Not connected, Your IP: 216.73.217.51
my vpn will just not connect. logs:
I 2023.07.17 00:26:52 - Checking authorization ...
. 2023.07.17 00:26:52 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.07.17 00:26:52 - Connecting to Kitalpha (Switzerland, Zurich)
. 2023.07.17 00:26:53 - Routes, add 91.214.169.71/32 for interface "Wi-Fi (Intel(R) Dual Band Wireless-AC 3168)".
. 2023.07.17 00:26:53 - Routes, add 91.214.169.71/32 for interface "Wi-Fi (Intel(R) Dual Band Wireless-AC 3168)", already exists.
. 2023.07.17 00:26:53 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.07.17 00:26:53 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.07.17 00:26:53 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.07.17 00:26:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.07.17 00:26:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.07.17 00:26:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.07.17 00:26:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.07.17 00:26:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]91.214.169.71:443
. 2023.07.17 00:26:53 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.07.17 00:26:53 - OpenVPN > UDP link local: (not bound)
. 2023.07.17 00:26:53 - OpenVPN > UDP link remote: [AF_INET]91.214.169.71:443
! 2023.07.17 00:27:06 - Disconnecting
. 2023.07.17 00:27:06 - Sending soft termination signal
. 2023.07.17 00:27:09 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.07.17 00:27:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.07.17 00:27:12 - Routes, delete 91.214.169.71/32 for interface "Wi-Fi (Intel(R) Dual Band Wireless-AC 3168)".
. 2023.07.17 00:27:12 - Routes, delete 91.214.169.71/32 for interface "Wi-Fi (Intel(R) Dual Band Wireless-AC 3168)", not exists.
. 2023.07.17 00:27:12 - Connection terminated.
I 2023.07.17 00:27:12 - Cancel requested.
! 2023.07.17 00:27:12 - Session terminated.
Edited ... by bunnyhop
