tonyj 0 Posted ... I'm not sure what exactly I'm doing to get 5 active sessions without being in a session. As a matter of fact I'm locked out from a session because I'm only allowed 5 concurrent sessions even though I've seen up to 6 or 7 sessions at a time. Any help would be appreciated. Quote Share this post Link to post
Tech Jedi Alex 1526 Posted ... Simply disconnect them all in the client area. Are you using Eddie to connect? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
tonyj 0 Posted ... So I went to the sessions section in the Client Area and I noticed none of the active sessions (Wireguard) had a disconnect button. However, when an empty session space was available, I activated a session and noticed my session box had a disconnect button. Is that unusual or is that pretty common? Yes, I am using Eddie to connect. Quote Share this post Link to post
drum 6 Posted ... Perhaps not the same case, i'm locked out for excess sessions when i'm testing connectivity to xyz site and fast connect/disconnect from airvpn servers. I can't see any disconnect button in Client Area/Sessions (Wireguard). Eddie Windows 10 x64 ADD: Welll it seems that the disconnect button is only available in OPENVPN connections, also when connecting/disconnecting using an OpenVPN airvpn server, the CLIENT AREA/SESSIONS is updated immediately. Would be possible to add the Disconnect button to Wireguard Sessions and most important, that disconnects for Wireguard sessions be like the OpenVPN ones, detected pretty fast so Wireguard users don't get more than 5 sessions at once? Thanks Quote Share this post Link to post
