate added: C=US, O=Microsoft Corporation, CN=Microsoft RSA Root Certificate Authority 2017 Certificate added: C=KR, O=NAVER BUSINESS PLATFORM Corp., CN=NAVER Global Root Certification Authority Certificate added: C=HU, L=Budapest, O=NetLock Kft., OU=Tanúsítványkiadók (Certification Services), CN=NetLock Arany (Class Gold) Főtanúsítvány Certificate added: C=CH, O=WISeKey, OU=OISTE Foundation Endorsed, CN=OISTE WISeKey Global Root GB CA Certificate added: C=CH, O=WISeKey, OU=OISTE Foundation Endorsed, CN=OISTE WISeKey Global Root GC CA Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 1 G3 Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 2 Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 2 G3 Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 3 Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 3 G3 Certificate added: C=US, S=Texas, L=Houston, O=SSL Corporation, CN=SSL.com EV Root Certification Authority ECC Certificate added: C=US, S=Texas, L=Houston, O=SSL Corporation, CN=SSL.com EV Root Certification Authority RSA R2 Certificate added: C=US, S=Texas, L=Houston, O=SSL Corporation, CN=SSL.com Root Certification Authority ECC Certificate added: C=US, S=Texas, L=Houston, O=SSL Corporation, CN=SSL.com Root Certification Authority RSA Certificate added: C=US, O=SSL Corporation, CN=SSL.com TLS ECC Root CA 2022 Certificate added: C=US, O=SSL Corporation, CN=SSL.com TLS RSA Root CA 2022 Certificate added: C=PL, O=Krajowa Izba Rozliczeniowa S.A., CN=SZAFIR ROOT CA2 Certificate added: C=GB, O=Sectigo Limited, CN=Sectigo Public Server Authentication Root E46 Certificate added: C=GB, O=Sectigo Limited, CN=Sectigo Public Server Authentication Root R46 Certificate added: C=JP, O="Cybertrust Japan Co., Ltd.", CN=SecureSign Root CA12 Certificate added: C=JP, O="Cybertrust Japan Co., Ltd.", CN=SecureSign Root CA14 Certificate added: C=JP, O="Cybertrust Japan Co., Ltd.", CN=SecureSign Root CA15 Certificate added: C=US, O=SecureTrust Corporation, CN=SecureTrust CA Certificate added: C=US, O=SecureTrust Corporation, CN=Secure Global CA Certificate added: C=JP, O="SECOM Trust Systems CO.,LTD.", CN=Security Communication ECC RootCA1 Certificate added: C=JP, O="SECOM Trust Systems CO.,LTD.", OU=Security Communication RootCA2 Certificate added: C=US, O="Starfield Technologies, Inc.", OU=Starfield Class 2 Certification Authority Certificate added: C=US, S=Arizona, L=Scottsdale, O="Starfield Technologies, Inc.", CN=Starfield Root Certificate Authority - G2 Certificate added: C=US, S=Arizona, L=Scottsdale, O="Starfield Technologies, Inc.", CN=Starfield Services Root Certificate Authority - G2 Certificate added: C=CH, O=SwissSign AG, CN=SwissSign Gold CA - G2 Certificate added: C=CH, O=SwissSign AG, CN=SwissSign Silver CA - G2 Certificate added: C=DE, O=T-Systems Enterprise Services GmbH, OU=T-Systems Trust Center, CN=T-TeleSec GlobalRoot Class 2 Certificate added: C=DE, O=T-Systems Enterprise Services GmbH, OU=T-Systems Trust Center, CN=T-TeleSec GlobalRoot Class 3 Certificate added: C=TR, L=Gebze - Kocaeli, O=Turkiye Bilimsel ve Teknolojik Arastirma Kurumu - TUBITAK, OU=Kamu Sertifikasyon Merkezi - Kamu SM, CN=TUBITAK Kamu SM SSL Kok Sertifikasi - Surum 1 Certificate added: C=TW, O=TAIWAN-CA, OU=Root CA, CN=TWCA CYBER Root CA Certificate added: C=TW, O=TAIWAN-CA, OU=Root CA, CN=TWCA Global Root CA Certificate added: C=TW, O=TAIWAN-CA, OU=Root CA, CN=TWCA Root Certification Authority Certificate added: C=DE, O=Deutsche Telekom Security GmbH, CN=Telekom Security TLS ECC Root 2020 Certificate added: C=DE, O=Deutsche Telekom Security GmbH, CN=Telekom Security TLS RSA Root 2023 Certificate added: O=TeliaSonera, CN=TeliaSonera Root CA v1 Certificate added: C=FI, O=Telia Finland Oyj, CN=Telia Root CA v2 Certificate added: C=CN, O="TrustAsia Technologies, Inc.", CN=TrustAsia Global Root CA G3 Certificate added: C=CN, O="TrustAsia Technologies, Inc.", CN=TrustAsia Global Root CA G4 Certificate added: C=US, S=Illinois, L=Chicago, O="Trustwave Holdings, Inc.", CN=Trustwave Global Certification Authority Certificate added: C=US, S=Illinois, L=Chicago, O="Trustwave Holdings, Inc.", CN=Trustwave Global ECC P256 Certification Authority Certificate added: C=US, S=Illinois, L=Chicago, O="Trustwave Holdings, Inc.", CN=Trustwave Global ECC P384 Certification Authority Certificate added: C=TN, O=Agence Nationale de Certification Electronique, CN=TunTrust Root CA Certificate added: C=CN, O=UniTrust, CN=UCA Extended Validation Root Certificate added: C=CN, O=UniTrust, CN=UCA Global G2 Root Certificate added: C=US, S=New Jersey, L=Jersey City, O=The USERTRUST Network, CN=USERTrust