UnknownKoala
ANSWERED Eddie-UI always restores ipv6 DNS settings to "automatic" on disconnect
I noticed that everytime you disconnect from AirVpn servers that your previously set DNS settings of your main ethernet adapter get restored.
This sadly only applies to IPv4 and not IPv6.
. 2024.09.10 19:26:07 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to 1.1.1.1, 1.0.0.1)
. 2024.09.10 19:26:07 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
It should set the IPv6 DNS setting back to cloudflare 2606:4700:4700::1111 & 2606:4700:4700::1001
I'm using Windows 11 23H2 (22631.4037) with Eddie-UI version 2.21.8
Can you check the current experimental 2.24.x, please?
It seems to work with the experimental version 2.24.2
. 2024.09.22 15:57:39 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to 9.9.9.9,149.112.112.112)
. 2024.09.22 15:57:39 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to 2620:fe::fe,2620:fe::9)
Do you recommend using the experimental version over the stable version?
Is there any disclaimer or security risk that might come when using the experimental version?
