dragen 6 Posted ... Norway's servers are over 60% most of the day. Can you ship a couple of Sweden's unused servers to Oslo? There's like 5 not being used. 4 caffeine0030, wontonko, knighthawk and 1 other reacted to this Quote Share this post Link to post
dalenar 0 Posted ... If you don't mind to connect to geographically nearest servers outside Norway and latency impact is not significant, it's still ok to use those servers from Sweden with low capacity. Check what works best for you. Quote Share this post Link to post
caffeine0030 1 Posted ... (edited) Yes more norwegian servers would be nice. I was going to make the same suggestion. Also one more server in estonia would be great. Good speeds from Alruba when its not at capacity Edited ... by caffeine0030 Quote Share this post Link to post
dragen 6 Posted ... On 11/3/2024 at 9:21 PM, dalenar said: If you don't mind to connect to geographically nearest servers outside Norway and latency impact is not significant, it's still ok to use those servers from Sweden with low capacity. Check what works best for you. Then I'd get swedish localisation on websites (for those sites that sets language based on IP location). And the problem with Norway being underfunded with servers, while Sweden having several that's practically unused would still exist. As I'm writing this, Sweden have 8 servers with less than 10% load out of 13. Norway have 5 servers with only 1 with less than 63%. 1 wontonko reacted to this Quote Share this post Link to post
torgooose 2 Posted ... Yes I agree 2 wontonko and knighthawk reacted to this Quote Share this post Link to post
