SobakaBaskov
ANSWERED Eddie stopped connecting today. Yesterday everything was fine, no changes to settings or updates were made
I 2023.08.07 08:14:32 - Session starting.
I 2023.08.07 08:14:33 - Checking authorization ...
. 2023.08.07 08:14:34 - Added new network interface "eddie", Wintun version 0.14
. 2023.08.07 08:14:34 - Using WinTun network interface "eddie (Wintun Userspace Tunnel)"
. 2023.08.07 08:14:34 - IPv6 disabled with packet filtering.
! 2023.08.07 08:14:34 - Connecting to Fomalhaut (Norway, Oslo)
. 2023.08.07 08:14:34 - Routes, add 185.206.225.53/32 for interface "Ethernet (Remote NDIS based Internet Sharing Device)".
. 2023.08.07 08:14:34 - Routes, add 185.206.225.53/32 for interface "Ethernet (Remote NDIS based Internet Sharing Device)", already exists.
. 2023.08.07 08:14:34 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.08.07 08:14:34 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.08.07 08:14:34 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.08.07 08:14:34 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.08.07 08:14:34 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.08.07 08:14:34 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.08.07 08:14:34 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.08.07 08:14:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.206.225.53:443
. 2023.08.07 08:14:34 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.08.07 08:14:34 - OpenVPN > UDP link local: (not bound)
. 2023.08.07 08:14:34 - OpenVPN > UDP link remote: [AF_INET]185.206.225.53:443
. 2023.08.07 08:14:34 - OpenVPN > TLS: Initial packet from [AF_INET]185.206.225.53:443, sid=d75e321a 61af3230
. 2023.08.07 08:14:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.08.07 08:14:35 - OpenVPN > VERIFY KU OK
. 2023.08.07 08:14:35 - OpenVPN > Validating certificate extended key usage
. 2023.08.07 08:14:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.08.07 08:14:35 - OpenVPN > VERIFY EKU OK
. 2023.08.07 08:14:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Fomalhaut, emailAddress=info@airvpn.org
. 2023.08.07 08:14:35 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.08.07 08:14:35 - OpenVPN > [Fomalhaut] Peer Connection Initiated with [AF_INET]185.206.225.53:443
. 2023.08.07 08:14:35 - OpenVPN > SENT CONTROL [Fomalhaut]: 'PUSH_REQUEST' (status=1)
. 2023.08.07 08:14:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.16.246.1,dhcp-option DNS6 fde6:7a:7d20:cf6::1,tun-ipv6,route-gateway 10.16.246.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:cf6::1061/64 fde6:7a:7d20:cf6::1,ifconfig 10.16.246.99 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2023.08.07 08:14:35 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.08.07 08:14:35 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.16.246.1'
. 2023.08.07 08:14:35 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:cf6::1'
. 2023.08.07 08:14:35 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2023.08.07 08:14:35 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:cf6::1061/64 fde6:7a:7d20:cf6::1'
. 2023.08.07 08:14:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.08.07 08:14:35 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.08.07 08:14:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.08.07 08:14:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.08.07 08:14:35 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.08.07 08:14:35 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.08.07 08:14:35 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.08.07 08:14:35 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.08.07 08:14:35 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.08.07 08:14:35 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.08.07 08:14:35 - OpenVPN > interactive service msg_channel=0
. 2023.08.07 08:14:35 - OpenVPN > open_tun
. 2023.08.07 08:14:35 - OpenVPN > wintun device [eddie] opened
. 2023.08.07 08:14:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 44 static 10.16.246.99 255.255.255.0
. 2023.08.07 08:14:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 44 all
. 2023.08.07 08:14:35 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 44 all
. 2023.08.07 08:14:35 - OpenVPN > IPv4 MTU set to 1500 on interface 44 using SetIpInterfaceEntry()
. 2023.08.07 08:14:35 - OpenVPN > Initialization Sequence Completed
. 2023.08.07 08:14:35 - Interface eddie metric changed from Automatic to 3, layer IPv4
. 2023.08.07 08:14:35 - Interface eddie metric changed from Automatic to 3, layer IPv6
. 2023.08.07 08:14:36 - Routes, add 0.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:14:36 - Routes, add 128.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:14:36 - Routes, add 185.206.225.51/32 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:14:36 - Routes, skipped for 2001:ac8:38:3:7b25:8919:4d97:4e23 : IPv6 blocked.
