Not connected, Your IP: 216.73.216.39
Unknown52
Wireguard Port forwarding
Hi I am thinking about buying the vpn but I want to know if it supports Port forwarding on port 80 and 443. And what's the speed I could get. I need to be able to use my 110 MIB/S
No, you cannot forward 80 and 443 or other widely used low-numbered ports.  Instead, you reserve high-numbered ports that are not currently reserved by other users.
Your speed goals are not a problem.  Users routinely obtain many times that speed over wireguard (though YMMV of course).
Edit: 100 Megabits/s is certainly no problem.  But b or B here?  100 Megabytes/s is sometimes do-able, but it depends on server load and, of course, on your own hardware.  Probably not a speed to count on.
Edited ... by SurprisedItWorks
misread MiB as Mib
