ErIMaDlOPZnzY59FjkC9
Bluetit AirVPN daemon SSH & IP 3 does not work?
Hello, I use Bluetit on one of my servers.
It works out of the box however, my ISP throttles download speed, using the normal the Eddie client I would use the SSH protocol with IP 3 and the downloads are no longer throttled.
How can I implement this using Bluetit?
Bluetit error
Jul 13 14:43:53 [23542]: IPv6 is available in this system
Jul 13 14:43:53 [23542]: Default VPN type for AirVPN connections is set to OpenVPN
Jul 13 14:43:53 [23542]: ERROR in /etc/airvpn/bluetit.rc: invalid value "ssh" for directive airproto (allowed values: udp, tcp)
Jul 13 14:43:53  bluetit[23542]: Bluetit successfully initialized and ready
Jul 13 14:43:53  bluetit[23542]: Requesting network IP and country to AirVPN ipleak.net via secure connection
Jul 13 14:44:03  bluetit[23542]: ERROR: Cannot detect system location: Cannot resolve ipleak.net
Jul 13 14:44:03  bluetit[23542]: AirVPN Manifest updater thread started
Jul 13 14:44:03  bluetit[23542]: AirVPN Manifest update interval is 15 minutes
Jul 13 14:44:03  bluetit[23542]: Updating AirVPN Manifest
Jul 13 14:44:03  bluetit[23542]: Trying connection to AirVPN bootstrap server at http://63.33.78.166
Bluetit.rc
# bluetit runcontrol file
# AirVPN bootstrap servers
bootserver                http://63.33.78.166
bootserver                http://52.48.66.85
bootserver                http://54.93.175.114
bootserver                http://63.33.116.50
bootserver                http://[2a03:b0c0:0:1010::9b:c001]
# RSA Parameters
rsaexponent
rsamodulus
# bootserver              <ip|url>
# rsaexponent             <value>
# rsamodulus              <value>
airconnectatboot          quick
# networklockpersist      <on|nftables|iptables|pf|off>
airusername               foo
airpassword               bar
# airkey                  <airvpn_user_key>
# airserver               <airvpn_server_name>
# aircountry              <airvpn_country_name>
airproto                  ssh
airport                   22
# aircipher               <cipher_name>
# airipv6                 <yes|no>
# air6to4                 <yes|no>
# manifestupdateinterval  <minutes>
# airwhiteserverlist      <server list>
# airblackserverlist      <server list>
# airwhitecountrylist     <country list>
# airblackcountrylist     <country list>
# forbidquickhomecountry  <yes|no>
# country                 <ISO code>
# remote                  <ip|url list>
# proto                   <udp|tcp>
# port                    <port>
# tunpersist              <yes|no>
# cipher                  <cipher_names>
# maxconnretries          <number>
# tcpqueuelimit           <value>
# ncpdisable              <yes|no>
# networklock             <on|nftables|iptables|pf|off>
# ignorednspush           <yes|no>
# timeout                 <seconds>
# compress                <yes|no|asym>
# tlsversionmin           <disabled|default|tls_1_x>
# proxyhost               <ip|url>
# proxyport               <port>
# proxyusername           <username>
# proxypassword           <password>
# proxybasic              <yes|no>
Well, learn C++ and implement it. :)
As for how to use it with Bluetit, it's not supported at the moment. Please use Eddie CLI for this.
