Shuwa1141 0 Posted ... (edited) Hi I haven't used Eddie in awhile, and today when I tried to connect to a server it keeps disconnecting and retrying. I saw that some others solved this problem by going to the Eddie setup and entering a new value "eddie" but I am on MacOS and there's no place to do that on that network section. I am running the latest beta of Sequoia 15.1 maybe that's the problem? I'll include my log file if anyone could help that would awesome Thanks in advance Eddie System/Environment Report - 9/22/2024 - 6:57 PM UTC Eddie version: 2.21.8 Eddie OS build: macos_x64 Eddie architecture: x64 OS type: MacOS OS name: macOS 15.1 OS version: 15.1 (Build 24B5046f) OS architecture: x64 Mono /.Net Framework: v4.0.30319 OpenVPN: 2.5.5 - OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 (/Users/stevenlopes/Desktop/Eddie copy.app/Contents/MacOS/openvpn) Hummingbird: 3.3.2 - Hummingbird - AirVPN OpenVPN 3 Client 1.2.0 - 22 March 2022 (/Users/stevenlopes/Desktop/Eddie copy.app/Contents/MacOS/hummingbird) WireGuard: 1.0.20200827 SSH: OpenSSH_9.8p1, LibreSSL 3.3.6 (/usr/bin/ssh) SSL: stunnel 5.56 (/Users/stevenlopes/Desktop/Eddie copy.app/Contents/MacOS/stunnel) Profile path: /Users/stevenlopes/.config/eddie/default.profile Data path: /Users/stevenlopes/.config/eddie Application path: /Users/stevenlopes/Desktop/Eddie copy.app/Contents/MacOS Executable path: /Users/stevenlopes/Desktop/Eddie copy.app/Contents/MacOS/Eddie Command line arguments: (0 args) Network Lock Active: No Connected to VPN: No OS support IPv4: Yes OS support IPv6: Yes Detected DNS: 192.168.50.1 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 106 ms Test Ping IPv6: Failed Test HTTP IPv4: Ok Test HTTP IPv6: Error: Fetch url error:Couldn't connect to server Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True servers.locklast: True areas.allowlist: ch,ca,se,us,nl,no netlock.mode: osx_pf ui.unit: bytes ---------------------------- Logs: . 2024.09.22 14:55:44 - Eddie version: 2.21.8 / macos_x64, System: MacOS, Name: macOS 15.1, Version: 15.1 (Build 24B5046f), Mono/.Net: v4.0.30319 . 2024.09.22 14:55:44 - Raise system privileges . 2024.09.22 14:55:55 - Reading options from /Users/stevenlopes/.config/eddie/default.profile . 2024.09.22 14:55:58 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10 (/Users/stevenlopes/Desktop/Eddie copy.app/Contents/MacOS/openvpn) . 2024.09.22 14:55:58 - SSH - Version: OpenSSH_9.8p1, LibreSSL 3.3.6 (/usr/bin/ssh) . 2024.09.22 14:55:58 - SSL - Version: stunnel 5.56 (/Users/stevenlopes/Desktop/Eddie copy.app/Contents/MacOS/stunnel) I 2024.09.22 14:55:58 - Ready . 2024.09.22 14:55:59 - Collect information about AirVPN completed ---------------------------- Network Interfaces and Routes: { "routes": [ { "destination": "0.0.0.0\/0", "expire": "", "flags": "UGScg", "gateway": "192.168.50.1", "interface": "en0", "mtu": "1500", "refs": "241", "rt_ifa": "192.168.50.90", "use": "735" }, { "destination": "127", "expire": "", "flags": "UCS", "gateway": "127.0.0.1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "127.0.0.1", "use": "0" }, { "destination": "127.0.0.1\/32", "expire": "", "flags": "UH", "gateway": "127.0.0.1", "interface": "lo0", "mtu": "16384", "refs": "12", "rt_ifa": "127.0.0.1", "use": "8314" }, { "destination": "169.254\/32", "expire": "!", "flags": "UCS", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "192.168.50\/32", "expire": "!", "flags": "UCS", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "7", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "192.168.50.1\/32", "expire": "!", "flags": "UCS", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "1", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "192.168.50.1\/32", "expire": "1188", "flags": "UHLWIir", "gateway": "3c:7c:3f:cf:83:a0", "interface": "en0", "mtu": "1500", "refs": "240", "rt_ifa": "192.168.50.90", "use": "305" }, { "destination": "192.168.50.89\/32", "expire": "1183", "flags": "UHLWI", "gateway": "80:76:c2:8a:22:14", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "192.168.50.90\/32", "expire": "!", "flags": "UCS", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "192.168.50.135\/32", "expire": "1194", "flags": "UHLWI", "gateway": "d0:3f:27:36:2a:0", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "192.168.50.151\/32", "expire": "1014", "flags": "UHLWI", "gateway": "b0:f7:c4:37:b5:1c", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "192.168.50.153\/32", "expire": "1174", "flags": "UHLWIi", "gateway": "10:bf:48:8d:83:77", "interface": "en0", "mtu": "1500", "refs": "1", "rt