Jommes 1 Posted ... Yesterday i set up a docker container with Gluetun en QBittorrent on my DS920+ I tried it with Wireguard over UDP and it works. But my Ubuntu test torrent had very slow download speeds. I saw that when i use the VPN on my laptop via UDP that my connection had hickups. It wasn't stable an very slow. I remembered that my ISP has an issue with UDP and OpenVPN. When i use OpenVPN with TCP it works fine. But AirVPN only works with UDP in combination with Wireguard. So i have no other option to use OpenVPN with tcp. I changed my compose-file, but when i start Gluetun i get this errors: 2023-04-03T13:52:36+02:00 INFO [openvpn] OpenSSL: error:05800074:x509 certificate routines::key values mismatch 2023-04-03T13:52:36+02:00 INFO [openvpn] Cannot load private key file [[INLINE]] 2023-04-03T13:52:36+02:00 INFO [openvpn] SIGUSR1[soft,private-key-password-failure] received, process restarting 2023-04-03T13:52:42+02:00 INFO [healthcheck] program has been unhealthy for 6s: restarting VPN (see https://github.com/qdm12/gluetun/wiki/Healthcheck) 2023-04-03T13:52:42+02:00 INFO [vpn] stopping This is my compose: #gluetun gluetun: image: qmcgaw/gluetun container_name: gluetun cap_add: - NET_ADMIN devices: - /dev/net/tun:/dev/net/tun ports: - 8888:8888/tcp # HTTP proxy - 8388:8388/tcp # Shadowsocks - 8388:8388/udp # Shadowsocks - 8090:8090 # port for qbittorrent - 34671:34671 volumes: - /volume1/docker/gluetun:/gluetun environment: - VPN_SERVICE_PROVIDER=airvpn - VPN_TYPE=openvpn - PROTOCOL=tcp - OPENVPN_USER=username - OPENVPN_PASSWORD=password - FIREWALL_VPN_INPUT_PORTS=34671 - SERVER_REGIONS=Europe - TZ=Europe/Paris - HTTPPROXY=on - SHADOWSOCKS=on - FIREWALL_OUTBOUND_SUBNETS=172.19.0.0/16,192.168.1.0/24 network_mode: vpn-stack restart: unless-stopped In /volume1/docker/gluetun:/gluetun i placed a client.crt and client.key file from this instructions: https://github.com/qdm12/gluetun/wiki/OpenVPN-client-key and and i extracted them from the OVPN config file a generated from the config generator. client.key contents: -----BEGIN PRIVATE KEY----- Very long key -----END PRIVATE KEY----- client.crt contents (in my AirVPN OVPN file i saw 2 certificates): -----BEGIN CERTIFICATE----- Very long key -----END CERTIFICATE----- </ca> <cert> -----BEGIN CERTIFICATE----- Very long key 2 -----END CERTIFICATE----- When i use one certificate, i get the same error. Can somebody help me out? Share this post Link to post
Tech Jedi Alex 1532 Posted ... 4 hours ago, Jommes said: But AirVPN only works with UDP in combination with Wireguard Correction: Wireguard itself works UDP-only. It's independent from the VPN provider. 4 hours ago, Jommes said: client.crt contents (in my AirVPN OVPN file i saw 2 certificates): I think this is where it hiccups. The instructions ask for the <cert> part only but you included the <ca> part, too. Moreover, <ca> is the first key appearing, so OpenVPN likely tries to use that as the <cert>, and logically fails because of a modulus mismatch. The instructions for AirVPN don't mention the CA cert being used. 4 hours ago, Jommes said: When i use one certificate, i get the same error. Can somebody help me out? Now it only depends which one you used. Can you make sure you used the <cert>? Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Jommes 1 Posted ... Okay, it's in Wireguard itself. Many thanks! I had selected the <ca> and i need the <cert> after changing everything works! I had to look in the logs to see if Gluetun uses TCP, and it does. A test-torrent go's very slow, when i test another Linux test-torrent it go's with almost the max of my downloadspeed. 1 wetduck reacted to this Share this post Link to post
