Hi, i just installed AirVpn 2 days ago and until now was all perfect, but now i have an issue with my connection.
My pc connects to the internet only with the airvpn app.
If i want to use normal internet connection, it says no internet connection anyway, but if i start airvpn my connection starts (behind the vpn obviously).
Could you help me with this issue?
i have windows 11 on it.
Thank you.
You are using Eddie tool? I don't see how this could happen in a different scenario so I give you the instruction as you are using Eddie:
Go to its setting and disable the kill switch. It's a security switch that makes you go offline if you are not connected to the internet. It's very useful for cases where the user is afraid that the VPN might disconnect and traffic would be sent via the normal internet connection.
