vizard82
ANSWERED Help with DIETPI (debian-based linux) + EDDI-CLI
Hello guys,
I'm new on linux and I'm trying to set-up AIRVPN on DietPi (a Debian-based headless distro optimized for SBC PC as RASPBERRY).
I've installed EDDI-CLI, and run the following  command :
eddie-cli -login=XXXXXXXXX -password=XXXXXXXXX -netlock -key=XXXXXXXXX -connect -areas.allowlist=ch -mode.type=openvpn
It connected to a than AIRVPN server without problem. Than I tested QBITTORRENT on IPLEAK.NET if it works as intended, but there's something strange.
As you can see in the attached image, IPLEAK show AIRVPN's IP + my IP.
I think I messed in the CLI-command
Best regards
Please provide logs from a full connection attempt.
Also, bind qB to the tunnel interface tun0. It's in qB settings > Advanced > Network interface.
It was that setting in qB. Now it seems to work as intended.
Thanks a lot!
