pasternyk 0 Posted ... (edited) hello i am new to vpns I have a quite powerful pc under windows 10 64 bits. I use wireguard configured to choose only the Nederland servers but eddie fails to connect. The status is either connecting to or disconnected. It lasts for 20 minutes. I don't know what to do. How configure qbitorrent eiher with the mapping thing. Is it possible to watch hbo for example with a vpn? Among others questions here are the logs . 2024.04.02 18:22:18 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.22621.0, Mono/.Net: v4.0.30319 . 2024.04.02 18:22:18 - Command line arguments (1): path="home" . 2024.04.02 18:22:19 - Reading options from C:\Users\tonio\AppData\Local\Eddie\default.profile . 2024.04.02 18:22:20 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2024.04.02 18:22:20 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe) . 2024.04.02 18:22:20 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe) I 2024.04.02 18:22:20 - Ready . 2024.04.02 18:22:21 - Collect information about AirVPN completed I 2024.04.02 18:22:22 - Session starting. I 2024.04.02 18:22:22 - Checking authorization ... . 2024.04.02 18:22:23 - Added new network interface "Eddie", Wintun version 0.12 . 2024.04.02 18:22:23 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:22:23 - Connecting to Atik (Netherlands, Alblasserdam) . 2024.04.02 18:22:23 - Routes, add 213.152.161.12/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:22:24 - Routes, add 213.152.161.12/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:22:24 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:22:24 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:22:24 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:22:24 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:22:24 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:22:24 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:22:24 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:22:24 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.12:443 . 2024.04.02 18:22:24 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:22:24 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:22:24 - OpenVPN > UDP link remote: [AF_INET]213.152.161.12:443 . 2024.04.02 18:22:56 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:22:56 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:23:02 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:23:02 - Disconnecting . 2024.04.02 18:23:02 - Routes, delete 213.152.161.12/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:23:02 - Routes, delete 213.152.161.12/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:23:02 - Connection terminated. I 2024.04.02 18:23:05 - Checking authorization ... . 2024.04.02 18:23:06 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:23:06 - Connecting to Caph (Netherlands, Alblasserdam) . 2024.04.02 18:23:06 - Routes, add 213.152.162.172/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:23:06 - Routes, add 213.152.162.172/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:23:06 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:23:06 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:23:06 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:23:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:23:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:23:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:23:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:23:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.172:443 . 2024.04.02 18:23:06 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:23:06 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:23:06 - OpenVPN > UDP link remote: [AF_INET]213.152.162.172:443 . 2024.04.02 18:23:39 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:23:39 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:23:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:23:43 - Disconnecting . 2024.04.02 18:23:43 - Routes, delete 213.152.162.172/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:23:43 - Routes, delete 213.152.162.172/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:23:43 - Connection terminated. I 2024.04.02 18:23:46 - Checking authorization ... . 2024.04.02 18:23:47 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:23:47 - Connecting to Hassaleh (Netherlands, Alblasserdam) . 2024.04.02 18:23:47 - Routes, add 213.152.161.42/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:23:47 - Routes, add 213.152.161.42/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:23:47 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:23:47 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:23:47 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:23:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:23:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:23:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:23:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:23:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.42:443 . 2024.04.02 18:23:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:23:47 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:23:47 - OpenVPN > UDP link remote: [AF_INET]213.152.161.42:443 . 2024.04.02 18:24:20 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:24:20 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:24:25 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:24:25 - Disconnecting . 2024.04.02 18:24:25 - Routes, delete 213.152.161.42/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:24:25 - Routes, delete 213.152.161.42/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:24:25 - Connection terminated. I 2024.04.02 18:24:28 - Checking authorization ... . 2024.04.02 18:24:29 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:24:29 - Connecting to Horologium (Netherlands, Alblasserdam) . 2024.04.02 18:24:29 - Routes, add 213.152.162.7/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:24:29 - Routes, add 213.152.162.7/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:24:29 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:24:29 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:24:29 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:24:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:24:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:24:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:24:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:24:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.7:443 . 2024.04.02 18:24:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:24:29 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:24:29 - OpenVPN > UDP link remote: [AF_INET]213.152.162.7:443 . 2024.04.02 18:25:02 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:25:02 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:25:06 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:25:06 - Disconnecting . 2024.04.02 18:25:07 - Routes, delete 213.152.162.7/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:25:07 - Routes, delete 213.152.162.7/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:25:07 - Connection terminated. I 2024.04.02 18:25:10 - Checking authorization ... . 2024.04.02 18:25:10 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:25:10 - Connecting to Menkent (Netherlands, Alblasserdam) . 2024.04.02 18:25:10 - Routes, add 213.152.176.140/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:25:10 - Routes, add 213.152.176.140/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:25:11 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:25:11 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:25:11 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:25:11 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:25:11 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:25:11 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:25:11 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:25:11 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.176.140:443 . 2024.04.02 18:25:11 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:25:11 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:25:11 - OpenVPN > UDP link remote: [AF_INET]213.152.176.140:443 . 2024.04.02 18:25:43 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:25:43 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:25:47 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:25:47 - Disconnecting . 2024.04.02 18:25:47 - Routes, delete 213.152.176.140/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:25:47 - Routes, delete 213.152.176.140/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:25:47 - Connection terminated. I 2024.04.02 18:25:50 - Checking authorization ... . 2024.04.02 18:25:51 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:25:51 - Connecting to Edasich (Netherlands, Alblasserdam) . 2024.04.02 18:25:51 - Routes, add 213.152.161.213/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:25:51 - Routes, add 213.152.161.213/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:25:51 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:25:51 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:25:51 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:25:51 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:25:51 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:25:51 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:25:51 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:25:51 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.213:443 . 