提示错误:The request is blocked.
Ref A: E44D5C1A192343E9A990DBBD35581022 Ref B: SG2EDGE1714 Ref C: 2024-10-08T07:08:48Z
或者是这样:
<!DOCTYPE html PUBLIC '-//W3C//DTD XHTML 1.0 Transitional//EN' 'http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd'><html xmlns='http://www.w3.org/1999/xhtml'><head><meta content='text/html; charset=utf-8' http-equiv='content-type'/><style type='text/css'>body { font-family:Arial; margin-left:40px; }img  { border:0 none; }#content { margin-left: auto; margin-right: auto }#message h2 { font-size: 20px; font-weight: normal; color: #000000; margin: 34px 0px 0px 0px }#message p  { font-size: 13px; color: #000000; margin: 7px 0px 0px 0px }#errorref { font-size: 11px; color: #737373; margin-top: 41px }</style><title>Microsoft</title></head><body><div id='content'><div id='message'><h2>The request is blocked.</h2></div><div id='errorref'><span>Ref A: 48C778D2723D4672998EF0196F6E91A9 Ref B: TYO01EDGE3517 Ref C: 2024-10-10T03:44:20Z</span></div></div></body></html>
windows客户端是正常的,我也咨询过微软客服,说我帐号是正常的。
如果通过https://www.startpage.com/,也可以正常进入ondrive网页,唯独不能直接打开
6 hours ago, OpenSourcerer said:
I'm sorry, would you mind posting this in English?
I am unable to access OneDrive on the web, and the OneDrive Android app cannot connect to the internet, but the OneDrive on Windows works fine. I have contacted Microsoft support, and they confirmed that my account is normal. I also sent an email to you before and was informed that Microsoft has blocked VPN usage. I would like to know if this is a temporary or permanent issue. Is there any way to resolve it?"
Currently a lot of sites block access from behind VPN on the ground that those are often used for nefarious activities, ignoring the fact there are millions of people in the world who simply cannot access the bigger Internet otherwise. VPNs are not necessarily detected by IP blacklists (but most commonly are) but also from time difference between your browser and the exit server (fixable by setting a custom time zone for the browser), by non-standard MTU / MSS sizes (also fixable by tweaking MTU size in the VPN client settings), and some other methods.
I don't know why, but it suddenly returned to normal today. Thank you very much for your answer. Using a VPN is legally risky where I live. I always thought that using a VPN could provide anonymity. Since Microsoft can detect that I am using a VPN, does that mean that the government can also easily detect that I am using a VPN?
Since VPNs are detected through time zone differences, does that mean it's safer to use nodes in neighboring countries?
It's just one way of detecting it, mostly it's simply "this IP is a datacenter, it cannot possibly be a legitimate user". You could try and see for yourself if it works, though.
I tried using an IP detection website, and as you mentioned, it says that I don't have a residential IP. Is it possible to disguise it as a residential IP by selecting a different node?
Different node = different server? Then no, as AirVPN servers are datacenter-only.
To disguise as a residential IP the exit node should be operated from a subnet belonging to a residential ISP, i.e. running on a normal household PC. Nowadays only Tor and I2P still has such nodes thanks to the many volunteers, but even Tor has a lot (if not most) of the exit nodes located on virtual private servers at data centers, even if those are operated by the same volunteers. The reason for that is that many residential ISPs around the world no longer provide real IP addresses, only shared behind NAT, while a Tor/VPN exit node should be able to accept connections from any subnet on the Internet to operate normally.
ISP-side NAT is also the main problem with seeding torrents, as well as with true peer-to-peer video and audio calls: theoretically WebRTC connections should be allowed through NAT by ISP but in practice this is often not the case and the video/audio apps has to resort to external TURN servers to transfer data. All of this is almost invisible when using commercial apps such as WhatsApp or Zoom, those can monetize themselves through ads and data mining and pay for their TURN traffic, but when it comes to free or almost-free services such as Jami, Tox, Element, SimpleX, etc. it becomes a problem when too much people flock there thinking it's the same thing as commercial apps. As far as I know only Dash is currently trying to solve this problem, or at least some part of it, through making the platform for creating decentralized self-monetized services.
