tuxxidoic
Unraid with airvpn(Sonarr,Prowlarr, Qbittorrent)
Hello, Im soon 1 month into trying to get my unraid with sonarr, prowlarr & qbittorrent to work. I switched from mullvad to airvpn after understanding that port forwarding was going to be important and mullvad doesnt do that anymore. They used to work, until I started trying to get port forwarding with airvpn to work.
After this,  neither of the mentioned docker apps for unraid work, or: they claim they work fine(connecting together in Unraid etc.). but they dont Download anything and when forcing them to search, nothing comes up.
I have no idea what to do, and I guess I should start here.
Im not sure anything is correct anywhere anymore and I dont know where to start...
- Ive created a wireguard .conf file, which Ive imported in unraid as a tunnel.
- Ive opened ports on your client area, the test open just gives a connection timed out.
- Ive downloaded the torrent from one of the sites linked to, its been stuck on downloading metadata for 2 days now.- I have no idea if I should forward any ports(cant find any definitive answer to this on your site, and if so: I have no idea which port to open)
- My hardware is a Ubiquiti Dream machine pro
- My servers are on a vnet
- I have moved my personal computer to the same vnet(because docker webui's wouldnt work with mullvad if it wasnt)
Anything from anyone here on what I can do to atleast get a confirmation SOMEWHERE that airvpn atleast works???
