petersday
Firewall Help
I need some firewall advice, I'm trying to block all internet access should the vpn go down, but still allow the vpn to connect.
Now I have read in the forums the recommended way of doing this is to use Comodo - but on my Windows 7 64bit machine it just does not install.
It gets to about 85% and then hangs. So I could really use some other 3rd party firewall alternative that works or a set of rules for the standard windows 7 firewall.
My own attempts at using the rules haven't been very successful - so I could really use some help please.
If you can't install comodo, something is fundamentally wrong with your win installation. You might want to fix that first anyhow.
