Hey guys I hope someone can actually help me 😕
whenever i try to connect to a server it keeps reconnecting to some other server and does that till it tried every server. Happens on Mac >Cata
Logs:
. 2024.08.02 22:00:15 - Eddie version: 2.21.8 / macos_x64, System: MacOS, Name: macOS 14.1, Version: 14.1 (Build 23B74), Mono/.Net: v4.0.30319
. 2024.08.02 22:00:16 - Raise system privileges
. 2024.08.02 22:00:21 - Reading options from /Users/epot/.config/eddie/default.profile
. 2024.08.02 22:00:22 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2024.08.02 22:00:22 - SSH - Version: OpenSSH_9.4p1, LibreSSL 3.3.6 (/usr/bin/ssh)
. 2024.08.02 22:00:22 - SSL - Version: Initializing (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2024.08.02 22:00:23 - Ready
. 2024.08.02 22:00:24 - Collect information about AirVPN completed
I 2024.08.02 22:00:29 - Session starting.
I 2024.08.02 22:00:29 - Checking authorization ...
! 2024.08.02 22:00:30 - Connecting to Algorab (Sweden, Uppsala)
. 2024.08.02 22:00:30 - Routes, add 62.102.148.198/32 for interface "en0".
. 2024.08.02 22:00:30 - Routes, add 62.102.148.198/32 for interface "en0", already exists.
. 2024.08.02 22:00:30 - OpenVPN > OpenVPN 2.5.5 arm-apple-darwin21.3.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Feb  8 2022
. 2024.08.02 22:00:30 - OpenVPN > library versions: OpenSSL 1.1.1k  25 Mar 2021, LZO 2.10
. 2024.08.02 22:00:30 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.08.02 22:00:30 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.08.02 22:00:30 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.08.02 22:00:30 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.08.02 22:00:30 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.198:443
. 2024.08.02 22:00:30 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2024.08.02 22:00:30 - OpenVPN > UDP link local: (not bound)
. 2024.08.02 22:00:30 - OpenVPN > UDP link remote: [AF_INET]
. 2024.08.02 22:00:30 - OpenVPN > TLS: Initial packet from [AF_INET], sid=c56e5c03 44a86c9f
. 2024.08.02 22:00:30 - OpenVPN > VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org, serial=10148936457887096835
. 2024.08.02 22:00:30 - OpenVPN > OpenSSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
. 2024.08.02 22:00:30 - OpenVPN > TLS_ERROR: BIO read tls_read_plaintext error
. 2024.08.02 22:00:30 - OpenVPN > TLS Error: TLS object -> incoming plaintext read error
. 2024.08.02 22:00:30 - OpenVPN > TLS Error: TLS handshake failed
. 2024.08.02 22:00:30 - OpenVPN > SIGUSR1[soft,tls-error] received, process restarting
. 2024.08.02 22:00:30 - OpenVPN > Restart pause, 5 second(s)
! 2024.08.02 22:00:30 - Disconnecting
. 2024.08.02 22:00:30 - Sending soft termination signal
. 2024.08.02 22:00:30 - OpenVPN > SIGINT[hard,init_instance] received, process exiting
. 2024.08.02 22:00:30 - Routes, delete  for interface "en0".
. 2024.08.02 22:00:31 - Routes, delete  for interface "en0", not exists.
. 2024.08.02 22:00:31 - Connection terminated.
I 2024.08.02 22:00:34 - Cancel requested.
! 2024.08.02 22:00:34 - Session terminated.
