Not connected, Your IP: 216.73.216.85
streamview
ANSWERED Eddie always conneect to Tyl canada
Hello guys
I have problem with Edie , it is not switching  servers  or country , always it connects to Canada.
I downloaded last version and installed it.
any Idea.
thanks
Edited ... by streamview
A good way to encourage people to answer you is to provide more info of your own volition: The system report, for example, what you tried in the meantime and what it led to, etc.
Of course, the route via professional support is always a valid choice. For the sake of the forums's readers, though, if you do happen to solve it this way, make sure to follow up on it and provide a solution here. In the long run it also helps support minimize tickets. Thank you!
Hello .
after contacting support , problem Solved.
to fix the issue :
1) Make sure that Eddie is not running
2) Delete Eddie's configuration file (don't worry, Eddie will create a new one at the next run):
C:\Users\"your user name"\AppData\Local\Eddie\default.profile
3) Re-start Eddie. You will need to re-enter your credentials and re-configure the country you want !
Thank you for following up! It's kind of a rarity, so that makes it more awesome. :)
