Not connected, Your IP: 216.73.216.169
hvest
TOR>>VPN Connection not Stable
Hi there i tried to connect tor TOR +VPN
Downloaded a Config for openvpn tor is running properly
When i connect to the Vpn all seems good,but when i ping any site or run any program who connect to internet my connection are down heres a log message from Oopevpn
sudo openvpn air.ovpn
Mon Nov  5 10:45:03 2012 OpenVPN 2.2.0 i686-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Jul  4 2011
Mon Nov  5 10:45:03 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Nov  5 10:45:03 2012 LZO compression initialized
Mon Nov  5 10:45:03 2012 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
Mon Nov  5 10:45:03 2012 Socket Buffers: R=[87380->131072] S=[16384->131072]
Mon Nov  5 10:45:03 2012 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
Mon Nov  5 10:45:03 2012 Local Options hash (VER=V4): '958c5492'
Mon Nov  5 10:45:03 2012 Expected Remote Options hash (VER=V4): '79ef4284'
Mon Nov  5 10:45:03 2012 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 [nonblock]
Mon Nov  5 10:45:03 2012 TCP connection established with [AF_INET]127.0.0.1:9050
Mon Nov  5 10:45:04 2012 TCPv4_CLIENT link local: [undef]
Mon Nov  5 10:45:04 2012 TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9050
Mon Nov  5 10:45:04 2012 TLS: Initial packet from [AF_INET]127.0.0.1:9050, sid=610af5b3 be4158ca
Mon Nov  5 10:45:09 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
Mon Nov  5 10:45:09 2012 VERIFY OK: nsCertType=SERVER
Mon Nov  5 10:45:09 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
Mon Nov  5 10:45:19 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Nov  5 10:45:19 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Nov  5 10:45:19 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Nov  5 10:45:19 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Nov  5 10:45:19 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Mon Nov  5 10:45:19 2012 [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9050
Mon Nov  5 10:45:21 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Mon Nov  5 10:45:22 2012 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.3.58 10.5.3.57'
Mon Nov  5 10:45:22 2012 OPTIONS IMPORT: timers and/or timeouts modified
Mon Nov  5 10:45:22 2012 OPTIONS IMPORT: LZO parms modified
Mon Nov  5 10:45:22 2012 OPTIONS IMPORT: --ifconfig/up options modified
Mon Nov  5 10:45:22 2012 OPTIONS IMPORT: route options modified
Mon Nov  5 10:45:22 2012 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mon Nov  5 10:45:22 2012 ROUTE default_gateway=192.168.0.254
Mon Nov  5 10:45:22 2012 TUN/TAP device tun0 opened
Mon Nov  5 10:45:22 2012 TUN/TAP TX queue length set to 100
Mon Nov  5 10:45:22 2012 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Nov  5 10:45:22 2012 /sbin/ifconfig tun0 10.5.3.58 pointopoint 10.5.3.57 mtu 1500
Mon Nov  5 10:45:22 2012 /sbin/route add -net 127.0.0.1 netmask 255.255.255.255 gw 192.168.0.254
Mon Nov  5 10:45:22 2012 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.5.3.57
Mon Nov  5 10:45:22 2012 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.5.3.57
Mon Nov  5 10:45:22 2012 /sbin/route add -net 10.5.0.1 netmask 255.255.255.255 gw 10.5.3.57
Mon Nov  5 10:45:22 2012 Initialization Sequence Completed
[/quote]
and when i ping any sites connection breaks down
[code]Mon Nov  5 10:46:22 2012 [server] Inactivity timeout (--ping-restart), restarting
Mon Nov  5 10:46:22 2012 TCP/UDP: Closing socket
Mon Nov  5 10:46:22 2012 /sbin/route del -net 10.5.0.1 netmask 255.255.255.255
Mon Nov  5 10:46:22 2012 /sbin/route del -net 127.0.0.1 netmask 255.255.255.255
Mon Nov  5 10:46:22 2012 /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
Mon Nov  5 10:46:22 2012 /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
Mon Nov  5 10:46:22 2012 Closing TUN/TAP interface
Mon Nov  5 10:46:22 2012 /sbin/ifconfig tun0 0.0.0.0
Mon Nov  5 10:46:22 2012 SIGUSR1[soft,ping-restart] received, process restarting
Mon Nov  5 10:46:22 2012 Restart pause, 5 second(s)
Mon Nov  5 10:46:27 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Nov  5 10:46:27 2012 LZO compression initialized