ECC Certification Authority Certificate added: C=US, S=New Jersey, L=Jersey City, O=The USERTRUST Network, CN=USERTrust RSA Certification Authority Certificate added: C=US, OU=www.xrampsecurity.com, O=XRamp Security Services Inc, CN=XRamp Global Certification Authority Certificate added: C=RO, O=certSIGN, OU=certSIGN ROOT CA Certificate added: C=RO, O=CERTSIGN SA, OU=certSIGN ROOT CA G2 Certificate added: C=HU, L=Budapest, O=Microsec Ltd., OID.2.5.4.97=VATHU-23584497, CN=e-Szigno Root CA 2017 Certificate added: C=TW, O="Chunghwa Telecom Co., Ltd.", OU=ePKI Root Certification Authority Certificate added: C=US, OU=emSign PKI, O=eMudhra Inc, CN=emSign ECC Root CA - C3 Certificate added: C=IN, OU=emSign PKI, O=eMudhra Technologies Limited, CN=emSign ECC Root CA - G3 Certificate added: C=US, OU=emSign PKI, O=eMudhra Inc, CN=emSign Root CA - C1 Certificate added: C=IN, OU=emSign PKI, O=eMudhra Technologies Limited, CN=emSign Root CA - G1 Certificate added: C=CN, O="iTrusChina Co.,Ltd.", CN=vTrus ECC Root CA Certificate added: C=CN, O="iTrusChina Co.,Ltd.", CN=vTrus Root CA 149 new root certificates were added to your trust store. Import process completed. Importing into BTLS system store: I already trust 0, your new list has 149 Certificate added: CN=ACCVRAIZ1, OU=PKIACCV, O=ACCV, C=ES Certificate added: C=ES, O=FNMT-RCM, OU=AC RAIZ FNMT-RCM Certificate added: C=ES, O=FNMT-RCM, OU=Ceres, OID.2.5.4.97=VATES-Q2826004J, CN=AC RAIZ FNMT-RCM SERVIDORES SEGUROS Certificate added: SERIALNUMBER=G63287510, C=ES, O=ANF Autoridad de Certificacion, OU=ANF CA Raiz, CN=ANF Secure Server Root CA Certificate added: C=IT, L=Milan, O=Actalis S.p.A./03358520967, CN=Actalis Authentication Root CA Certificate added: C=US, O=AffirmTrust, CN=AffirmTrust Commercial Certificate added: C=US, O=AffirmTrust, CN=AffirmTrust Networking Certificate added: C=US, O=AffirmTrust, CN=AffirmTrust Premium Certificate added: C=US, O=AffirmTrust, CN=AffirmTrust Premium ECC Certificate added: C=US, O=Amazon, CN=Amazon Root CA 1 Certificate added: C=US, O=Amazon, CN=Amazon Root CA 2 Certificate added: C=US, O=Amazon, CN=Amazon Root CA 3 Certificate added: C=US, O=Amazon, CN=Amazon Root CA 4 Certificate added: CN=Atos TrustedRoot 2011, O=Atos, C=DE Certificate added: CN=Atos TrustedRoot Root CA ECC TLS 2021, O=Atos, C=DE Certificate added: CN=Atos TrustedRoot Root CA RSA TLS 2021, O=Atos, C=DE Certificate added: C=ES, CN=Autoridad de Certificacion Firmaprofesional CIF A62634068 Certificate added: C=CN, O=BEIJING CERTIFICATE AUTHORITY, CN=BJCA Global Root CA1 Certificate added: C=CN, O=BEIJING CERTIFICATE AUTHORITY, CN=BJCA Global Root CA2 Certificate added: C=IE, O=Baltimore, OU=CyberTrust, CN=Baltimore CyberTrust Root Certificate added: C=NO, O=Buypass AS-983163327, CN=Buypass Class 2 Root CA Certificate added: C=NO, O=Buypass AS-983163327, CN=Buypass Class 3 Root CA Certificate added: C=SK, L=Bratislava, O=Disig a.s., CN=CA Disig Root R2 Certificate added: C=CN, O=China Financial Certification Authority, CN=CFCA EV ROOT Certificate added: C=GB, S=Greater Manchester, L=Salford, O=COMODO CA Limited, CN=COMODO Certification Authority Certificate added: C=GB, S=Greater Manchester, L=Salford, O=COMODO CA Limited, CN=COMODO ECC Certification Authority Certificate added: C=GB, S=Greater Manchester, L=Salford, O=COMODO CA Limited, CN=COMODO RSA Certification Authority Certificate added: C=US, O=Certainly, CN=Certainly Root E1 Certificate added: C=US, O=Certainly, CN=Certainly Root R1 Certificate added: C=FR, O=Dhimyotis, CN=Certigna Certificate added: C=FR, O=Dhimyotis, OU=0002 48146308100036, CN=Certigna Root CA Certificate added: C=PL, O=Asseco Data Systems S.A., OU=Certum Certification Authority, CN=Certum EC-384 CA Certificate added: C=PL, O=Unizeto Technologies S.A., OU=Certum Certification Authority, CN=Certum Trusted Network CA Certificate added: C=PL, O=Unizeto Technologies S.A., OU=Certum Certification Authority, CN=Certum Trusted Network CA 2 Certificate added: C=PL, O=Asseco Data Systems S.A., OU=Certum Certification Authority, CN=Certum Trusted Root CA Certificate added: C=US, O=CommScope, CN=CommScope Public Trust ECC Root-01 Certificate added: C=US, O=CommScope, CN=CommScope Public Trust ECC Root-02 Certificate added: C=US, O=CommScope, CN=CommScope Public Trust RSA Root-01 Certificate added: C=US, O=CommScope, CN=CommScope Public Trust RSA Root-02 Certificate added: C=GB, S=Greater Manchester, L=Salford, O=Comodo CA Limited, CN=AAA Certificate Services Certificate added: C=DE, O=D-Trust GmbH, CN=D-TRUST BR Root CA 1 2020 Certificate added: C=DE, O=D-Trust GmbH, CN=D-TRUST