yippee
[EDIT: FIXED] attempt to connect/restart loop with eddie
[EDIT: FIXED] the below post helped me! i can't seem to delete this post-- sorry mods!
I 2023.05.31 22:53:03 - Session starting.
I 2023.05.31 22:53:05 - Checking authorization ...
. 2023.05.31 22:53:06 - Added new network interface "Eddie", Wintun version 0.12
. 2023.05.31 22:53:06 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.05.31 22:53:06 - Connecting to Lacerta (Canada, Montreal)
. 2023.05.31 22:53:06 - Routes, add 87.101.92.173/32 for interface "Wi-Fi (Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W))".
. 2023.05.31 22:53:06 - Routes, add 87.101.92.173/32 for interface "Wi-Fi (Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W))", already exists.
. 2023.05.31 22:53:06 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.05.31 22:53:06 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.05.31 22:53:06 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.05.31 22:53:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.05.31 22:53:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.05.31 22:53:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.05.31 22:53:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.05.31 22:53:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]87.101.92.173:443
. 2023.05.31 22:53:06 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.05.31 22:53:06 - OpenVPN > UDP link local: (not bound)
. 2023.05.31 22:53:06 - OpenVPN > UDP link remote: [AF_INET]87.101.92.173:443
. 2023.05.31 22:53:06 - OpenVPN > TLS: Initial packet from [AF_INET]87.101.92.173:443, sid=58f3551a b6cc14e3
. 2023.05.31 22:53:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.05.31 22:53:06 - OpenVPN > VERIFY KU OK
. 2023.05.31 22:53:06 - OpenVPN > Validating certificate extended key usage
. 2023.05.31 22:53:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.05.31 22:53:06 - OpenVPN > VERIFY EKU OK
. 2023.05.31 22:53:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Lacerta, emailAddress=info@airvpn.org
. 2023.05.31 22:53:38 - OpenVPN > [Lacerta] Inactivity timeout (--ping-exit), exiting
. 2023.05.31 22:53:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.05.31 22:53:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2023.05.31 22:53:44 - Disconnecting
. 2023.05.31 22:53:44 - Routes, delete 87.101.92.173/32 for interface "Wi-Fi (Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W))".
. 2023.05.31 22:53:44 - Routes, delete 87.101.92.173/32 for interface "Wi-Fi (Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W))", not exists.
. 2023.05.31 22:53:44 - Connection terminated.
I 2023.05.31 22:53:47 - Checking authorization ...
. 2023.05.31 22:53:48 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2023.05.31 22:53:48 - Connecting to Lacerta (Canada, Montreal)
. 2023.05.31 22:53:48 - Routes, add 87.101.92.173/32 for interface "Wi-Fi (Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W))".
. 2023.05.31 22:53:48 - Routes, add 87.101.92.173/32 for interface "Wi-Fi (Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W))", already exists.
. 2023.05.31 22:53:48 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2023.05.31 22:53:48 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2023.05.31 22:53:48 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2023.05.31 22:53:48 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.05.31 22:53:48 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.05.31 22:53:48 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2023.05.31 22:53:48 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2023.05.31 22:53:48 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]87.101.92.173:443
. 2023.05.31 22:53:48 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2023.05.31 22:53:48 - OpenVPN > UDP link local: (not bound)
. 2023.05.31 22:53:48 - OpenVPN > UDP link remote: [AF_INET]87.101.92.173:443
. 2023.05.31 22:53:48 - OpenVPN > TLS: Initial packet from [AF_INET]87.101.92.173:443, sid=51229934 c87c0f66
. 2023.05.31 22:53:48 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2023.05.31 22:53:48 - OpenVPN > VERIFY KU OK
. 2023.05.31 22:53:48 - OpenVPN > Validating certificate extended key usage
. 2023.05.31 22:53:48 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2023.05.31 22:53:48 - OpenVPN > VERIFY EKU OK
. 2023.05.31 22:53:48 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Lacerta, emailAddress=info@airvpn.org
! 2023.05.31 22:53:49 - Disconnecting
. 2023.05.31 22:53:49 - Sending soft termination signal
. 2023.05.31 22:53:52 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2023.05.31 22:53:53 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2023.05.31 22:53:53 - Routes, delete 87.101.92.173/32 for interface "Wi-Fi (Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W))".
. 2023.05.31 22:53:53 - Routes, delete 87.101.92.173/32 for interface "Wi-Fi (Killer(R) Wi-Fi 6 AX1650s 160MHz Wireless Network Adapter (201D2W))", not exists.
. 2023.05.31 22:53:53 - Connection terminated.
I 2023.05.31 22:53:53 - Cancel requested.
! 2023.05.31 22:53:54 - Session terminated.
would anyone be able to help me? :( Edited ... by yippee