2024.04.02 18:25:51 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:25:51 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:25:51 - OpenVPN > UDP link remote: [AF_INET]213.152.161.213:443 . 2024.04.02 18:26:24 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:26:24 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:26:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:26:28 - Disconnecting . 2024.04.02 18:26:29 - Routes, delete 213.152.161.213/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:26:29 - Routes, delete 213.152.161.213/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:26:29 - Connection terminated. I 2024.04.02 18:26:32 - Checking authorization ... . 2024.04.02 18:26:32 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:26:32 - Connecting to Orion (Netherlands, Alblasserdam) . 2024.04.02 18:26:32 - Routes, add 213.152.161.241/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:26:33 - Routes, add 213.152.161.241/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:26:33 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:26:33 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:26:33 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:26:33 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:26:33 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:26:33 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:26:33 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:26:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.241:443 . 2024.04.02 18:26:33 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:26:33 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:26:33 - OpenVPN > UDP link remote: [AF_INET]213.152.161.241:443 . 2024.04.02 18:27:05 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:27:05 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:27:09 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:27:09 - Disconnecting . 2024.04.02 18:27:09 - Routes, delete 213.152.161.241/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:27:10 - Routes, delete 213.152.161.241/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:27:10 - Connection terminated. I 2024.04.02 18:27:13 - Checking authorization ... . 2024.04.02 18:27:13 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:27:13 - Connecting to Cygnus (Netherlands, Alblasserdam) . 2024.04.02 18:27:13 - Routes, add 213.152.161.246/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:27:13 - Routes, add 213.152.161.246/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:27:14 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:27:14 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:27:14 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:27:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:27:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:27:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:27:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:27:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.246:443 . 2024.04.02 18:27:14 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:27:14 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:27:14 - OpenVPN > UDP link remote: [AF_INET]213.152.161.246:443 . 2024.04.02 18:27:46 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:27:46 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:27:51 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:27:51 - Disconnecting . 2024.04.02 18:27:51 - Routes, delete 213.152.161.246/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:27:51 - Routes, delete 213.152.161.246/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:27:51 - Connection terminated. I 2024.04.02 18:27:54 - Checking authorization ... . 2024.04.02 18:27:55 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:27:55 - Connecting to Gianfar (Netherlands, Alblasserdam) . 2024.04.02 18:27:55 - Routes, add 213.152.161.103/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:27:55 - Routes, add 213.152.161.103/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:27:55 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:27:55 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:27:55 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:27:55 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:27:55 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:27:55 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:27:55 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:27:55 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.103:443 . 2024.04.02 18:27:55 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:27:55 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:27:55 - OpenVPN > UDP link remote: [AF_INET]213.152.161.103:443 . 2024.04.02 18:28:28 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:28:28 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:28:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:28:32 - Disconnecting . 2024.04.02 18:28:32 - Routes, delete 213.152.161.103/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:28:32 - Routes, delete 213.152.161.103/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:28:32 - Connection terminated. I 2024.04.02 18:28:35 - Checking authorization ... . 2024.04.02 18:28:36 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:28:36 - Connecting to Miram (Netherlands, Alblasserdam) . 2024.04.02 18:28:36 - Routes, add 213.152.162.91/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:28:36 - Routes, add 213.152.162.91/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:28:36 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:28:36 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:28:36 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:28:36 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:28:36 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:28:36 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:28:36 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:28:36 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.91:443 . 2024.04.02 18:28:36 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:28:36 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:28:36 - OpenVPN > UDP link remote: [AF_INET]213.152.162.91:443 . 2024.04.02 18:29:08 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:29:08 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:29:14 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:29:14 - Disconnecting . 2024.04.02 18:29:14 - Routes, delete 213.152.162.91/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:29:14 - Routes, delete 213.152.162.91/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:29:14 - Connection terminated. I 2024.04.02 18:29:18 - Checking authorization ... . 2024.04.02 18:29:18 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2024.04.02 18:29:18 - Connecting to Comae (Netherlands, Alblasserdam) . 2024.04.02 18:29:18 - Routes, add 213.152.186.165/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:29:18 - Routes, add 213.152.186.165/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", already exists. . 2024.04.02 18:29:18 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2024.04.02 18:29:18 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2024.04.02 18:29:18 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2024.04.02 18:29:18 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:29:18 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:29:18 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2024.04.02 18:29:18 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2024.04.02 18:29:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.186.165:443 . 2024.04.02 18:29:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2024.04.02 18:29:18 - OpenVPN > UDP link local: (not bound) . 2024.04.02 18:29:18 - OpenVPN > UDP link remote: [AF_INET]213.152.186.165:443 . 2024.04.02 18:29:50 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2024.04.02 18:29:50 - OpenVPN > SIGTERM received, sending exit notification to peer . 2024.04.02 18:29:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2024.04.02 18:29:55 - Disconnecting . 2024.04.02 18:29:55 - Routes, delete 213.152.186.165/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)". . 2024.04.02 18:29:56 - Routes, delete 213.152.186.165/32 for interface "Ethernet (Realtek PCIe GbE Family Controller)", not exists. . 2024.04.02 18:29:56 - Connection terminated. Edited ... by OpenSourcerer Apply LOG format to logs Quote Share this post Link to post
Tech Jedi Alex 1518 Posted ... On 4/2/2024 at 5:52 PM, pasternyk said: I use wireguard configured to choose only the Nederland servers but eddie fails to connect Your logs don't back up that claim. It's exclusively using OpenVPN. Can you check? On 4/2/2024 at 5:52 PM, pasternyk said: . 2024.04.02 18:29:50 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting It suggests that UDP is getting blocked. Can you check in the router? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