. 2023.08.07 08:14:36 - Flushing DNS
I 2023.08.07 08:14:36 - Checking route IPv4
. 2023.08.07 08:15:03 - Checking route (4° try)
. 2023.08.07 08:15:28 - Checking route (5° try)
E 2023.08.07 08:15:49 - Checking route IPv4 failed, last reason: Fetch url error:Timeout was reached
. 2023.08.07 08:15:49 - OpenVPN > [Fomalhaut] Inactivity timeout (--ping-restart), restarting
. 2023.08.07 08:15:49 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2023.08.07 08:15:49 - OpenVPN > Restart pause, 5 second(s)
. 2023.08.07 08:15:49 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.08.07 08:15:49 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.08.07 08:15:49 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.08.07 08:15:49 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.08.07 08:15:49 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.206.225.53:443
. 2023.08.07 08:15:49 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.08.07 08:15:49 - OpenVPN > UDP link local: (not bound)
. 2023.08.07 08:15:49 - OpenVPN > UDP link remote: [AF_INET]185.206.225.53:443
. 2023.08.07 08:15:49 - OpenVPN > TLS: Initial packet from [AF_INET]185.206.225.53:443, sid=93049483 d8e6758a
. 2023.08.07 08:15:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.08.07 08:15:49 - OpenVPN > VERIFY KU OK
. 2023.08.07 08:15:49 - OpenVPN > Validating certificate extended key usage
. 2023.08.07 08:15:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.08.07 08:15:49 - OpenVPN > VERIFY EKU OK
. 2023.08.07 08:15:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Fomalhaut, emailAddress=info@airvpn.org
. 2023.08.07 08:15:49 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.08.07 08:15:49 - OpenVPN > [Fomalhaut] Peer Connection Initiated with [AF_INET]185.206.225.53:443
. 2023.08.07 08:15:49 - OpenVPN > SENT CONTROL [Fomalhaut]: 'PUSH_REQUEST' (status=1)
. 2023.08.07 08:15:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.16.246.1,dhcp-option DNS6 fde6:7a:7d20:cf6::1,tun-ipv6,route-gateway 10.16.246.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:cf6::1061/64 fde6:7a:7d20:cf6::1,ifconfig 10.16.246.99 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2023.08.07 08:15:49 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.08.07 08:15:49 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.16.246.1'
. 2023.08.07 08:15:49 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:cf6::1'
. 2023.08.07 08:15:49 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2023.08.07 08:15:49 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:cf6::1061/64 fde6:7a:7d20:cf6::1'
. 2023.08.07 08:15:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.08.07 08:15:49 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.08.07 08:15:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.08.07 08:15:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.08.07 08:15:49 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.08.07 08:15:49 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.08.07 08:15:49 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.08.07 08:15:49 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.08.07 08:15:49 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.08.07 08:15:49 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.08.07 08:15:49 - OpenVPN > Preserving previous TUN/TAP instance: eddie
. 2023.08.07 08:15:49 - OpenVPN > Initialization Sequence Completed
. 2023.08.07 08:15:50 - Routes, add 0.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)", already exists.
. 2023.08.07 08:15:50 - Routes, add 128.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)", already exists.
. 2023.08.07 08:15:50 - Routes, add 185.206.225.51/32 for interface "eddie (Wintun Userspace Tunnel)", already exists.
. 2023.08.07 08:15:50 - Routes, skipped for 2001:ac8:38:3:7b25:8919:4d97:4e23 : IPv6 blocked.
. 2023.08.07 08:15:50 - Flushing DNS
! 2023.08.07 08:15:50 - Disconnecting
. 2023.08.07 08:15:50 - Sending soft termination signal
. 2023.08.07 08:15:53 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.08.07 08:15:55 - OpenVPN > Closing TUN/TAP interface
. 2023.08.07 08:15:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 44 10.16.246.99 store=active
. 2023.08.07 08:15:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.08.07 08:15:55 - Routes, delete 0.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:15:55 - Routes, delete 128.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:15:55 - Routes, delete 185.206.225.53/32 for interface "Ethernet (Remote NDIS based Internet Sharing Device)".
