Notworking
ANSWERED connect & disconnected same config file
hi,
there is any way to use the same connection in two+ devices?
i'm trying to connect 2 devices using the same config file generated by config generator but that causes them to be disconnected and connected.
That happens only if you use the same key pair/device on the same server, using same protocol and port. Then naturally the older connection will be killed.
What do you really want to do?
