chhpv
AsusMerlin 386.12 RT-AC88U I can't connect help
I can't connect tried all configurations writes constant Error - check configuration!
Oct  5 21:18:30 rc_service: httpd 415:notify_rc start_vpnclient1
Oct  5 21:18:31 ovpn-client1[17859]: OpenVPN 2.6.6 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Oct  5 21:18:31 ovpn-client1[17859]: library versions: OpenSSL 1.1.1u  30 May 2023, LZO 2.08
Oct  5 21:18:31 ovpn-client1[17860]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct  5 21:18:31 ovpn-client1[17860]: TCP/UDP: Preserving recently used remote address: [AF_INET]185.200.116.221:443
Oct  5 21:18:31 ovpn-client1[17860]: Socket Buffers: R=[87380->87380] S=[16384->16384]
Oct  5 21:18:31 ovpn-client1[17860]: Attempting to establish TCP connection with [AF_INET]185.200.116.221:443
Oct  5 21:18:31 ovpn-client1[17860]: TCP connection established with [AF_INET]185.200.116.221:443
Oct  5 21:18:31 ovpn-client1[17860]: TCPv4_CLIENT link local: (not bound)
Oct  5 21:18:31 ovpn-client1[17860]: TCPv4_CLIENT link remote: [AF_INET]185.200.116.221:443
Oct  5 21:18:32 ovpn-client1[17860]: TLS: Initial packet from [AF_INET]185.200.116.221:443, sid=77704483 3c6808a1
Oct  5 21:18:33 ovpn-client1[17860]: VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Oct  5 21:18:33 ovpn-client1[17860]: VERIFY KU OK
Oct  5 21:18:33 ovpn-client1[17860]: Validating certificate extended key usage
Oct  5 21:18:33 ovpn-client1[17860]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Oct  5 21:18:33 ovpn-client1[17860]: VERIFY EKU OK
Oct  5 21:18:33 ovpn-client1[17860]: VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Delphinus, emailAddress=info@airvpn.org
Oct  5 21:18:34 ovpn-client1[17860]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Oct  5 21:18:34 ovpn-client1[17860]: [Delphinus] Peer Connection Initiated with [AF_INET]185.200.116.221:443
Oct  5 21:18:34 ovpn-client1[17860]: TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
Oct  5 21:18:34 ovpn-client1[17860]: TLS: tls_multi_process: initial untrusted session promoted to trusted
Oct  5 21:18:35 ovpn-client1[17860]: SENT CONTROL [Delphinus]: 'PUSH_REQUEST' (status=1)
Oct  5 21:18:35 ovpn-client1[17860]: PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.15.83.1,dhcp-option DNS6 fde6:7a:7d20:b53::1,tun-ipv6,route-gateway 10.15.83.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:b53::107d/64 fde6:7a:7d20:b53::1,ifconfig 10.15.83.127 255.255.255.0,peer-id 0,cipher CHACHA20-POLY1305'
Oct  5 21:18:35 ovpn-client1[17860]: OPTIONS IMPORT: --ifconfig/up options modified
Oct  5 21:18:35 ovpn-client1[17860]: OPTIONS IMPORT: route options modified
Oct  5 21:18:35 ovpn-client1[17860]: OPTIONS IMPORT: route-related options modified
Oct  5 21:18:35 ovpn-client1[17860]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Oct  5 21:18:35 ovpn-client1[17860]: GDG6: remote_host_ipv6=n/a
Oct  5 21:18:35 ovpn-client1[17860]: net_route_v6_best_gw query: dst ::
Oct  5 21:18:35 ovpn-client1[17860]: net_route_v6_best_gw result: via :: dev lo
Oct  5 21:18:35 ovpn-client1[17860]: TUN/TAP device tun11 opened
Oct  5 21:18:35 ovpn-client1[17860]: TUN/TAP TX queue length set to 1000
Oct  5 21:18:35 ovpn-client1[17860]: /usr/sbin/ip link set dev tun11 up mtu 1500
Oct  5 21:18:35 ovpn-client1[17860]: /usr/sbin/ip addr add dev tun11 10.15.83.127/24
