When trying to access the Norwegian public broadcaster (nrk) nrk1: https://tv.nrk.no/direkte/nrk1.    The following message appears on screen:
Quote
"Det virker som om du benytter deg av en VPN-tjeneste. Skru av denne tjenesten og prøv igjen.  For mer informasjon, gå til info.nrk.no."
Translation:  "It appears as if you are using a VPN service.  Turn off this service and try again.  For more information, go to info.nrk.no"
I have tried accessing Norwegian servers and servers outside of Norway, with the same result.
Is it possible to have a routing server/update in Norway for these issues?
I note that NRK is listed here, but that is almost 10 years old:    Edited ... by squawkbox
Added further information
