Not connected, Your IP: 216.73.216.245
ainisw99
encounter a problem:VPN Over proxy
I'm using air through a proxy on my phone
I use a proxy software called "Clash"on my Android phone
I noticed that Air uses HTTP as the proxy protocol
Clash listens at 127.0.0.1. The listening port for HTTP is 7890
So, I put 127.0.0.1 in the Air server host line,server port 7890
I picked Clash in air split tunnel.The goal is for clash traffic data not to be routed through the VPN
Connection successful , Air main screen shows TCPv4 via HTTP. I conducted a leak test and the test results showed no leaks.
But I'm having a problem with Air disconnecting every once in a while (many times a few minutes),
If I'm constantly using traffic, such as watching a video, then the VPN connection time maybe stays longer
I check the Air logs,The most frequent occurrence is:
Keep Alive timeout:session termination.restart in 2000ms........ Another scenario is that the VPN disconnects and then turns on the locking.
Clash is connected
What should I do to fix this?
