DARR1 0 Posted ... ptables -I FORWARD -i tun1 -p udp -d destIP --dport port -j IP outside<<<<, correct? iptables -I FORWARD -i tun1 -p tcp -d destIP --dport port -j IP outside<<<<<<,correct ? iptables -t nat -I PREROUTING -i tun1 -p tcp --dport port -j DNAT --IP of local device<<<< correct ? iptables -t nat -I PREROUTING -i tun1 -p udp --dport port -j DNAT -IP of local device<<<<<,correct ? So all i have to do is put in those IP's and it should work ? Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... State the source from where you got these commands, please. This is highly out of context, and somewhat hints at an emerging XY problem. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
DARR1 0 Posted ... iptables -I FORWARD -i tun1 -p udp -d destIP --dport port -j ACCEPTiptables -I FORWARD -i tun1 -p tcp -d destIP --dport port -j ACCEPTiptables -t nat -I PREROUTING -i tun1 -p tcp --dport port -j DNAT --to-destination destIPiptables -t nat -I PREROUTING -i tun1 -p udp --dport port -j DNAT --to-destination destIP This is what i saw on here i just changed the the ends for the forums i have done PF before but it weren't like this Quote Share this post Link to post
DARR1 0 Posted ... Is this what it should look like when i put i the ports and ip ? iptables -I FORWARD -i tun11 -p udp -d 192.168.XX.XX--dport XXXX -j ACCEPT iptables -I FORWARD -i tun11 -p tcp -d 192.168.XX.XX --dport XXXX -j ACCEPT iptables -t nat -I PREROUTING -i tun11 -p tcp --dport XXXX -j DNAT --192.168.XX.XX iptables -t nat -I PREROUTING -i tun11 -p udp --dport XXXX -j DNAT --192.168.XX.XXX Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... Okay, from the start then. Provide a link to the exact source where you got these. State your intentions, where you want to set what up exactly. State the hardware you're trying this on, plus OS version, and paste either text configs or screenshots of it. iptables doesn't log unless told in the chain to do so, but if there's any relevant logging, even if you only think it might be relevant, provide that as well. If you ask "are these rules correct", if someone answers, they do so under a certain layer of assumptions born from a hopeless lack of information on your part. If they are incorrect, we find ourselves in a circle of Q&As, and the actual help starts only after a whole page of posts. Please be specific in what you want help with and you will be helped. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
DARR1 0 Posted ... https://airvpn.org/forums/topic/49628-asus-merlin-router-airvpn-portforwarding-instructions/ My intention is to have 1 port forwarded Set up will take place in the router -Asus -RT-AX86U Merlin Port will be forwarded to a media server on a Qnap Using windows 11 on my desktop syslog (1).txt Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... Splendid! So you followed the guide made by @Similiar. You're clearly referencing step 9. Is the interface name tun11? If yes, that part is correct. Is the port you want to forward correct? In case of a web server running on the NAS, just for example, dport would be 80, so it should be the port on which the media server listens. On 3/1/2023 at 5:34 PM, DARR1 said: ptables -I FORWARD -i tun1 -p udp -d destIP --dport port -j IP outside<<<<, correct? iptables -I FORWARD -i tun1 -p tcp -d destIP --dport port -j IP outside<<<<<<,correct ? Lastly, from your first post, it is clear now that these are not correct. -j is JUMP = action what to do. It can be an immediate "command" like REDIRECT, a different chain or the name of an extension like TARPIT. In the guide the two lines simply allow the traffic to actually pass, since I figure the policy is DROP to not allow any other traffic. The redirects are the other two lines; they seem correct to me. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
DARR1 0 Posted ... Think i messed up in step 2..when it says add a port...which port should be added ? The port of the Nas where the media server runs ? Quote Share this post Link to post
Tech Jedi Alex 1522 Posted ... Forward a random port and configure Plex to listen on whichever port gets assigned to you. If you cannot change it in Plex, enter the port Plex wants to listen to in the Local port field and then forward a random port. If the port forwarding on the Asus router is correct, you should be able to connect to Plex using the remote port. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
