donald_duck
DNS Leaks
Auto solved.
If you have the same problem, You can follow this guide:
Click Start, click Network, click Network and Sharing Center, and then click Manage Network Connections (or Change Adapter Settings).
Press the ALT key, click Advanced (or from Organize->Layout enable menu bar) , and then click Advanced Settings. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click the Adapters and Bindings tab, and then, VPN connection.
Now, if you do a dnslookup PC will use airvpn dns.
Bye