EV Root CA 1 2020 Certificate added: C=DE, O=D-Trust GmbH, CN=D-TRUST Root Class 3 CA 2 2009 Certificate added: C=DE, O=D-Trust GmbH, CN=D-TRUST Root Class 3 CA 2 EV 2009 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Assured ID Root CA Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Assured ID Root G2 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Assured ID Root G3 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Global Root CA Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Global Root G2 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Global Root G3 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert High Assurance EV Root CA Certificate added: C=US, O="DigiCert, Inc.", CN=DigiCert TLS ECC P384 Root G5 Certificate added: C=US, O="DigiCert, Inc.", CN=DigiCert TLS RSA4096 Root G5 Certificate added: C=US, O=DigiCert Inc, OU=www.digicert.com, CN=DigiCert Trusted Root G4 Certificate added: O=Entrust.net, OU=www.entrust.net/CPS_2048 incorp. by ref. (limits liab.), OU=(c) 1999 Entrust.net Limited, CN=Entrust.net Certification Authority (2048) Certificate added: C=US, O="Entrust, Inc.", OU=www.entrust.net/CPS is incorporated by reference, OU="(c) 2006 Entrust, Inc.", CN=Entrust Root Certification Authority Certificate added: C=US, O="Entrust, Inc.", OU=See www.entrust.net/legal-terms, OU="(c) 2012 Entrust, Inc. - for authorized use only", CN=Entrust Root Certification Authority - EC1 Certificate added: C=US, O="Entrust, Inc.", OU=See www.entrust.net/legal-terms, OU="(c) 2009 Entrust, Inc. - for authorized use only", CN=Entrust Root Certification Authority - G2 Certificate added: C=ES, O=Firmaprofesional SA, OID.2.5.4.97=VATES-A62634068, CN=FIRMAPROFESIONAL CA ROOT-A WEB Certificate added: C=CN, O="GUANG DONG CERTIFICATE AUTHORITY CO.,LTD.", CN=GDCA TrustAUTH R5 ROOT Certificate added: C=AT, O=e-commerce monitoring GmbH, CN=GLOBALTRUST 2020 Certificate added: C=US, O=Google Trust Services LLC, CN=GTS Root R1 Certificate added: C=US, O=Google Trust Services LLC, CN=GTS Root R2 Certificate added: C=US, O=Google Trust Services LLC, CN=GTS Root R3 Certificate added: C=US, O=Google Trust Services LLC, CN=GTS Root R4 Certificate added: OU=GlobalSign ECC Root CA - R4, O=GlobalSign, CN=GlobalSign Certificate added: OU=GlobalSign ECC Root CA - R5, O=GlobalSign, CN=GlobalSign Certificate added: C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA Certificate added: OU=GlobalSign Root CA - R3, O=GlobalSign, CN=GlobalSign Certificate added: OU=GlobalSign Root CA - R6, O=GlobalSign, CN=GlobalSign Certificate added: C=BE, O=GlobalSign nv-sa, CN=GlobalSign Root E46 Certificate added: C=BE, O=GlobalSign nv-sa, CN=GlobalSign Root R46 Certificate added: C=US, O="The Go Daddy Group, Inc.", OU=Go Daddy Class 2 Certification Authority Certificate added: C=US, S=Arizona, L=Scottsdale, O="GoDaddy.com, Inc.", CN=Go Daddy Root Certificate Authority - G2 Certificate added: C=GR, O=Hellenic Academic and Research Institutions CA, CN=HARICA TLS ECC Root CA 2021 Certificate added: C=GR, O=Hellenic Academic and Research Institutions CA, CN=HARICA TLS RSA Root CA 2021 Certificate added: C=GR, L=Athens, O=Hellenic Academic and Research Institutions Cert. Authority, CN=Hellenic Academic and Research Institutions ECC RootCA 2015 Certificate added: C=GR, L=Athens, O=Hellenic Academic and Research Institutions Cert. Authority, CN=Hellenic Academic and Research Institutions RootCA 2015 Certificate added: C=TW, O="Chunghwa Telecom Co., Ltd.", CN=HiPKI Root CA - G1 Certificate added: C=HK, S=Hong Kong, L=Hong Kong, O=Hongkong Post, CN=Hongkong Post Root CA 3 Certificate added: C=US, O=Internet Security Research Group, CN=ISRG Root X1 Certificate added: C=US, O=Internet Security Research Group, CN=ISRG Root X2 Certificate added: C=US, O=IdenTrust, CN=IdenTrust Commercial Root CA 1 Certificate added: C=US, O=IdenTrust, CN=IdenTrust Public Sector Root CA 1 Certificate added: C=ES, O=IZENPE S.A., CN=Izenpe.com Certificate added: C=HU, L=Budapest, O=Microsec Ltd., CN=Microsec e-Szigno Root CA 2009, E=info@e-szigno.hu Certificate added: C=US, O=Microsoft Corporation, CN=Microsoft ECC Root Certificate Authority 2017 Certificate added: C=US, O=Microsoft Corporation, CN=Microsoft RSA Root Certificate Authority 2017 Certificate added: C=KR, O=NAVER BUSINESS PLATFORM Corp., CN=NAVER Global Root Certification Authority Certificate added: C=HU, L=Budapest, O=NetLock Kft., OU=Tanúsítványkiadók (Certification Services), CN=NetLock Arany (Class Gold) Főtanúsítvány Certificate added: C=CH, O=WISeKey, OU=OISTE Foundation Endorsed, CN=OISTE WISeKey Global Root GB CA