Not connected, Your IP: 216.73.216.190
winterdj
Musicbrainz.org unable to connect when connected to AirVPN
4 hours ago, winterdj said:
Update: Apologies, I think I should have posted this in "Blocked websites warning"
Moved. :)
Many thanks for moving the post.
So when I'm connected to AirVPN, I get the following SSL issue:
% curl -I 'https://picard.musicbrainz.org/api/v2/releases/'
curl: (35) LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to picard.musicbrainz.org:443
And when not connected to AirVPN, a standard correct response:
HTTP/2 200
server: openresty
date: Wed, 01 May 2024 06:35:39 GMT
content-type: application/json
content-length: 1939
vary: Accept-Encoding
The issue came up for me when Jellyfin was trying to scan my MP3 library to add meta data, which uses Musicbrainz.