Oct  5 21:18:35 ovpn-client1[17860]: Linux ip addr add failed: external program exited with error status: 2
Oct  5 21:18:35 ovpn-client1[17860]: Exiting due to fatal error
6:36 ovpn-client2[7769]: TCPv4_CLIENT link remote: [AF_INET]194.187.251.157:443
Oct  5 23:46:36 ovpn-client2[7769]: TLS: Initial packet from [AF_INET]194.187.251.157:443, sid=32ea2dfd 17b16432
Oct  5 23:46:36 ovpn-client2[7769]: VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Oct  5 23:46:36 ovpn-client2[7769]: VERIFY KU OK
Oct  5 23:46:36 ovpn-client2[7769]: Validating certificate extended key usage
Oct  5 23:46:36 ovpn-client2[7769]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Oct  5 23:46:36 ovpn-client2[7769]: VERIFY EKU OK
Oct  5 23:46:36 ovpn-client2[7769]: VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Mebsuta, emailAddress=info@airvpn.org
Oct  5 23:46:36 ovpn-client2[7769]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Oct  5 23:46:36 ovpn-client2[7769]: [Mebsuta] Peer Connection Initiated with [AF_INET]194.187.251.157:443
Oct  5 23:46:36 ovpn-client2[7769]: TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
Oct  5 23:46:36 ovpn-client2[7769]: TLS: tls_multi_process: initial untrusted session promoted to trusted
Oct  5 23:46:37 ovpn-client1[8153]: Connection reset, restarting [0]
Oct  5 23:46:37 ovpn-client1[8153]: SIGUSR1[soft,connection-reset] received, process restarting
Oct  5 23:46:37 ovpn-client1[8153]: Restart pause, 1 second(s)
Oct  5 23:46:37 ovpn-client2[7769]: SENT CONTROL [Mebsuta]: 'PUSH_REQUEST' (status=1)
Oct  5 23:46:37 ovpn-client2[7769]: PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.21.147.1,route-gateway 10.21.147.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.21.147.96 255.255.255.0,peer-id 0,cipher CHACHA20-POLY1305'
Oct  5 23:46:37 ovpn-client2[7769]: OPTIONS IMPORT: --ifconfig/up options modified
Oct  5 23:46:37 ovpn-client2[7769]: OPTIONS IMPORT: route options modified
Oct  5 23:46:37 ovpn-client2[7769]: OPTIONS IMPORT: route-related options modified
Oct  5 23:46:37 ovpn-client2[7769]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Oct  5 23:46:37 ovpn-client2[7769]: Preserving previous TUN/TAP instance: tun12
Oct  5 23:46:37 ovpn-client2[7769]: Initialization Sequence Completed
Oct  5 23:46:37 ovpn-client2[7769]: Data Channel: cipher 'CHACHA20-POLY1305', peer-id: 0, compression: 'stub'
Oct  5 23:46:37 ovpn-client2[7769]: Timers: ping 10, ping-restart 60
Oct  5 23:46:38 ovpn-client1[8153]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct  5 23:46:38 ovpn-client1[8153]: TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.157:443
Oct  5 23:46:38 ovpn-client1[8153]: Socket Buffers: R=[87380->87380] S=[16384->16384]
Oct  5 23:46:38 ovpn-client1[8153]: Attempting to establish TCP connection with [AF_INET]194.187.251.157:443
Oct  5 23:46:38 ovpn-client1[8153]: TCP connection established with [AF_INET]194.187.251.157:443
Oct  5 23:46:38 ovpn-client1[8153]: TCPv4_CLIENT link local: (not bound)
Oct  5 23:46:38 ovpn-client1[8153]: TCPv4_CLIENT link remote: [AF_INET]194.187.251.157:443
Oct  5 23:46:38 ovpn-client1[8153]: TLS: Initial packet from [AF_INET]194.187.251.157:443, sid=82a55bf2 9d86db5b
Oct  5 23:46:38 ovpn-client1[8153]: VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Oct  5 23:46:38 ovpn-client1[8153]: VERIFY KU OK
