proton-air-vpn 0 Posted ... Hello I have the problem that I can't access themoviedb.org with an active vpn connection. On the router (openwrt), pinging and routing to themoviedb.org works without any problems. Only on the end devices (mobile phone, laptop...) does this not work. an ns lookup resulted in: nslookup themoviedb.org Servers: 1.1.1.1 Address: 1.1.1.1#53 Non-authoritative answer: Name: themoviedb.org Address: 52.85.49.42 Name: themoviedb.org Address: 52.85.49.118 Name: themoviedb.org Address: 52.85.49.38 Name: themoviedb.org Address: 52.85.49.34 Name: themoviedb.org I would be grateful if someone could help me because I don't know where the problem is. Sorry for the bad english, I'm not that good at it Share this post Link to post
Tech Jedi Alex 1522 Posted ... Spicy nickname… Do you connect with your PC or with the router to AirVPN? If PC, which software do you use? Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
proton-air-vpn 0 Posted ... So my configuration is as follows: AirVPN runs on OpenWRT router. My computer runs LMDE5 with LibreWolf. I use Android with Firefox on my Phone. I had previously set the airdns but since I noticed that themoviedb doesn't work, I set the dns to 1.1.1.1 to rule out an error in airdns. But that's not the reason because I can't access themoviedb with google dns either. If I switch to my unprotected lan/wlan, I can access themoviedb directly. the same with opera and vpn switched on. I don't understand that because I can ping themoviedb in openwrt and the routing also works without problems... Share this post Link to post
Tech Jedi Alex 1522 Posted ... Better check if you can connect to DNS servers to begin with. On Linux desktop, netcat can do that. -z closes nc if successful instead of waiting for CTRL-C, -v shows success, too, and -w is timeout of 10 seconds (default is 300 or 600, something along this): $ nc -zvw10 <your router> 53 $ nc -zvw10 <AirDNS server> 53 $ nc -zvw10 1.1.1.1 53 . Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
proton-air-vpn 0 Posted ... Sorry I was sick in bed for a few days. So the connection to the dns is not a problem. the request also appears in adguard and this is not blocked either, but no transmission takes place but i get the standard message: error: connection failed LibreWolf cannot connect to the server at www.themoviedb.org. nc -zvw10 returned the following: :~$ nc -zvw10 10.20.30.1 53 Connection to 10.20.30.1 53 port [tcp/domain] succeeded! :~$ nc -zvw10 10.20.30.123 53 (Adguardhome dns) Connection to 10.20.30.123 53 port [tcp/domain] succeeded! :~$ nc -zvw10 10.4.0.1 53 Connection to 10.4.0.1 53 port [tcp/domain] succeeded! What I don't understand is that the request can be seen in adguard and is not blocked, but the page is not called up, regardless of which device I want to call up the page from. as said on in openwrt diagnostics I get the following output: PING themoviedb.org (52.85.49.34): 56 data bytes 64 bytes from 52.85.49.34: seq=0 ttl=242 time=74.827 ms 64 bytes from 52.85.49.34: seq=1 ttl=242 time=48.152 ms 64 bytes from 52.85.49.34: seq=2 ttl=242 time=50.544 ms 64 bytes from 52.85.49.34: seq=3 ttl=242 time=50.892 ms 64 bytes from 52.85.49.34: seq=4 ttl=242 time=51.872 ms --- themoviedb.org ping statistics --- 5 packets transmitted, 5 packets received, 0% packet loss round-trip min/avg/max = 48.152/55.257/74.827 ms Server: 127.0.0.1 Address: 127.0.0.1:53 Non-authoritative answer: Name: themoviedb.org Address: 52.85.49.42 Name: themoviedb.org Address: 52.85.49.34 Name: themoviedb.org Address: 52.85.49.118 Name: themoviedb.org Address: 52.85.49.38 Non-authoritative answer: Name: themoviedb.org Address: 2600:9000:2038:1a00:e:5373:440:93a1 Name: themoviedb.org Address: 2600:9000:2038:8200:e:5373:440:93a1 Name: themoviedb.org Address: 2600:9000:2038:8c00:e:5373:440:93a1 Name: themoviedb.org Address: 2600:9000:2038:9200:e:5373:440:93a1 Name: themoviedb.org Address: 2600:9000:2038:ba00:e:5373:440:93a1 Name: themoviedb.org Address: 2600:9000:2038:c200:e:5373:440:93a1 Name: themoviedb.org Address: 2600:9000:2038:e400:e:5373:440:93a1 Name: themoviedb.org Address: 2600:9000:2038:f200:e:5373:440:93a1 everything works on the router but not on the end device Share this post Link to post
Flx 77 Posted ... 4 hours ago, proton-air-vpn said: everything works on the router but not on the end device What happens if gateway and DNS are set to match the router IP(OpenWRT) for Phone and your computer? Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
proton-air-vpn 0 Posted ... If I deposit the dns on the router (OpenWRT) (gateway and dns identical) I have the same problem... Share this post Link to post
proton-air-vpn 0 Posted ... So the problem is found and fixed Many thanks to OpenSourcerer without whom I would not have gotten it solved. The problem was the Yandex DNS (77.88.8.8 and 77.88.8.1) that was specified as a WAN DNS server. After removing the two dns servers, I was able to access themoviedb.org again without any problems. It's not clear to me why the WAN DNS has an influence on the LAN, since I'm actually using the AirDNS (10.4.0.1) there, but well, ok then that's the way it is Share this post Link to post
Tech Jedi Alex 1522 Posted ... 4 minutes ago, proton-air-vpn said: It's not clear to me why the WAN DNS has an influence on the LAN, since I'm actually using the AirDNS (10.4.0.1) there, but well, ok then that's the way it is We'll check on that in the future, as discussed in our little chat. But the original problem is solved. Thank you for your patience! 1 nexsteppe reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