Mon Nov  5 10:46:27 2012 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
Mon Nov  5 10:46:27 2012 Socket Buffers: R=[87380->131072] S=[16384->131072]
Mon Nov  5 10:46:27 2012 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
Mon Nov  5 10:46:27 2012 Local Options hash (VER=V4): '958c5492'
Mon Nov  5 10:46:27 2012 Expected Remote Options hash (VER=V4): '79ef4284'
Mon Nov  5 10:46:27 2012 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 [nonblock]
Mon Nov  5 10:46:27 2012 TCP connection established with [AF_INET]127.0.0.1:9050
Mon Nov  5 10:46:32 2012 recv_socks_reply: TCP port read timeout expired: Operation now in progress (errno=115)
Mon Nov  5 10:46:32 2012 TCP/UDP: Closing socket
Mon Nov  5 10:46:32 2012 SIGTERM[soft,init_instance] received, process exiting
Hi There I have problem with connect TOR+VPN all seems good but when i ping some sites my connection are down heres the log form openvpn
Mon Nov  5 10:43:24 2012 OpenVPN 2.2.0 i686-linux-gnu [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Jul  4 2011
Mon Nov  5 10:43:24 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Nov  5 10:43:24 2012 LZO compression initialized
Mon Nov  5 10:43:24 2012 Control Channel MTU parms [ L:1560 D:140 EF:40 EB:0 ET:0 EL:0 ]
Mon Nov  5 10:43:24 2012 Socket Buffers: R=[87380->131072] S=[16384->131072]
Mon Nov  5 10:43:24 2012 Data Channel MTU parms [ L:1560 D:1450 EF:60 EB:135 ET:0 EL:0 AF:3/1 ]
Mon Nov  5 10:43:24 2012 Local Options hash (VER=V4): '958c5492'
Mon Nov  5 10:43:24 2012 Expected Remote Options hash (VER=V4): '79ef4284'
Mon Nov  5 10:43:24 2012 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 [nonblock]
Mon Nov  5 10:43:24 2012 TCP connection established with [AF_INET]127.0.0.1:9050
Mon Nov  5 10:43:24 2012 TCPv4_CLIENT link local: [undef]
Mon Nov  5 10:43:24 2012 TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9050
Mon Nov  5 10:43:24 2012 TLS: Initial packet from [AF_INET]127.0.0.1:9050, sid=4659c5d9 fd2074b3
Mon Nov  5 10:43:28 2012 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
Mon Nov  5 10:43:28 2012 VERIFY OK: nsCertType=SERVER
Mon Nov  5 10:43:28 2012 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
Mon Nov  5 10:43:38 2012 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Nov  5 10:43:38 2012 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Nov  5 10:43:38 2012 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mon Nov  5 10:43:38 2012 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Nov  5 10:43:38 2012 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Mon Nov  5 10:43:38 2012 [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9050
Mon Nov  5 10:43:40 2012 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Mon Nov  5 10:43:41 2012 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.3.58 10.5.3.57'
Mon Nov  5 10:43:41 2012 OPTIONS IMPORT: timers and/or timeouts modified
Mon Nov  5 10:43:41 2012 OPTIONS IMPORT: LZO parms modified
Mon Nov  5 10:43:41 2012 OPTIONS IMPORT: --ifconfig/up options modified
Mon Nov  5 10:43:41 2012 OPTIONS IMPORT: route options modified
Mon Nov  5 10:43:41 2012 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mon Nov  5 10:43:41 2012 ROUTE default_gateway=192.168.0.254
Mon Nov  5 10:43:41 2012 TUN/TAP device tun0 opened
Mon Nov  5 10:43:41 2012 TUN/TAP TX queue length set to 100
Mon Nov  5 10:43:41 2012 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mon Nov  5 10:43:41 2012 /sbin/ifconfig tun0 10.5.3.58 pointopoint 10.5.3.57 mtu 1500
Mon Nov  5 10:43:41 2012 /sbin/route add -net 127.0.0.1 netmask 255.255.255.255 gw 192.168.0.254
Mon Nov  5 10:43:41 2012 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.5.3.57
Mon Nov  5 10:43:41 2012 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.5.3.57
Mon Nov  5 10:43:41 2012 /sbin/route add -net 10.5.0.1 netmask 255.255.255.255 gw 10.5.3.57
Mon Nov  5 10:43:41 2012 Initialization Sequence Completed
As you can see all seems good but when i ping any site connection breaks down
Any idea how to fix that