Certificate added: C=CH, O=WISeKey, OU=OISTE Foundation Endorsed, CN=OISTE WISeKey Global Root GC CA Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 1 G3 Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 2 Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 2 G3 Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 3 Certificate added: C=BM, O=QuoVadis Limited, CN=QuoVadis Root CA 3 G3 Certificate added: C=US, S=Texas, L=Houston, O=SSL Corporation, CN=SSL.com EV Root Certification Authority ECC Certificate added: C=US, S=Texas, L=Houston, O=SSL Corporation, CN=SSL.com EV Root Certification Authority RSA R2 Certificate added: C=US, S=Texas, L=Houston, O=SSL Corporation, CN=SSL.com Root Certification Authority ECC Certificate added: C=US, S=Texas, L=Houston, O=SSL Corporation, CN=SSL.com Root Certification Authority RSA Certificate added: C=US, O=SSL Corporation, CN=SSL.com TLS ECC Root CA 2022 Certificate added: C=US, O=SSL Corporation, CN=SSL.com TLS RSA Root CA 2022 Certificate added: C=PL, O=Krajowa Izba Rozliczeniowa S.A., CN=SZAFIR ROOT CA2 Certificate added: C=GB, O=Sectigo Limited, CN=Sectigo Public Server Authentication Root E46 Certificate added: C=GB, O=Sectigo Limited, CN=Sectigo Public Server Authentication Root R46 Certificate added: C=JP, O="Cybertrust Japan Co., Ltd.", CN=SecureSign Root CA12 Certificate added: C=JP, O="Cybertrust Japan Co., Ltd.", CN=SecureSign Root CA14 Certificate added: C=JP, O="Cybertrust Japan Co., Ltd.", CN=SecureSign Root CA15 Certificate added: C=US, O=SecureTrust Corporation, CN=SecureTrust CA Certificate added: C=US, O=SecureTrust Corporation, CN=Secure Global CA Certificate added: C=JP, O="SECOM Trust Systems CO.,LTD.", CN=Security Communication ECC RootCA1 Certificate added: C=JP, O="SECOM Trust Systems CO.,LTD.", OU=Security Communication RootCA2 Certificate added: C=US, O="Starfield Technologies, Inc.", OU=Starfield Class 2 Certification Authority Certificate added: C=US, S=Arizona, L=Scottsdale, O="Starfield Technologies, Inc.", CN=Starfield Root Certificate Authority - G2 Certificate added: C=US, S=Arizona, L=Scottsdale, O="Starfield Technologies, Inc.", CN=Starfield Services Root Certificate Authority - G2 Certificate added: C=CH, O=SwissSign AG, CN=SwissSign Gold CA - G2 Certificate added: C=CH, O=SwissSign AG, CN=SwissSign Silver CA - G2 Certificate added: C=DE, O=T-Systems Enterprise Services GmbH, OU=T-Systems Trust Center, CN=T-TeleSec GlobalRoot Class 2 Certificate added: C=DE, O=T-Systems Enterprise Services GmbH, OU=T-Systems Trust Center, CN=T-TeleSec GlobalRoot Class 3 Certificate added: C=TR, L=Gebze - Kocaeli, O=Turkiye Bilimsel ve Teknolojik Arastirma Kurumu - TUBITAK, OU=Kamu Sertifikasyon Merkezi - Kamu SM, CN=TUBITAK Kamu SM SSL Kok Sertifikasi - Surum 1 Certificate added: C=TW, O=TAIWAN-CA, OU=Root CA, CN=TWCA CYBER Root CA Certificate added: C=TW, O=TAIWAN-CA, OU=Root CA, CN=TWCA Global Root CA Certificate added: C=TW, O=TAIWAN-CA, OU=Root CA, CN=TWCA Root Certification Authority Certificate added: C=DE, O=Deutsche Telekom Security GmbH, CN=Telekom Security TLS ECC Root 2020 Certificate added: C=DE, O=Deutsche Telekom Security GmbH, CN=Telekom Security TLS RSA Root 2023 Certificate added: O=TeliaSonera, CN=TeliaSonera Root CA v1 Certificate added: C=FI, O=Telia Finland Oyj, CN=Telia Root CA v2 Certificate added: C=CN, O="TrustAsia Technologies, Inc.", CN=TrustAsia Global Root CA G3 Certificate added: C=CN, O="TrustAsia Technologies, Inc.", CN=TrustAsia Global Root CA G4 Certificate added: C=US, S=Illinois, L=Chicago, O="Trustwave Holdings, Inc.", CN=Trustwave Global Certification Authority Certificate added: C=US, S=Illinois, L=Chicago, O="Trustwave Holdings, Inc.", CN=Trustwave Global ECC P256 Certification Authority Certificate added: C=US, S=Illinois, L=Chicago, O="Trustwave Holdings, Inc.", CN=Trustwave Global ECC P384 Certification Authority Certificate added: C=TN, O=Agence Nationale de Certification Electronique, CN=TunTrust Root CA Certificate added: C=CN, O=UniTrust, CN=UCA Extended Validation Root Certificate added: C=CN, O=UniTrust, CN=UCA Global G2 Root Certificate added: C=US, S=New Jersey, L=Jersey City, O=The USERTRUST Network, CN=USERTrust ECC Certification Authority Certificate added: C=US, S=New Jersey, L=Jersey City, O=The USERTRUST Network, CN=USERTrust RSA Certification Authority Certificate added: C=US, OU=www.xrampsecurity.com, O=XRamp Security Services Inc, CN=XRamp Global Certification Authority Certificate added: C=RO, O=certSIGN, OU=certSIGN ROOT CA Certificate added: C=RO, O=CERTSIGN SA, OU=certSIGN ROOT CA G2 Certificate added: C=HU, L=Budapest, O=Microsec Ltd., OID.2.5.4.97=VATHU-23584497, CN=e-Szigno Root CA 2017 Certificate added: C=TW, O="Chunghwa Telecom Co., Ltd.", OU=ePKI Root Certification Authority Certificate added: C=US, OU=emSign PKI, O=eMudhra Inc, CN=emSign ECC Root CA - C3 Certificate added: C=IN, OU=emSign PKI, O=eMudhra Technologies Limited, CN=emSign ECC Root CA - G3 Certificate added: C=US, OU=emSign PKI, O=eMudhra Inc, CN=emSign Root CA - C1 Certificate added: C=IN, OU=emSign PKI, O=eMudhra Technologies Limited, CN=emSign Root CA - G1 Certificate added: C=CN, O="iTrusChina Co.,Ltd.", CN=vTrus ECC Root CA Certificate added: C=CN, O="iTrusChina Co.,Ltd.", CN=vTrus Root CA 149 new root certificates were added to your trust store. Import process completed. installing libnl... installing nspr... installing nss... installing pkcs11-helper... installing openvpn... Optional dependencies for openvpn easy-rsa: easy CA and certificate handling pam: authenticate via PAM [installed] installing duktape... installing polkit... installing shared-mime-info... installing gdk-pixbuf2... Optional dependencies for gdk-pixbuf2 libwmf: Load .wmf and .apm libopenraw: Load .dng, .cr2, .crw, .nef, .orf, .pef, .arw, .erf, .mrw, and .raf libavif: Load .avif libheif: Load .heif, .heic, and .avif libjxl: Load .jxl librsvg: Load .svg, .svgz, and .svg.gz [pending] webp-pixbuf-loader: Load .webp installing libnotify... installing hicolor-icon-theme... installing adwaita-icon-theme-legacy... installing adwaita-cursors... installing adwaita-icon-theme... installing dconf... installing gsettings-system-schemas... installing adobe-source-code-pro-fonts... installing cantarell-fonts... installing gsettings-desktop-schemas... installing libxfixes... installing libxi... installing libxtst... installing xorg-xprop... installing at-spi2-core... installing desktop-file-utils... installing iso-codes... installing libcloudproviders... installing lcms2... installing libcolord... installing libdaemon... installing avahi... Optional dependencies for avahi gtk3: avahi-discover, avahi-discover-standalone, bshell, bssh, bvnc [pending] libevent: libevent bindings [installed] nss-mdns: NSS support for mDNS python-dbus: avahi-bookmarks, avahi-discover python-gobject: avahi-bookmarks, avahi-discover python-twisted: avahi-bookmarks qt5-base: qt5 bindings installing libcups... installing libpciaccess... installing libdrm... Optional dependencies for libdrm cairo: needed for modetest tool [installed] installing libxshmfence... installing libxxf86vm... installing libedit... installing llvm-libs... installing lm_sensors... Optional dependencies for lm_sensors rrdtool: for logging with sensord perl: for sensor detection and configuration convert [installed] installing spirv-tools... installing default-cursors... Optional dependencies for default-cursors adwaita-cursors: default cursor theme [installed] installing wayland... installing mesa... Optional dependencies for mesa opengl-man-pages: for the OpenGL API man pages installing libglvnd... installing libepoxy... installing dav1d... Optional dependencies for dav1d dav1d-doc: HTML documentation installing librsvg... installing libxcomposite... installing libxcursor... installing libxdamage... installing libxinerama... installing xkeyboard-config... installing libxkbcommon... Optional dependencies for libxkbcommon libxkbcommon-x11: xkbcli interactive-x11 wayland: xkbcli interactive-wayland [installed] installing libxrandr... installing json-glib... installing libproxy... installing glib-networking... installing libsoup3... Optional dependencies for libsoup3 samba: Windows Domain SSO installing libstemmer... installing tinysparql... installing gtk-update-icon-cache... installing gtk3... Optional dependencies for gtk3 evince: Default print preview command installing ayatana-ido... installing libayatana-indicator... installing libdbusmenu-glib... installing libdbusmenu-gtk3... installing libayatana-appindicator... :: Running post-transaction hooks... ( 1/16) Creating system user accounts... Creating group 'avahi' with GID 972. Creating user 'avahi' (Avahi mDNS/DNS-SD daemon) with UID 972 and GID 972. Creating group 'openvpn' with GID 971. Creating user 'openvpn' (OpenVPN) with UID 971 and GID 971. Creating group 'polkitd' with GID 102. Creating user 'polkitd' (User for polkitd) with UID 102 and GID 102. ( 2/16) Registering binary formats... Skipped: Current root is not booted. ( 3/16) Reloading system manager configuration... Skipped: Current root is not booted. ( 4/16) Reloading user manager configuration... Skipped: Current root is not booted. ( 5/16) Creating temporary