X Generation
Info eMule with AirVPN and WireGuard High ID
hello what??
I'm quite new here and have been dealing with this AirVPN for the last few days.
- Port forwarding does not seem to work properly here? Or am I too stupid?
- tcp works without any problems, only udp doesn't want to do it at all, it seems to me, I've solved it differently now
what you need:
- 2 forwarded ports https://airvpn.org/ports/
- eMule.50a.MorphXT.12.7 oder eMule.50a.UltiMatiX_v5.0_31.08.2016_by_engo3k
- edit: eMule ... what you want ... ( Your VPN IPv4 )
then enter the generated ports in eMule -> connection tcp and udp
- Turn off UPnP under Connection
- under Options/Advanced - Server and client LAN IPs filter check box
- under Options/Advanced - assign internet connection 0.0.0.0 <- change
- Windows .. Enter "cmd" in the search bar of the desktop and open the command prompt with "Right-click -> Run as administrator" (alternatively, you can also call up a command line with the Windows key + R).
A DOS box opens in which you now type the command netstat -an. You will now see a list of all network connections on your computer.
look for a number starting with 10. ... and enter this in eMule - under Options/Advanced - assign internet connection 0.0.0.0 <- enter
- Close eMule to save the settings
- Establish an AirVPN connection of your choice
- PS: When you change the AirVPN server, the 10th ... IP also changes
consequently CMD - netstat -an 10 .. read IP and enter again in eMule ;)
I hope it helps you one or the other
let's rock the ed2k
X Generation
edit: Unbenannt.png
not you Exit IP -> Your VPN IPv4 !!!
Edited ... by X Generation
