lococola
[SOLVED] Docker connection to AirVPN not working - certificate expired
So I read up on the certificate issues and managed to get Eddie working using the suggested workaround. But I am also running PrivoxyVPN on my Unraid box which connects to AirVPN, and this one is still throwing errors:
VERIFY ERROR: depth=1, error=certificate has expired: C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org,
I did already go to Client Area -> VPN settings and did Renew. This solved the problem for Eddie. But is there anything else I can do to fix it for my Docker container?
EDIT: Solved. Needed to generate a new ovpn file and put that in the Docker's config folder, replacing the old file. All working again.