files... ( 6/16) Arming ConditionNeedsUpdate... ( 7/16) Updating the MIME type database... ( 8/16) Updating fontconfig configuration... ( 9/16) Reloading system bus configuration... Skipped: Current root is not booted. (10/16) Updating fontconfig cache... (11/16) Probing GDK-Pixbuf loader modules... (12/16) Updating GIO module cache... (13/16) Compiling GSettings XML schema files... (14/16) Probing GTK3 input method modules... (15/16) Updating icon theme caches... (16/16) Updating the desktop file MIME type cache... ==> Checking buildtime dependencies... ==> Installing missing dependencies... resolving dependencies... looking for conflicting packages... Package (17) New Version Net Change extra/cppdap 1.58.0-2 1.55 MiB extra/dotnet-host 8.0.10.sdk110-1 0.44 MiB extra/dotnet-runtime 8.0.10.sdk110-1 66.28 MiB extra/dotnet-targeting-pack 8.0.10.sdk110-1 45.49 MiB extra/jsoncpp 1.9.6-3 0.77 MiB extra/libunwind 1.8.1-3 0.29 MiB extra/libuv 1.49.2-1 0.61 MiB extra/netstandard-targeting-pack 8.0.10.sdk110-1 17.87 MiB extra/perl-error 0.17029-7 0.04 MiB extra/perl-mailtools 2.21-9 0.10 MiB extra/perl-timedate 2.33-7 0.08 MiB extra/rhash 1.4.4-1 0.32 MiB extra/cmake 3.31.2-1 77.90 MiB extra/dotnet-sdk 8.0.10.sdk110-1 299.56 MiB extra/git 2.47.1-1 28.29 MiB extra/mono-msbuild 16.10.1.xamarinxplat.2021.05.26.14.00-5 44.41 MiB extra/patchelf 0.18.0-3 0.24 MiB Total Installed Size: 584.24 MiB :: Proceed with installation? [Y/n] checking keyring... checking package integrity... loading package files... checking for file conflicts... :: Processing package changes... installing perl-error... installing perl-timedate... installing perl-mailtools... installing git... Optional dependencies for git tk: gitk and git gui openssh: ssh transport and crypto perl-libwww: git svn perl-term-readkey: git svn and interactive.singlekey setting perl-io-socket-ssl: git send-email TLS support perl-authen-sasl: git send-email TLS support perl-mediawiki-api: git mediawiki support perl-datetime-format-iso8601: git mediawiki support perl-lwp-protocol-https: git mediawiki https support perl-cgi: gitweb (web interface) support python: git svn & git p4 [installed] subversion: git svn org.freedesktop.secrets: keyring credential helper libsecret: libsecret credential helper [installed] installing cppdap... installing jsoncpp... Optional dependencies for jsoncpp jsoncpp-doc: documentation installing libuv... installing rhash... installing cmake... Optional dependencies for cmake make: for unix Makefile generator [installed] ninja: for ninja generator qt6-base: cmake-gui installing patchelf... installing dotnet-host... Optional dependencies for dotnet-host bash-completion: Bash completion support installing libunwind... installing dotnet-runtime... Optional dependencies for dotnet-runtime lttng-ust2.12: CoreCLR tracing installing netstandard-targeting-pack... Optional dependencies for netstandard-targeting-pack bash-completion: Bash completion support installing dotnet-targeting-pack... Optional dependencies for dotnet-targeting-pack bash-completion: Bash completion support installing dotnet-sdk... Optional dependencies for dotnet-sdk aspnet-targeting-pack: Build ASP.NET Core applications installing mono-msbuild... :: Running post-transaction hooks... (1/7) Creating system user accounts... Creating group 'git' with GID 970. Creating user 'git' (git daemon user) with UID 970 and GID 970. (2/7) Reloading system manager configuration... Skipped: Current root is not booted. (3/7) Arming ConditionNeedsUpdate... (4/7) Updating the MIME type database... (5/7) Warn about old perl modules (6/7) Updating icon theme caches... (7/7) Updating the desktop file MIME type cache... ==> Retrieving sources... ==> WARNING: Skipping all source file integrity checks. ==> Extracting sources... -> Creating working copy of Eddie git repo... Cloning into 'Eddie'... done. ==> Starting build()... Welcome to .NET 8.0! --------------------- SDK Version: 8.0.110 ---------------- Installed an ASP.NET Core HTTPS development certificate. To trust the certificate, view the instructions: https://aka.ms/dotnet-https-linux ---------------- Write your first app: https://aka.ms/dotnet-hello-world Find out what's new: https://aka.ms/dotnet-whats-new Explore documentation: https://aka.ms/dotnet-docs Report issues and find source on GitHub: https://github.com/dotnet/core Use 'dotnet --help' to see available commands or visit: https://aka.ms/dotnet-cli -------------------------------------------------------------------------------------- An issue was encountered verifying workloads. For more information, run "dotnet workload