AonH 0 Posted ... Hello everyone, I am using an Opnsense with an wg permtun tinto which specific external fqdns are routed. Everything works well, speed is also ok for these services. Due to the currently running EM I found the streaming service vavoo.to, on which many channels can be accessed by stream. Unfortunately no stream works anymore once the traffic runs through the airvpn wg tunnel. has anyone ever had finite problems or a solution? My Routing works fine only the service give out the error " The media could not be loaded, either because the server or network failed or because the format is not supported" on any OS (tested ios, debian, win). Quote Share this post Link to post
