Not connected, Your IP: 216.73.216.28
qwertyuiop1990
ANSWERED How to run and connect on boot (Raspbian, RPi 4)
I'm on an RPi 4, running Raspbian 64-bit, latest version.  The Eddie UI client has an option "Connect at startup", which will connect right when I open Eddie, however, after a system reboot Eddie does not open automatically.  I've tried the systemd files in this forum post from a few years ago, but it doesn't seem to work (not sure why).  Does anyone have a succinct guide on how to autostart the VPN connection on Raspberry Pi (raspbian) boot?
That forums post refers to the CLI version with a configuration preconfigured in the GUI. Autostarting apps should be started by the desktop, not with Systemd. Which desktop environment are you using? Contents of these vars?
$ echo $XDG_SESSION_DESKTOP \| $DESKTOP_SESSION \| $XDG_CURRENT_DESKTOP
Here's the output to that:
lightdm-xsession | LXDE-pi | LXDE
I've used the LXDE-pi/autostart file before to automatically launch UI clients at start up.  I've tried doing that here but perhaps I have the name wrong of the Eddie client.  Would this be a viable option?
Ok I figured out it was @eddie-ui.
I opened the file:
/etc/xdg/lxsession/LXDE-pi/autostart
And added the line at the bottom:
@eddie.ui
Then I enabled the settings to autostart and connect the client.  Not sure why this option isn't mentioned anywhere else.
