tad1
Win 10 Eddie not connecting
Connection has become very sporadic on my Windows 10 PC. Eddie 2.21.8
I have tried blocking IPv6 but that doesn't help.
Any help appreciated.
. 2022.11.10 12:02:47 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.19045.0, Mono/.Net: v4.0.30319
. 2022.11.10 12:02:47 - Command line arguments (1): path="home"
. 2022.11.10 12:02:50 - Reading options from C:\Users\John\AppData\Local\Eddie\default.profile
. 2022.11.10 12:02:52 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2022.11.10 12:02:52 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2022.11.10 12:02:52 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2022.11.10 12:02:53 - Ready
. 2022.11.10 12:02:53 - Collect information about AirVPN completed
I 2022.11.10 12:03:12 - Session starting.
I 2022.11.10 12:03:13 - Checking authorization ...
. 2022.11.10 12:03:15 - Added new network interface "Eddie", Wintun version 0.12
. 2022.11.10 12:03:15 - Using WinTun network interface "Eddie (Eddie Tunnel)"
. 2022.11.10 12:03:15 - IPv6 disabled with packet filtering.
! 2022.11.10 12:03:15 - Connecting to Denebola (United Kingdom of Great Britain and Northern Ireland, London)
. 2022.11.10 12:03:16 - Routes, add 146.70.61.141/32 for interface "Ethernet (Intel(R) Ethernet Connection I217-LM)".
. 2022.11.10 12:03:17 - Routes, add 146.70.61.141/32 for interface "Ethernet (Intel(R) Ethernet Connection I217-LM)", already exists.
. 2022.11.10 12:03:17 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2022.11.10 12:03:17 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.11.10 12:03:17 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2022.11.10 12:03:17 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.11.10 12:03:17 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.11.10 12:03:17 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.11.10 12:03:17 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.11.10 12:03:17 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]146.70.61.141:443
. 2022.11.10 12:03:17 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.11.10 12:03:17 - OpenVPN > UDP link local: (not bound)
. 2022.11.10 12:03:17 - OpenVPN > UDP link remote: [AF_INET]146.70.61.141:443
. 2022.11.10 12:03:17 - OpenVPN > TLS: Initial packet from [AF_INET]146.70.61.141:443, sid=bc3dbe03 64433b03
. 2022.11.10 12:03:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.11.10 12:03:17 - OpenVPN > VERIFY KU OK
. 2022.11.10 12:03:17 - OpenVPN > Validating certificate extended key usage
. 2022.11.10 12:03:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.11.10 12:03:17 - OpenVPN > VERIFY EKU OK
. 2022.11.10 12:03:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Denebola, emailAddress=info@airvpn.org
. 2022.11.10 12:03:17 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2022.11.10 12:03:17 - OpenVPN > [Denebola] Peer Connection Initiated with [AF_INET]146.70.61.141:443
. 2022.11.10 12:03:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.15.122.1,dhcp-option DNS6 fde6:7a:7d20:b7a::1,tun-ipv6,route-gateway 10.15.122.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:b7a::108b/64 fde6:7a:7d20:b7a::1,ifconfig 10.15.122.141 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2022.11.10 12:03:17 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.11.10 12:03:17 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.15.122.1'
. 2022.11.10 12:03:17 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:b7a::1'
. 2022.11.10 12:03:17 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2022.11.10 12:03:17 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:b7a::108b/64 fde6:7a:7d20:b7a::1'
. 2022.11.10 12:03:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.11.10 12:03:17 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.11.10 12:03:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.11.10 12:03:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.11.10 12:03:17 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.11.10 12:03:17 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.11.10 12:03:17 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.11.10 12:03:17 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.11.10 12:03:17 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.11.10 12:03:17 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.11.10 12:03:17 - OpenVPN > interactive service msg_channel=0
. 2022.11.10 12:03:17 - OpenVPN > open_tun
. 2022.11.10 12:03:17 - OpenVPN > wintun device [Eddie] opened
. 2022.11.10 12:03:18 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 51 static 10.15.122.141 255.255.255.0
. 2022.11.10 12:03:18 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 51 all
. 2022.11.10 12:03:18 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 51 all
. 2022.11.10 12:03:18 - OpenVPN > IPv4 MTU set to 1500 on interface 51 using SetIpInterfaceEntry()
. 2022.11.10 12:03:18 - OpenVPN > Initialization Sequence Completed
. 2022.11.10 12:03:18 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2022.11.10 12:03:18 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2022.11.10 12:03:19 - DNS leak protection with packet filtering enabled.
. 2022.11.10 12:03:19 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.15.122.1)
. 2022.11.10 12:03:19 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.15.122.1)
. 2022.11.10 12:03:20 - DNS IPv4 of a network adapter forced (VirtualBox Host-Only Network, from automatic to 10.15.122.1)
. 2022.11.10 12:03:20 - DNS IPv4 of a network adapter forced (VMware Network Adapter VMnet1, from automatic to 10.15.122.1)
. 2022.11.10 12:03:20 - DNS IPv4 of a network adapter forced (VMware Network Adapter VMnet8, from automatic to 10.15.122.1)
. 2022.11.10 12:03:21 - Routes, add 0.0.0.0/1 for interface "Eddie (Eddie Tunnel)".
. 2022.11.10 12:03:22 - Routes, add 128.0.0.0/1 for interface "Eddie (Eddie Tunnel)".
. 2022.11.10 12:03:23 - Routes, add 146.70.61.139/32 for interface "Eddie (Eddie Tunnel)".
. 2022.11.10 12:03:23 - Routes, skipped for 2001:ac8:31:22d:3cd3:c0e2:a717:bef4 : IPv6 blocked.
. 2022.11.10 12:03:23 - Flushing DNS
I 2022.11.10 12:03:23 - Checking route IPv4
. 2022.11.10 12:03:31 - Checking route (4° try)
. 2022.11.10 12:03:35 - Checking route (5° try)
E 2022.11.10 12:03:35 - Checking route IPv4 failed, last reason: Fetch url error:SSL connect error
! 2022.11.10 12:03:35 - Disconnecting
. 2022.11.10 12:03:35 - Sending soft termination signal
. 2022.11.10 12:03:38 - OpenVPN > SIGTERM received, sending exit notification to peer