_ifa": "192.168.50.90", "use": "30" }, { "destination": "192.168.50.175\/32", "expire": "898", "flags": "UHLWI", "gateway": "f2:22:f4:df:c:95", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "2" }, { "destination": "192.168.50.239\/32", "expire": "1200", "flags": "UHLWI", "gateway": "46:ae:30:6f:47:6b", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "192.168.50.255\/32", "expire": "!", "flags": "UHLWbI", "gateway": "ff:ff:ff:ff:ff:ff", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "28" }, { "destination": "224.0.0\/4", "expire": "!", "flags": "UmCS", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "1", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "224.0.0.251\/32", "expire": "", "flags": "UHmLWI", "gateway": "1:0:5e:0:0:fb", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "255.255.255.255\/32", "expire": "!", "flags": "UCS", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "192.168.50.90", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::f92c:c871:5509:3882%utun0", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun1", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::10a0:cf3e:5ac7:d00b%utun1", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun2", "mtu": "2000", "refs": "0", "rt_ifa": "fe80::e570:11df:3beb:8b1e%utun2", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun3", "mtu": "1000", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun3", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "2607:fb90:fa78:8400::", "interface": "ipsec0", "mtu": "1500", "refs": "8", "rt_ifa": "fe80::8837:95aa:2539:811%ipsec0", "use": "14" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun4", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::a413:c8c1:3fc5:9f31%utun4", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun5", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::cd04:9da8:3f24:8331%utun5", "use": "0" }, { "destination": "::\/0", "expire": "", "flags": "UGcIg", "gateway": "fe80::", "interface": "utun6", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::692c:ec4b:d7ab:9195%utun6", "use": "0" }, { "destination": "::1\/128", "expire": "", "flags": "UHL", "gateway": "::1", "interface": "lo0", "mtu": "16384", "refs": "1", "rt_ifa": "::1", "use": "14" }, { "destination": "2607:fb90:fa78:8400::\/64", "expire": "", "flags": "Uc", "gateway": "fe80::8837:95aa:2539:811", "interface": "ipsec0", "mtu": "1500", "refs": "2", "rt_ifa": "fe80::8837:95aa:2539:811%ipsec0", "use": "0" }, { "destination": "2607:fb90:fa78:8400:39bc:43b9:150:2e0d\/128", "expire": "", "flags": "UHL", "gateway": "link#22", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "2607:fb90:fa78:8400:39bc:43b9:150:2e0d", "use": "0" }, { "destination": "fda3:94bc:bece:1::\/64", "expire": "", "flags": "UGc", "gateway": "fe80::b2f7:c4ff:fe37:b51c", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::108d:d4d2:9644:b531%en0", "use": "0" }, { "destination": "fdbe:42cd:d28d:901e::\/64", "expire": "", "flags": "UC", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "2", "rt_ifa": "fe80::108d:d4d2:9644:b531%en0", "use": "0" }, { "destination": "fdbe:42cd:d28d:901e:ca4:37c9:4d0b:8648\/128", "expire": "", "flags": "UHLWI", "gateway": "f2:22:f4:df:c:95", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::108d:d4d2:9644:b531%en0", "use": "3" }, { "destination": "fdbe:42cd:d28d:901e:1cfc:28ac:a370:7765\/128", "expire": "", "flags": "UHL", "gateway": "7a:af:8f:b3:16:8c", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fdbe:42cd:d28d:901e:1cfc:28ac:a370:7765", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::1", "interface": "lo0", "mtu": "16384", "refs": "1", "rt_ifa": "fe80::1%lo0", "use": "0" }, { "destination": "fe80::1\/128", "expire": "", "flags": "UHLI", "gateway": "link#1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::1%lo0", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UCI", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "5", "rt_ifa": "fe80::108d:d4d2:9644:b531%en0", "use": "0" }, { "destination": "fe80::8ad:89cb:b422:4599\/128", "expire": "", "flags": "UHLWI", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::108d:d4d2:9644:b531%en0", "use": "0" }, { "destination": "fe80::8b9:5496:6228:6c10\/128", "expire": "", "flags": "UHLWIi", "gateway": "f2:22:f4:df:c:95", "interface": "en0", "mtu": "1500", "refs": "3", "rt_ifa": "fe80::108d:d4d2:9644:b531%en0", "use": "253" }, { "destination": "fe80::108d:d4d2:9644:b531\/128", "expire": "", "flags": "UHLI", "gateway": "7a:af:8f:b3:16:8c", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::108d:d