. 2023.08.07 08:15:55 - Routes, delete 185.206.225.51/32 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:15:55 - Routes, skipped for 2001:ac8:38:3:7b25:8919:4d97:4e23 : IPv6 blocked.
. 2023.08.07 08:15:55 - Routes, delete 185.206.225.53/32 for interface "Ethernet (Remote NDIS based Internet Sharing Device)", not exists.
. 2023.08.07 08:15:56 - IPv6 restored with packet filtering.
. 2023.08.07 08:15:56 - Interface eddie metric restored from 3 to Automatic, layer IPv4
. 2023.08.07 08:15:56 - Interface eddie metric restored from 3 to Automatic, layer IPv6
. 2023.08.07 08:15:56 - Connection terminated.
I 2023.08.07 08:15:59 - Checking authorization ...
. 2023.08.07 08:15:59 - Using WinTun network interface "eddie (Wintun Userspace Tunnel)"
. 2023.08.07 08:15:59 - IPv6 disabled with packet filtering.
! 2023.08.07 08:15:59 - Connecting to Camelopardalis (Norway, Oslo)
. 2023.08.07 08:15:59 - Routes, add 82.102.27.197/32 for interface "Ethernet (Remote NDIS based Internet Sharing Device)".
. 2023.08.07 08:15:59 - Routes, add 82.102.27.197/32 for interface "Ethernet (Remote NDIS based Internet Sharing Device)", already exists.
. 2023.08.07 08:16:00 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.08.07 08:16:00 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.08.07 08:16:00 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.08.07 08:16:00 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.08.07 08:16:00 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.08.07 08:16:00 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.08.07 08:16:00 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.08.07 08:16:00 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]82.102.27.197:443
. 2023.08.07 08:16:00 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.08.07 08:16:00 - OpenVPN > UDP link local: (not bound)
. 2023.08.07 08:16:00 - OpenVPN > UDP link remote: [AF_INET]82.102.27.197:443
. 2023.08.07 08:16:00 - OpenVPN > TLS: Initial packet from [AF_INET]82.102.27.197:443, sid=9020ff2e 90e4fb46
. 2023.08.07 08:16:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.08.07 08:16:00 - OpenVPN > VERIFY KU OK
. 2023.08.07 08:16:00 - OpenVPN > Validating certificate extended key usage
. 2023.08.07 08:16:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.08.07 08:16:00 - OpenVPN > VERIFY EKU OK
. 2023.08.07 08:16:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Camelopardalis, emailAddress=info@airvpn.org
. 2023.08.07 08:16:00 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2023.08.07 08:16:00 - OpenVPN > [Camelopardalis] Peer Connection Initiated with [AF_INET]82.102.27.197:443
! 2023.08.07 08:16:00 - Disconnecting
. 2023.08.07 08:16:00 - Sending soft termination signal
. 2023.08.07 08:16:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.08.07 08:16:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.12.54.1,dhcp-option DNS6 fde6:7a:7d20:836::1,tun-ipv6,route-gateway 10.12.54.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:836::10d7/64 fde6:7a:7d20:836::1,ifconfig 10.12.54.217 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2023.08.07 08:16:03 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2023.08.07 08:16:03 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.12.54.1'
. 2023.08.07 08:16:03 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:836::1'
. 2023.08.07 08:16:03 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2023.08.07 08:16:03 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:836::10d7/64 fde6:7a:7d20:836::1'
. 2023.08.07 08:16:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2023.08.07 08:16:03 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2023.08.07 08:16:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2023.08.07 08:16:03 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2023.08.07 08:16:03 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2023.08.07 08:16:03 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2023.08.07 08:16:03 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2023.08.07 08:16:03 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2023.08.07 08:16:03 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.08.07 08:16:03 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2023.08.07 08:16:03 - OpenVPN > interactive service msg_channel=0
. 2023.08.07 08:16:03 - OpenVPN > open_tun
. 2023.08.07 08:16:03 - OpenVPN > wintun device [eddie] opened
. 2023.08.07 08:16:03 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 44 static 10.12.54.217 255.255.255.0
. 2023.08.07 08:16:03 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 44 all
. 2023.08.07 08:16:03 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 44 all
. 2023.08.07 08:16:03 - OpenVPN > IPv4 MTU set to 1500 on interface 44 using SetIpInterfaceEntry()
. 2023.08.07 08:16:03 - OpenVPN > Initialization Sequence Completed
. 2023.08.07 08:16:03 - Interface eddie metric changed from Automatic to 3, layer IPv4
. 2023.08.07 08:16:03 - Interface eddie metric changed from Automatic to 3, layer IPv6
. 2023.08.07 08:16:03 - Routes, add 0.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:16:04 - Routes, add 128.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:16:04 - Routes, add 82.102.27.195/32 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:16:04 - Routes, skipped for 2001:ac8:38:21:2473:6fcc:942d:eb92 : IPv6 blocked.