update". MSBuild version 17.8.5+b5265ef37 for .NET Determining projects to restore... Restored /build/eddie-ui-git/src/Eddie/src/App.CLI.Linux/App.CLI.Linux.net8.csproj (in 3.13 sec). Restored /build/eddie-ui-git/src/Eddie/src/Lib.Platform.Linux/Lib.Platform.Linux.net8.csproj (in 3.13 sec). Restored /build/eddie-ui-git/src/Eddie/src/Lib.Core/Lib.Core.net8.csproj (in 3.13 sec). Lib.Core.net8 -> /build/eddie-ui-git/src/Eddie/src/Lib.Core/bin/Release/net8.0/Lib.Core.dll Lib.Platform.Linux.net8 -> /build/eddie-ui-git/src/Eddie/src/Lib.Platform.Linux/bin/Release/net8.0/Lib.Platform.Linux.dll App.CLI.Linux.net8 -> /build/eddie-ui-git/src/Eddie/src/App.CLI.Linux/bin/Release/net8.0/linux-x64/eddie-cli.dll BasePath: /build/eddie-ui-git/src/Eddie/src/App.CLI.Linux TargetDir: /build/eddie-ui-git/src/Eddie/src/App.CLI.Linux/bin/Release/net8.0/linux-x64/ Arch: x64 Config: Release Building eddie-cli-elevated - Config: Release, Shared: yes Building eddie-cli-elevated - Done Building eddie-cli-elevated-service - Config: Release Building eddie-cli-elevated-service - Done Building libLib.Platform.Linux.Native.so - Config: Release Building libLib.Platform.Linux.Native.so - Done Optimizing assemblies for size. This process might take a while. App.CLI.Linux.net8 -> /build/eddie-ui-git/src/Eddie/src/App.CLI.Linux/bin/Release/net8.0/linux-x64/publish/ Microsoft (R) Build Engine version 16.10.1 for Mono Copyright (C) Microsoft Corporation. All rights reserved. Lib.Core -> /build/eddie-ui-git/src/Eddie/src/Lib.Core/bin/x64/Release/Lib.Core.dll Lib.Forms.Skin -> /build/eddie-ui-git/src/Eddie/src/Lib.Forms.Skin/bin/x64/Release/Lib.Forms.Skin.dll Lib.Forms -> /build/eddie-ui-git/src/Eddie/src/Lib.Forms/bin/x64/Release/Lib.Forms.dll Lib.Platform.Linux -> /build/eddie-ui-git/src/Eddie/src/Lib.Platform.Linux/bin/x64/Release/Lib.Platform.Linux.dll App.Forms.Linux -> /build/eddie-ui-git/src/Eddie/src/App.Forms.Linux/bin/x64/Release/App.Forms.Linux.exe BasePath: /build/eddie-ui-git/src/Eddie/src/App.Forms.Linux TargetDir: src/App.Forms.Linux/bin/x64/Release/ Arch: x64 Config: Release Building eddie-cli-elevated - Config: Release, Shared: yes Building eddie-cli-elevated - Done Building eddie-cli-elevated-service - Config: Release Building eddie-cli-elevated-service - Done Building libLib.Platform.Linux.Native.so - Config: Release Building libLib.Platform.Linux.Native.so - Done Building eddie-tray - Config: Release Building eddie-tray - If compilation errors occur, remember libayatana-appindicator3-dev package is required. Building eddie-tray - Done Download mkbundle target. If break here, check with mkbundle --list-targets and fix build.sh MKBUNDLECROSSTARGET From: /build/.mono/targets/mono-6.8.0-debian-10-x64 Using runtime: /build/.mono/targets/mono-6.8.0-debian-10-x64/bin/mono Assembly: /build/eddie-ui-git/src/Eddie/src/App.Forms.Linux/bin/x64/Release/App.Forms.Linux.exe Config: /build/eddie-ui-git/src/Eddie/src/App.Forms.Linux/bin/x64/Release/App.Forms.Linux.exe.config Assembly: /build/eddie-ui-git/src/Eddie/src/App.Forms.Linux/bin/x64/Release/mscorlib.dll Assembly: /build/eddie-ui-git/src/Eddie/src/App.Forms.Linux/bin/x64/Release/Lib.Forms.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Drawing.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/Mono.Security.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Configuration.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Xml.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Security.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Core.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Numerics.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Windows.Forms.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Runtime.Serialization.Formatters.Soap.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/Accessibility.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/Mono.WebBrowser.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/Mono.Posix.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Data.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.Transactions.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/System.EnterpriseServices.dll Assembly: /build/eddie-ui-git/src/Eddie/src/App.Forms.Linux/bin/x64/Release/Lib.Core.dll Assembly: /build/eddie-ui-git/src/Eddie/src/App.Forms.Linux/bin/x64/Release/Lib.Forms.Skin.dll Assembly: /build/eddie-ui-git/src/Eddie/src/App.Forms.Linux/bin/x64/Release/Lib.Platform.Linux.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/I18N.CJK.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/I18N.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/I18N.MidEast.