Not connected, Your IP: 216.73.216.85
jpowers
Eddie connection problems
I haven't been able to connect to VPN for the past couple of days. I'm running version 2.2.1.8 for Windows 10 64bit.
Eddie cannot make a connection and times out, cyclying through servers with the same results. Logs included here:
https://eddie.website/report/80f2a079/
Please let me know how I can get back online.
Thank you.
Looks to me as if UDP/443 is blocked. DId you try other ports and protocols? In Eddie Preferences > Protocols, untick Automatic, then choose different options below that. Try UDP/53, then maybe TCP/443, those are the least likely to be blocked.
