"Ch"WK;{/LWPavmu 0 Posted ... I installed it and it was working just fine. My windows updated and after a restar the vpn stopped working. Please help me! . Quote 2022.10.21 21:52:49 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.22000.0, Mono/.Net: v4.0.30319 . 2022.10.21 21:52:49 - Command line arguments (1): path="home" . 2022.10.21 21:52:50 - Reading options from C:\Users\jack-\AppData\Local\Eddie\default.profile . 2022.10.21 21:52:51 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2022.10.21 21:52:51 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe) . 2022.10.21 21:52:51 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe) ! 2022.10.21 21:52:52 - Activation of Network Lock - Windows Filtering Platform I 2022.10.21 21:52:52 - Ready . 2022.10.21 21:52:53 - Collect information about AirVPN completed I 2022.10.21 21:52:53 - Session starting. . 2022.10.21 21:52:53 - Waiting for latency tests (2 to go) . 2022.10.21 21:52:53 - Collect information about AirVPN completed I 2022.10.21 21:52:56 - Checking authorization ... . 2022.10.21 21:52:57 - Added new network interface "Eddie", Wintun version 0.12 . 2022.10.21 21:52:57 - Using WinTun network interface "Eddie (Eddie Tunnel)" ! 2022.10.21 21:52:57 - Connecting to Aspidiske (Netherlands, Alblasserdam) . 2022.10.21 21:52:57 - Routes, add 134.19.179.197/32 for interface "Hamachi (LogMeIn Hamachi Virtual Ethernet Adapter)". . 2022.10.21 21:52:57 - Routes, add 134.19.179.197/32 for interface "Hamachi (LogMeIn Hamachi Virtual Ethernet Adapter)", already exists. . 2022.10.21 21:52:57 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2022.10.21 21:52:57 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2022.10.21 21:52:57 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2022.10.21 21:52:57 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2022.10.21 21:52:57 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2022.10.21 21:52:57 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2022.10.21 21:52:57 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2022.10.21 21:52:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.197:443 . 2022.10.21 21:52:57 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2022.10.21 21:52:57 - OpenVPN > UDP link local: (not bound) . 2022.10.21 21:52:57 - OpenVPN > UDP link remote: [AF_INET]134.19.179.197:443 . 2022.10.21 21:53:29 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2022.10.21 21:53:29 - OpenVPN > SIGTERM received, sending exit notification to peer . 2022.10.21 21:53:35 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2022.10.21 21:53:35 - Disconnecting . 2022.10.21 21:53:35 - Routes, delete 134.19.179.197/32 for interface "Hamachi (LogMeIn Hamachi Virtual Ethernet Adapter)". . 2022.10.21 21:53:35 - Routes, delete 134.19.179.197/32 for interface "Hamachi (LogMeIn Hamachi Virtual Ethernet Adapter)", not exists. . 2022.10.21 21:53:35 - Connection terminated. Quote Share this post Link to post
Tech Jedi Alex 1523 Posted ... In Eddie Preferences > Protocols, untick Automatic and try different ports and protocols, especially UDP/53 and TCP/443 might be interesting to check out. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