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/I18N.Other.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/I18N.Rare.dll Assembly: /build/.mono/targets/mono-6.8.0-debian-10-x64/lib/mono/4.5/I18N.West.dll systemconfig: mkbundle.config machineconfig: /build/.mono/targets/mono-6.8.0-debian-10-x64/etc/mono/4.5/machine.config Library: ../../../../../repository/linux_portable/mkbundle/x64/libMonoPosixHelper.so Library: ../../../../../repository/linux_portable/mkbundle/x64/libgdiplus.so.0 Library: /usr/lib/libmono-native.so Generated eddie-ui % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 61556 0 61556 0 0 103k 0 --:--:-- --:--:-- --:--:-- 103k ==> Entering fakeroot environment... ==> Starting package()... -> Installing desktop file... ==> Tidying install... -> Removing libtool files... -> Purging unwanted files... -> Removing static library files... -> Copying source files needed for debug symbols... -> Compressing man and info pages... ==> Checking for packaging issues... ==> WARNING: Package contains reference to $srcdir usr/lib/eddie-ui/eddie-cli usr/lib/eddie-ui/libLib.Platform.Linux.Native.so usr/lib/eddie-ui/eddie-ui usr/lib/eddie-ui/eddie-cli-elevated usr/lib/eddie-ui/eddie-cli-elevated-service ==> Creating package "eddie-ui-git"... -> Generating .PKGINFO file... -> Generating .BUILDINFO file... -> Adding install file... -> Generating .MTREE file... -> Compressing package... ==> Leaving fakeroot environment. ==> Finished making: eddie-ui-git 2.24.5-1 (Fri Dec 13 14:25:25 2024) Edited ... by BlackSpart Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... On 12/13/2024 at 2:54 PM, BlackSpart said: aur downloading... What is this repo you're pulling? It's not an Arch-provided repo, so the very first thing I'm going to do is to doubt you're really running vanilla Arch. Did you try building outside a chroot? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
BlackSpart 0 Posted ... On 12/14/2024 at 11:31 PM, OpenSourcerer said: What is this repo you're pulling? It's not an Arch-provided repo, so the very first thing I'm going to do is to doubt you're really running vanilla Arch. This is my local repository, configured like this in `/etc/pacman.conf` : [aur] SigLevel = Never TrustAll Server = file:///home/aur It contains only the AUR packages that I have built using the same method I have described in the first post. Nothing too exotic here I think : $ pacman -Sl aur aur aurutils 20.3-1 [installé] aur brave-bin 1:1.73.104-1 [installé] aur phonon-qt6-mpv 0.1.0-1 [installé] aur phonon-qt6-mpv-debug 0.1.0-1 aur tuxedo-control-center-bin 2.1.16-1 [installé] aur tuxedo-drivers-dkms 4.11.7-1 [installé] On 12/14/2024 at 11:31 PM, OpenSourcerer said: Did you try building outside a chroot? I just tried and it works when building outside a chroot... but it is a lot less clean because the build process is executed as my main user, and all the build dependencies are installed globally on my system. The stable package of the AUR `eddie-ui` works when built in a chroot, so this is a bug. Thank you for your answer ! Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... I see. Bit of a mixup here because some Arch-based distros provide a repo with prebuilt packages also called aur while the users said they were "using Arch" (which they weren't really, because Manjaro, CachyOS, Endeavour, etc. are not Arch), and it was the source of problems in those cases. 21 hours ago, BlackSpart said: so this is a bug I wouldn't jump to this conclusion without doing anything else to verify it. 22 hours ago, BlackSpart said: but it is a lot less clean because the build process is executed as my main user, and all the build dependencies are installed globally on my system. Is an option to simply remove the builddeps after building not there? Virtually all pacman wrappers support this. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Infradragon 0 Posted ... (edited) i'm having the exact same issue with both the eddie-ui and eddie-ui-git packages from the AUR edit: figured it out, the packge from the cachyos repos is causing the issue, i'll report this upstream Edited ... by Infradragon Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... 5 hours ago, Infradragon said: edit: figured it out, the packge from the cachyos repos is causing the issue, i'll report this upstream No. Instead, remove the aur repo from your mirrorlist, remove all packages from it and rebuild them live from AUR. Cachy's aur repo is a horror made manifest, I'm hearing nothing but bad things about it. 1 Infradragon reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
