Not connected, Your IP: 216.73.216.190
Mesolem
No connect
Hello
I've had the problem I'm having for a few days now
No German server can access the Premium.to and Premiumize.me pages. Only the German servers are affected. After a few tests, I found that it is due to your DNS server.
other servers work.
Have you tried using German servers with google DNS, just to test and make sure it's the DNS resolver at the German VPN server side to blame?
Hm. It's because some authoritative DNS resolvers see many many DNS requests coming from the AirVPN server Exit IP address (this is normal).
It's a shared IP between all the AirVPN users using that server at that given time.
Because they don't whitelist it as a "high traffic DNS requestor source" it's the effect you get.
Google Public DNS works no different but because the IP addresses are whitelisted in a way that are known to send a lot of requests and also might use caching in other way than AirVPN resolvers do (since they are not projected for privacy first, like AirVPN servers are).