4d2:9644:b531%en0", "use": "0" }, { "destination": "fe80::26ce:33ff:fea7:fa72\/128", "expire": "", "flags": "UHLWI", "gateway": "24:ce:33:a7:fa:72", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::108d:d4d2:9644:b531%en0", "use": "0" }, { "destination": "fe80::b2f7:c4ff:fe37:b51c\/128", "expire": "", "flags": "UHLWIi", "gateway": "b0:f7:c4:37:b5:1c", "interface": "en0", "mtu": "1500", "refs": "1", "rt_ifa": "fe80::108d:d4d2:9644:b531%en0", "use": "0" }, { "destination": "fe80::bcc8:37ff:fe53:ae24\/128", "expire": "", "flags": "UHLI", "gateway": "be:c8:37:53:ae:24", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::bcc8:37ff:fe53:ae24%awdl0", "use": "0" }, { "destination": "fe80::bcc8:37ff:fe53:ae24\/128", "expire": "", "flags": "UHLI", "gateway": "be:c8:37:53:ae:24", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::bcc8:37ff:fe53:ae24%llw0", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::f92c:c871:5509:3882", "interface": "utun0", "mtu": "1500", "refs": "2", "rt_ifa": "fe80::f92c:c871:5509:3882%utun0", "use": "0" }, { "destination": "fe80::f92c:c871:5509:3882\/128", "expire": "", "flags": "UHLI", "gateway": "link#18", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::f92c:c871:5509:3882%utun0", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::10a0:cf3e:5ac7:d00b", "interface": "utun1", "mtu": "1380", "refs": "2", "rt_ifa": "fe80::10a0:cf3e:5ac7:d00b%utun1", "use": "0" }, { "destination": "fe80::10a0:cf3e:5ac7:d00b\/128", "expire": "", "flags": "UHLI", "gateway": "link#19", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::10a0:cf3e:5ac7:d00b%utun1", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::e570:11df:3beb:8b1e", "interface": "utun2", "mtu": "2000", "refs": "2", "rt_ifa": "fe80::e570:11df:3beb:8b1e%utun2", "use": "0" }, { "destination": "fe80::e570:11df:3beb:8b1e\/128", "expire": "", "flags": "UHLI", "gateway": "link#20", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::e570:11df:3beb:8b1e%utun2", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::ce81:b1c:bd2c:69e", "interface": "utun3", "mtu": "1000", "refs": "2", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun3", "use": "0" }, { "destination": "fe80::ce81:b1c:bd2c:69e\/128", "expire": "", "flags": "UHLI", "gateway": "link#21", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun3", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::8837:95aa:2539:811", "interface": "ipsec0", "mtu": "1500", "refs": "1", "rt_ifa": "fe80::8837:95aa:2539:811%ipsec0", "use": "0" }, { "destination": "fe80::8837:95aa:2539:811\/128", "expire": "", "flags": "UHLI", "gateway": "link#22", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::8837:95aa:2539:811%ipsec0", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::a413:c8c1:3fc5:9f31", "interface": "utun4", "mtu": "1380", "refs": "2", "rt_ifa": "fe80::a413:c8c1:3fc5:9f31%utun4", "use": "0" }, { "destination": "fe80::a413:c8c1:3fc5:9f31\/128", "expire": "", "flags": "UHLI", "gateway": "link#23", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::a413:c8c1:3fc5:9f31%utun4", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::cd04:9da8:3f24:8331", "interface": "utun5", "mtu": "1380", "refs": "3", "rt_ifa": "fe80::cd04:9da8:3f24:8331%utun5", "use": "0" }, { "destination": "fe80::cd04:9da8:3f24:8331\/128", "expire": "", "flags": "UHLI", "gateway": "link#24", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::cd04:9da8:3f24:8331%utun5", "use": "0" }, { "destination": "fe80::\/64", "expire": "", "flags": "UcI", "gateway": "fe80::692c:ec4b:d7ab:9195", "interface": "utun6", "mtu": "1380", "refs": "2", "rt_ifa": "fe80::692c:ec4b:d7ab:9195%utun6", "use": "0" }, { "destination": "fe80::692c:ec4b:d7ab:9195\/128", "expire": "", "flags": "UHLI", "gateway": "link#25", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "fe80::692c:ec4b:d7ab:9195%utun6", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "::1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "::1", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::c26:a304:9193:5217%en0", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "link#16", "interface": "awdl0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::10a8:85ff:fe44:1984%awdl0", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "link#17", "interface": "llw0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::10a8:85ff:fe44:1984%llw0", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::f92c:c871:5509:3882", "interface": "utun0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::f92c:c871:5509:3882%utun0", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::10a0:cf3e:5ac7:d00b", "interface": "utun1", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::10a0:cf3e:5ac7:d00b%utun1", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::e570:11df:3beb:8b1e", "interface": "utun2", "mtu": "2000", "refs": "0", "rt_ifa": "fe80::e570:11df:3beb:8b1e%utun2", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::ce81:b1c:bd2c:69e", "interface": "utun3", "mtu": "1000", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun3", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::8837:95aa:2539:811", "interface": "ipsec0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::8837:95aa:2539:811%ipsec0", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::a413:c8c1:3fc5:9f31", "interface": "utun4", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::a413:c8c1:3fc5:9f31%utun4", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::cd04:9da8:3f24:8331", "interface": "utun5", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::cd04:9da8:3f24:8331%utun5", "use": "0" }, { "destination": "ff00::\/8", "expire": "", "flags": "UmCI", "gateway": "fe80::692c:ec4b:d7ab:9195", "interface": "utun6", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::692c:ec4b:d7ab:9195%utun6", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "::1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "::1", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::c26:a304:9193:5217%en0", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::f92c:c871:5509:3882", "interface": "utun0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::f92c:c871:5509:3882%utun0", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::10a0:cf3e:5ac7:d00b", "interface": "utun1", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::10a0:cf3e:5ac7:d00b%utun1", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::e570:11df:3beb:8b1e", "interface": "utun2", "mtu": "2000", "refs": "0", "rt_ifa": "fe80::e570:11df:3beb:8b1e%utun2", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::ce81:b1c:bd2c:69e", "interface": "utun3", "mtu": "1000", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun3", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::8837:95aa:2539:811", "interface": "ipsec0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::8837:95aa:2539:811%ipsec0", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::a413:c8c1:3fc5:9f31", "interface": "utun4", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::a413:c8c1:3fc5:9f31%utun4", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::cd04:9da8:3f24:8331", "interface": "utun5", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::cd04:9da8:3f24:8331%utun5", "use": "0" }, { "destination": "ff01::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::692c:ec4b:d7ab:9195", "interface": "utun6", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::692c:ec4b:d7ab:9195%utun6", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "::1", "interface": "lo0", "mtu": "16384", "refs": "0", "rt_ifa": "::1", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "link#14", "interface": "en0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::c26:a304:9193:5217%en0", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::f92c:c871:5509:3882", "interface": "utun0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::f92c:c871:5509:3882%utun0", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::10a0:cf3e:5ac7:d00b", "interface": "utun1", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::10a0:cf3e:5ac7:d00b%utun1", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::e570:11df:3beb:8b1e", "interface": "utun2", "mtu": "2000", "refs": "0", "rt_ifa": "fe80::e570:11df:3beb:8b1e%utun2", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::ce81:b1c:bd2c:69e", "interface": "utun3", "mtu": "1000", "refs": "0", "rt_ifa": "fe80::ce81:b1c:bd2c:69e%utun3", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::8837:95aa:2539:811", "interface": "ipsec0", "mtu": "1500", "refs": "0", "rt_ifa": "fe80::8837:95aa:2539:811%ipsec0", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::a413:c8c1:3fc5:9f31", "interface": "utun4", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::a413:c8c1:3fc5:9f31%utun4", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::cd04:9da8:3f24:8331", "interface": "utun5", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::cd04:9da8:3f24:8331%utun5", "use": "0" }, { "destination": "ff02::\/32", "expire": "", "flags": "UmCI", "gateway": "fe80::692c:ec4b:d7ab:9195", "interface": "utun6", "mtu": "1380", "refs": "0", "rt_ifa": "fe80::692c:ec4b:d7ab:9195%utun6", "use": "0" } ], "ipv4-default-gateway": "192.168.50.1", "ipv4-default-interface": "en0", "ipv6-default-gateway": "fe80::", "ipv6-default-interface": "utun0", "interfaces": [ { "friendly": "lo0", "id": "lo0", "name": "lo0", "description": "lo0", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "127.0.0.1", "::1", "fe80::1" ], "bind": true }, { "friendly": "gif0", "id": "gif0", "name": "gif0", "description": "gif0", "type": "Unknown", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "stf0", "id": "stf0", "name": "stf0", "description": "stf0", "type": "Unknown", "status": "Unknown", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "anpi2", "id": "anpi2", "name": "anpi2", "description": "anpi2", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "anpi0", "id": "anpi0", "name": "anpi0", "description": "anpi0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "anpi1", "id": "anpi1", "name": "anpi1", "description": "anpi1", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Ethernet Adapter (en4)", "id": "en4", "name": "en4", "description": "en4", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Ethernet Adapter (en5)", "id": "en5", "name": "en5", "description": "en5", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Ethernet Adapter (en6)", "id": "en6", "name": "en6", "description": "en6", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Thunderbolt 1", "id": "en1", "name": "en1", "description": "en1", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Thunderbolt 2", "id": "en2", "name": "en2", "description": "en2", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Thunderbolt 3", "id": "en3", "name": "en3", "description": "en3", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "ap1", "id": "ap1", "name": "ap1", "description": "ap1", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "Wi-Fi", "id": "en0", "name": "en0", "description": "en0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::108d:d4d2:9644:b531", "fdbe:42cd:d28d:901e:1cfc:28ac:a370:7765", "192.168.50.90" ], "bind": true }, { "friendly": "Thunderbolt Bridge", "id": "bridge0", "name": "bridge0", "description": "bridge0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [], "bind": false }, { "friendly": "awdl0", "id": "awdl0", "name": "awdl0", "description": "awdl0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::bcc8:37ff:fe53:ae24" ], "bind": true }, { "friendly": "llw0", "id": "llw0", "name": "llw0", "description": "llw0", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::bcc8:37ff:fe53:ae24" ], "bind": true }, { "friendly": "utun0", "id": "utun0", "name": "utun0", "description": "utun0", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::f92c:c871:5509:3882" ], "bind": true }, { "friendly": "utun1", "id": "utun1", "name": "utun1", "description": "utun1", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::10a0:cf3e:5ac7:d00b" ], "bind": true }, { "friendly": "utun2", "id": "utun2", "name": "utun2", "description": "utun2", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::e570:11df:3beb:8b1e" ], "bind": true }, { "friendly": "utun3", "id": "utun3", "name": "utun3", "description": "utun3", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::ce81:b1c:bd2c:69e" ], "bind": true }, { "friendly": "ipsec0", "id": "ipsec0", "name": "ipsec0", "description": "ipsec0", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::8837:95aa:2539:811", "2607:fb90:fa78:8400:39bc:43b9:150:2e0d" ], "bind": true }, { "friendly": "utun4", "id": "utun4", "name": "utun4", "description": "utun4", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::a413:c8c1:3fc5:9f31" ], "bind": true }, { "friendly": "utun5", "id": "utun5", "name": "utun5", "description": "utun5", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::cd04:9da8:3f24:8331" ], "bind": true }, { "friendly": "utun6", "id": "utun6", "name": "utun6", "description": "utun6", "type": "Unknown", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::692c:ec4b:d7ab:9195" ], "bind": true } ] } ---------------------------- ifconfig: lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP> inet 127.0.0.1 netmask 0xff000000 inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 nd6 options=201<PERFORMNUD,DAD> gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280 stf0: flags=0<> mtu 1280 anpi2: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=400<CHANNEL_IO> ether 5e:c1:8b:ed:25:92 media: none status: inactive anpi0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=400<CHANNEL_IO> ether 5e:c1:8b:ed:25:90 media: none status: inactive anpi1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=400<CHANNEL_IO> ether 5e:c1:8b:ed:25:91 media: none status: inactive en4: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=400<CHANNEL_IO> ether 5e:c1:8b:ed:25:70 nd6 options=201<PERFORMNUD,DAD> media: none status: inactive en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=400<CHANNEL_IO> ether 5e:c1:8b:ed:25:71 nd6 options=201<PERFORMNUD,DAD> media: none status: inactive en6: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=400<CHANNEL_IO> ether 5e:c1:8b:ed:25:72 nd6 options=201<PERFORMNUD,DAD> media: none status: inactive en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500 options=460<TSO4,TSO6,CHANNEL_IO> ether 36:07:d0:2c:3c:c0 media: autoselect <full-duplex> status: inactive en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500 options=460<TSO4,TSO6,CHANNEL_IO> ether 36:07:d0:2c:3c:c4 media: autoselect <full-duplex> status: inactive en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500 options=460<TSO4,TSO6,CHANNEL_IO> ether 36:07:d0:2c:3c:c8 media: autoselect <full-duplex> status: inactive ap1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM> ether a6:17:6d:71:0f:bd nd6 options=201<PERFORMNUD,DAD> media: autoselect (none) status: inactive en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM> ether 7a:af:8f:b3:16:8c inet6 fe80::108d:d4d2:9644:b531%en0 prefixlen 64 secured scopeid 0xe inet6 fdbe:42cd:d28d:901e:1cfc:28ac:a370:7765 prefixlen 64 autoconf secured inet 192.168.50.90 netmask 0xffffff00 broadcast 192.168.50.255 nd6 options=201<PERFORMNUD,DAD> media: autoselect status: active bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=63<RXCSUM,TXCSUM,TSO4,TSO6> ether 36:07:d0:2c:3c:c0 Configuration: id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0 maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200 root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0 ipfilter disabled flags 0x0 member: en1 flags=3<LEARNING,DISCOVER> ifmaxaddr 0 port 10 priority 0 path cost 0 member: en2 flags=3<LEARNING,DISCOVER> ifmaxaddr 0 port 11 priority 0 path cost 0 member: en3 flags=3<LEARNING,DISCOVER> ifmaxaddr 0 port 12 priority 0 path cost 0 nd6 options=201<PERFORMNUD,DAD> media: <unknown type> status: inactive awdl0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM> ether be:c8:37:53:ae:24 inet6 fe80::bcc8:37ff:fe53:ae24%awdl0 prefixlen 64 scopeid 0x10 nd6 options=201<PERFORMNUD,DAD> media: autoselect status: active llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=400<CHANNEL_IO> ether be:c8:37:53:ae:24 inet6 fe80::bcc8:37ff:fe53:ae24%llw0 prefixlen 64 scopeid 0x11 nd6 options=201<PERFORMNUD,DAD> media: autoselect (none) utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500 inet6 fe80::f92c:c871:5509:3882%utun0 prefixlen 64 scopeid 0x12 nd6 options=201<PERFORMNUD,DAD> utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380 inet6 fe80::10a0:cf3e:5ac7:d00b%utun1 prefixlen 64 scopeid 0x13 nd6 options=201<PERFORMNUD,DAD> utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000 inet6 fe80::e570:11df:3beb:8b1e%utun2 prefixlen 64 scopeid 0x14 nd6 options=201<PERFORMNUD,DAD> utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000 inet6 fe80::ce81:b1c:bd2c:69e%utun3 prefixlen 64 scopeid 0x15 nd6 options=201<PERFORMNUD,DAD> ipsec0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500 options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM> inet6 fe80::8837:95aa:2539:811%ipsec0 prefixlen 64 scopeid 0x16 inet6 2607:fb90:fa78:8400:39bc:43b9:150:2e0d prefixlen 64 nd6 options=201<PERFORMNUD,DAD> utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380 inet6 fe80::a413:c8c1:3fc5:9f31%utun4 prefixlen 64 scopeid 0x17 nd6 options=201<PERFORMNUD,DAD> utun5: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380 inet6 fe80::cd04:9da8:3f24:8331%utun5 prefixlen 64 scopeid 0x18 nd6 options=201<PERFORMNUD,DAD> utun6: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380 inet6 fe80::692c:ec4b:d7ab:9195%utun6 prefixlen 64 scopeid 0x19 nd6 options=201<PERFORMNUD,DAD> Edited ... by OpenSourcerer Apply LOG format to system report Share this post Link to post
Tech Jedi Alex 1518 Posted ... Please try a connection first, then paste the system report. Your logs are empty, we cannot really troubleshoot this. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Shuwa1141 0 Posted ... I got it to work by downloading and using the latest beta version of Eddie. Whatever was doing it is gone Thanks Steve Share this post Link to post
