circuitcreature
ANSWERED Constant connection drops when torrent client is active
MacOS, AirVPN Eddie 2.23.1
This just started up yesterday.
VPN works fine when first connected. Once Qbittorrent is started and makes a couple connections VPN traffic drops to zero and after about 60 seconds disconnects and reconnects. This cycle goes on until Qbit is closed.
Tried:
AirVPN settings are all default and using tcp 443 and ipv4 only
QBit:
port open in the router,
network interface: tun3 (VPN connection)
Tried many other things but just can figure out what is going on.
Logs right after a disconnect
. 2023.07.11 15:34:10 - OpenVPN > read TCPv4_CLIENT: Operation timed out (fd=9,code=60)
. 2023.07.11 15:34:10 - OpenVPN > Connection reset, restarting [0]
. 2023.07.11 15:34:10 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2023.07.11 15:34:10 - OpenVPN > Restart pause, 1 second(s)
! 2023.07.11 15:34:11 - Disconnecting
. 2023.07.11 15:34:11 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.197:443
. 2023.07.11 15:34:11 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144]
. 2023.07.11 15:34:11 - OpenVPN > Attempting to establish TCP connection with [AF_INET]184.75.221.197:443
. 2023.07.11 15:34:11 - OpenVPN > TCP connection established with [AF_INET]184.75.221.197:443
. 2023.07.11 15:34:11 - OpenVPN > TCPv4_CLIENT link local: (not bound)
. 2023.07.11 15:34:11 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]184.75.221.197:443
. 2023.07.11 15:34:11 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.197:443, sid=841f400a 9299aa6c
. 2023.07.11 15:34:11 - Sending soft termination signal
. 2023.07.11 15:34:12 - OpenVPN > event_wait : Interrupted system call (fd=-1,code=4)
. 2023.07.11 15:34:12 - OpenVPN > Closing TUN/TAP interface
. 2023.07.11 15:34:12 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:1b7b::101e
. 2023.07.11 15:34:12 - OpenVPN > delete host fde6:7a:7d20:1b7b::101e
. 2023.07.11 15:34:12 - OpenVPN > SIGINT[hard,] received, process exiting
. 2023.07.11 15:34:12 - Routes, delete 0.0.0.0/1 for interface "utun3", not exists.
. 2023.07.11 15:34:12 - Routes, delete 128.0.0.0/1 for interface "utun3", not exists.
. 2023.07.11 15:34:12 - Routes, delete ::/1 for interface "utun3", not exists.
. 2023.07.11 15:34:12 - Routes, delete 8000::/1 for interface "utun3", not exists.
. 2023.07.11 15:34:12 - Routes, delete 184.75.221.197/32 for interface "en0".
. 2023.07.11 15:34:12 - Routes, delete 184.75.221.195/32 for interface "utun3", not exists.
. 2023.07.11 15:34:12 - Routes, delete 2606:6080:1001:15:45d:2b31:f931:2e2/128 for interface "utun3", not exists.
. 2023.07.11 15:34:12 - Routes, delete 184.75.221.197/32 for interface "en0", not exists.
. 2023.07.11 15:34:12 - DNS of a network adapter restored to original settings (Wi-Fi, to 192.168.1.1)
. 2023.07.11 15:34:12 - DNS of a network adapter restored to original settings (iPhone USB, to 192.168.1.1)
. 2023.07.11 15:34:13 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to 192.168.1.1)
. 2023.07.11 15:34:13 - Connection terminated.
I 2023.07.11 15:34:16 - Checking authorization ...
! 2023.07.11 15:34:17 - Connecting to Acamar (United States of America, Miami)
. 2023.07.11 15:34:17 - Routes, add 173.44.55.157/32 for interface "en0".
. 2023.07.11 15:34:17 - Routes, add 173.44.55.157/32 for interface "en0", already exists.
. 2023.07.11 15:34:17 - OpenVPN > OpenVPN 2.6.3 x86_64-apple-darwin21.4.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD]
. 2023.07.11 15:34:17 - OpenVPN > library versions: OpenSSL 3.1.0 14 Mar 2023, LZO 2.10
. 2023.07.11 15:34:17 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]173.44.55.157:443
. 2023.07.11 15:34:17 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144]
. 2023.07.11 15:34:17 - OpenVPN > Attempting to establish TCP connection with [AF_INET]173.44.55.157:443
. 2023.07.11 15:34:17 - OpenVPN > TCP connection established with [AF_INET]173.44.55.157:443
. 2023.07.11 15:34:17 - OpenVPN > TCPv4_CLIENT link local: (not bound)
. 2023.07.11 15:34:17 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]173.44.55.157:443
. 2023.07.11 15:34:17 - OpenVPN > TLS: Initial packet from [AF_INET]173.44.55.157:443, sid=5e3c11ba 9074b792
. 2023.07.11 15:34:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.07.11 15:34:18 - OpenVPN > VERIFY KU OK
. 2023.07.11 15:34:18 - OpenVPN > Validating certificate extended key usage
. 2023.07.11 15:34:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.07.11 15:34:18 - OpenVPN > VERIFY EKU OK
. 2023.07.11 15:34:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Acamar, emailAddress=info@airvpn.org
  Edited ... by circuitcreature
Is there a reason why you use TCP?
Do not open this in the router, only in AirVPN.
I was forcing TCP based on other threads I've read. When forcing UDP I get the same results. Currently, I have it set to automatic in Eddie and both within QB.
I should have mentioned the port is open with AirVPN.
If UDP works, don't force TCP. Try this: Reboot the machine (not shutdown, then startup), then set UDP/443 for the connection.
In qB, set the protocol to TCP only and adjust the max connections to ~100.
Then try again.
Thanks for getting back.
I reset preferences on both apps and still no go. I spun up a hard-wired server with a docker instance of QB and everything worked fine.
After constant video drops, with no VPN, I found that my AP was acting up.
Guess its about time to retire this old boy.
