Any way to bypass DPI block without using SSL and SSH protocols in Eddie client? OpenVPN and Wireguard UDP/TCP protocols are completely blocked, can't connect to any of them. I mainly use VPN for gaming, and SSL/SSH protocols are too slow for that.
Any solutions without having to use Eddie also work, but I'm quite a noob here about all this VPN stuff.
The DPI block can be quite nasty in some situations yes. But how is SSL entirely blocked, this means you cannot access any https page regardless?
You could use a obfs bridge + Tor and connect to OpenVPN via Tor's socks5, but I don't know how goo this will be for gaming, it could be much slower than what AirVPN can support / provide you if you connect directly.
Are you sure the TCP/UDP protocols of WireGuard and OpenVPN are blocked really, and it's not just some DNS blacklist that does not resolve entry addresses for AirVPN servers?
