Lao8
Anyone using AirVPN well in China?
I just simply chose recommended server. It keeps connecting different servers but never succeeded. Is AirVPN working well in China now? Thanks folks
There are a couple of China-related threads already - did you search for them? You did not mention how you connect (protocol? port? ...). One config you may try has been posted here:
Thank you for reply! I was trying on PC desktop. Just using Eddie-UI, successfully logged in, and [connected to a recommended server], won't work at all...
Try the following:
Do not use recommended server for this type of problem.
Under protocols:
Choose OpenVPN TCP port 443 entry IP3
Does it work?
15 hours ago, Television said:
Try the following:
Under protocols:
Does it work?
no still not working...
On 10/25/2023 at 1:31 PM, Lao8 said:
Just using Eddie-UI
Where are the logs from Eddie? Please send your logs from Eddie to Staff if you are not "comfy" posting them in the forum. Then we'll see what's "frisky".
