Not connected, Your IP: 18.227.52.111
Airvpn123456789123456789
Slow speeds while using AirVPN with qBittorrent
While using AirVPN with qBittorrent I see slow speeds with torrents, once I disable AirVPN my speeds go back to normal. To clarify I'm hitting at most 100-300 Kib/s while using AirVPN, 100+Mib/s without AirVPN on the same torrent. So far I have set my Protocol to Wireguard "official wireguard port", I've tried several servers but experience the same speeds between them all. In qBittorrent I have bound the network interface to "Eddie", I also entered the forwarded port AirVPN provided me with in qBittorrent>Connection>Port used for incoming connections. I'm not sure if that is the right spot to put the forwarded port. I'm looking for a guide or if anybody knows specific settings I'm needing to change to get AirVPN working properly with qBittorrent. I've searched google and these forums but I see a lot of dated and contradicting information on what settings I should change.