. 2023.08.07 08:16:04 - Flushing DNS
. 2023.08.07 08:16:05 - OpenVPN > Closing TUN/TAP interface
. 2023.08.07 08:16:05 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 44 10.12.54.217 store=active
. 2023.08.07 08:16:05 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.08.07 08:16:05 - Routes, delete 0.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:16:05 - Routes, delete 128.0.0.0/1 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:16:06 - Routes, delete 82.102.27.197/32 for interface "Ethernet (Remote NDIS based Internet Sharing Device)".
. 2023.08.07 08:16:06 - Routes, delete 82.102.27.195/32 for interface "eddie (Wintun Userspace Tunnel)".
. 2023.08.07 08:16:06 - Routes, skipped for 2001:ac8:38:21:2473:6fcc:942d:eb92 : IPv6 blocked.
. 2023.08.07 08:16:06 - Routes, delete 82.102.27.197/32 for interface "Ethernet (Remote NDIS based Internet Sharing Device)", not exists.
. 2023.08.07 08:16:06 - IPv6 restored with packet filtering.
. 2023.08.07 08:16:06 - Interface eddie metric restored from 3 to Automatic, layer IPv4
. 2023.08.07 08:16:06 - Interface eddie metric restored from 3 to Automatic, layer IPv6
. 2023.08.07 08:16:06 - Connection terminated.
I 2023.08.07 08:16:06 - Cancel requested.
! 2023.08.07 08:16:06 - Session terminated.
Edited ... by OpenSourcerer
Apply LOG format to logs
Have you tried turning it off and on again?
Actually, don't just turn it off; reboot instead.
On August 7 Russian authorities introduced DPI ban over both OpenVPN and FireWire protocols.
Unlike China defaults like OpenVPN-TCP-443 won't work. Changing servers is useles too. So this is topic might be better moved to the general troubleshooting topic.
FireWire, or Wireguard? :)
In any case, use OpenVPN over SSH or SSL to verify.
Thanks for the answers! I've tried everything possible with the advice from the forum. I have rebooted the computer several times. Nothing helped. But this morning everything is working again. Any advice on SSH and SSL for verification, how should I do it so I don't panic next time? Thanks!!!
Edited ... by SobakaBaskov
Wireguard doesn't work, no matter the port: 1637 or 47107; no matter the app - tried the native Wierguard from f-droid and Eddie as well.
As for OpenVPN - I've tried all the possible 42 configs from the Config Generator page, neither have worked. Although I haven't changed the default advanced settings (like resolved hosts or OpenVPN profile etc).
OpenVPN over SSH works alright but it's slow and seems unstable.
I haven't checked out OpenVPN over SSL, seems like a giant pain in the ass to setup tbh.
You are using Eddie, right? You don't have to setup anything. Simply select SSL as the protocol.
Yeah, forgot to mention the fact - AirVPN works flawlessly on PC, the aforementioned dpi block only concerns the mobile traffic as of now.
Is there some SSL option available in Eddie on Android that I'm missing?
I don't see any easy and convenient way to implement OpenVPN over SSL on Android, just this guide - https://airvpn.org/forums/topic/24349-how-to-airvpn-via-sslstunnel-on-android-678/
Well, you failed to mention Android, and the logs are from a PC. :)
No, SSH and SSL are not an (easy) option on Android, sorry. The thread you linked is, as far as I remember, the latest way to set this up.