Oct  5 23:46:38 ovpn-client1[8153]: Validating certificate extended key usage
Oct  5 23:46:38 ovpn-client1[8153]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Oct  5 23:46:38 ovpn-client1[8153]: VERIFY EKU OK
Oct  5 23:46:38 ovpn-client1[8153]: VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Mebsuta, emailAddress=info@airvpn.org
Oct  5 23:46:38 ovpn-client1[8153]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Oct  5 23:46:38 ovpn-client1[8153]: [Mebsuta] Peer Connection Initiated with [AF_INET]194.187.251.157:443
Oct  5 23:46:38 ovpn-client1[8153]: TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
Oct  5 23:46:38 ovpn-client1[8153]: TLS: tls_multi_process: initial untrusted session promoted to trusted
Oct  5 23:46:38 ovpn-client2[7769]: Connection reset, restarting [0]
Oct  5 23:46:38 ovpn-client2[7769]: SIGUSR1[soft,connection-reset] received, process restarting
Oct  5 23:46:38 ovpn-client2[7769]: Restart pause, 1 second(s)
Oct  5 23:46:38 ovpn-client1[8153]: PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.21.147.1,route-gateway 10.21.147.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.21.147.96 255.255.255.0,peer-id 0,cipher CHACHA20-POLY1305'
Oct  5 23:46:38 ovpn-client1[8153]: OPTIONS IMPORT: --ifconfig/up options modified
Oct  5 23:46:38 ovpn-client1[8153]: OPTIONS IMPORT: route options modified
Oct  5 23:46:38 ovpn-client1[8153]: OPTIONS IMPORT: route-related options modified
Oct  5 23:46:38 ovpn-client1[8153]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Oct  5 23:46:38 ovpn-client1[8153]: Preserving previous TUN/TAP instance: tun11
Oct  5 23:46:38 ovpn-client1[8153]: Initialization Sequence Completed
Oct  5 23:46:38 ovpn-client1[8153]: Data Channel: cipher 'CHACHA20-POLY1305', peer-id: 0, compression: 'stub'
Oct  5 23:46:38 ovpn-client1[8153]: Timers: ping 10, ping-restart 60
Oct  5 23:46:39 ovpn-client2[7769]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct  5 23:46:39 ovpn-client2[7769]: TCP/UDP: Preserving recently used remote address: [AF_INET]194.187.251.157:443
Oct  5 23:46:39 ovpn-client2[7769]: Socket Buffers: R=[87380->87380] S=[16384->16384]
Oct  5 23:46:39 ovpn-client2[7769]: Attempting to establish TCP connection with [AF_INET]194.187.251.157:443
Oct  5 23:46:39 ovpn-client2[7769]: TCP connection established with [AF_INET]194.187.251.157:443
Oct  5 23:46:39 ovpn-client2[7769]: TCPv4_CLIENT link local: (not bound)
Oct  5 23:46:39 ovpn-client2[7769]: TCPv4_CLIENT link remote: [AF_INET]194.187.251.157:443
Oct  5 23:46:39 ovpn-client2[7769]: TLS: Initial packet from [AF_INET]194.187.251.157:443, sid=7f41c06b 615acd7b
Oct  5 23:46:40 ovpn-client2[7769]: VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Oct  5 23:46:40 ovpn-client2[7769]: VERIFY KU OK
Oct  5 23:46:40 ovpn-client2[7769]: Validating certificate extended key usage
Oct  5 23:46:40 ovpn-client2[7769]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Oct  5 23:46:40 ovpn-client2[7769]: VERIFY EKU OK
Oct  5 23:46:40 ovpn-client2[7769]: VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Mebsuta, emailAddress=info@airvpn.org
Edited ... by chhpv
you are better off asking the AsusMerlin site and use the config generator located on this site.
i dont have this firmware but you can try this:
