I have some trouble tonight, I can't connect to the VNP since it freezes on "checking route IPV4". Impossible to cancel also.
I'm on windows 10 64 bits.
I have the sae trouble on 2.21.6 version.
I recently change my internet source, I had a home connection before, and now I'm connected by my phone.
Thank you very much for your help.
. 2022.09.05 21:11:34 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.19043.0, Mono/.Net: v4.0.30319
. 2022.09.05 21:11:34 - Command line arguments (1): path="home"
. 2022.09.05 21:11:40 - Reading options from C:\Users\benoi\AppData\Local\Eddie\default.profile
. 2022.09.05 21:11:43 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2022.09.05 21:11:43 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2022.09.05 21:11:43 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
. 2022.09.05 21:11:44 - Recovery. Unexpected crash?
. 2022.09.05 21:11:44 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2022.09.05 21:11:44 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2022.09.05 21:11:44 - DNS IPv4 of a network adapter restored to original settings (VirtualBox Host-Only Network, to automatic)
. 2022.09.05 21:11:45 - DNS IPv6 of a network adapter restored to original settings (VirtualBox Host-Only Network, to automatic)
I 2022.09.05 21:11:46 - Ready
. 2022.09.05 21:11:47 - Collect information about AirVPN completed
I 2022.09.05 21:15:21 - Session starting.
I 2022.09.05 21:15:22 - Checking authorization ...
. 2022.09.05 21:15:24 - Added new network interface "Eddie", Wintun version 0.12
. 2022.09.05 21:15:24 - Using WinTun network interface "Eddie (Eddie Tunnel)"
! 2022.09.05 21:15:24 - Connecting to Luhman (Netherlands, Alblasserdam)
. 2022.09.05 21:15:25 - Routes, add 213.152.186.170/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)".
. 2022.09.05 21:15:25 - Routes, add 213.152.186.170/32 for interface "Wi-Fi (Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC)", already exists.
. 2022.09.05 21:15:25 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2022.09.05 21:15:25 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.09.05 21:15:25 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2022.09.05 21:15:25 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.09.05 21:15:25 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.09.05 21:15:25 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.09.05 21:15:25 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.09.05 21:15:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.186.170:443
. 2022.09.05 21:15:25 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.09.05 21:15:25 - OpenVPN > UDP link local: (not bound)
. 2022.09.05 21:15:25 - OpenVPN > UDP link remote: [AF_INET]213.152.186.170:443
. 2022.09.05 21:15:25 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.186.170:443, sid=c014b3f3 6a8a5a35
. 2022.09.05 21:15:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.09.05 21:15:26 - OpenVPN > VERIFY KU OK
. 2022.09.05 21:15:26 - OpenVPN > Validating certificate extended key usage
. 2022.09.05 21:15:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.09.05 21:15:26 - OpenVPN > VERIFY EKU OK
. 2022.09.05 21:15:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Luhman, emailAddress=info@airvpn.org
. 2022.09.05 21:15:26 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2022.09.05 21:15:26 - OpenVPN > [Luhman] Peer Connection Initiated with [AF_INET]213.152.186.170:443
. 2022.09.05 21:15:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.34.194.1,dhcp-option DNS6 fde6:7a:7d20:1ec2::1,tun-ipv6,route-gateway 10.34.194.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1ec2::1033/64 fde6:7a:7d20:1ec2::1,ifconfig 10.34.194.53 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2022.09.05 21:15:26 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.09.05 21:15:26 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.34.194.1'
. 2022.09.05 21:15:26 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1ec2::1'
. 2022.09.05 21:15:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.09.05 21:15:26 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.09.05 21:15:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.09.05 21:15:26 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.09.05 21:15:26 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.09.05 21:15:26 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.09.05 21:15:26 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.09.05 21:15:26 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.09.05 21:15:26 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.09.05 21:15:26 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.09.05 21:15:26 - OpenVPN > interactive service msg_channel=0
. 2022.09.05 21:15:26 - OpenVPN > open_tun
. 2022.09.05 21:15:26 - OpenVPN > wintun device [Eddie] opened
. 2022.09.05 21:15:26 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 11 static 10.34.194.53 255.255.255.0
. 2022.09.05 21:15:27 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 11 all
. 2022.09.05 21:15:27 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 11 all
. 2022.09.05 21:15:27 - OpenVPN > IPv4 MTU set to 1500 on interface 11 using SetIpInterfaceEntry()
. 2022.09.05 21:15:27 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 11 fde6:7a:7d20:1ec2::1033/128 store=active
. 2022.09.05 21:15:27 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1ec2::/64 -> fde6:7a:7d20:1ec2::1033 metric 0) dev Eddie
. 2022.09.05 21:15:27 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1ec2::/64 11 fe80::8 store=active
. 2022.09.05 21:15:27 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.09.05 21:15:27 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 11 all
. 2022.09.05 21:15:27 - OpenVPN > IPv6 MTU set to 1500 on interface 11 using SetIpInterfaceEntry()
. 2022.09.05 21:15:27 - OpenVPN > Initialization Sequence Completed
. 2022.09.05 21:15:27 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2022.09.05 21:15:27 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2022.09.05 21:15:27 - DNS leak protection with packet filtering enabled.
. 2022.09.05 21:15:28 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.34.194.1)
. 2022.09.05 21:15:28 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:1ec2::1)
. 2022.09.05 21:15:28 - DNS IPv4 of a network adapter forced (VirtualBox Host-Only Network, from automatic to 10.34.194.1)
. 2022.09.05 21:15:28 - DNS IPv6 of a network adapter forced (VirtualBox Host-Only Network, from automatic to fde6:7a:7d20:1ec2::1)
. 2022.09.05 21:15:29 - Routes, add 0.0.0.0/1 for interface "Eddie (Eddie Tunnel)".
. 2022.09.05 21:15:30 - Routes, add 128.0.0.0/1 for interface "Eddie (Eddie Tunnel)".
. 2022.09.05 21:15:30 - Routes, add 213.152.186.168/32 for interface "Eddie (Eddie Tunnel)".
. 2022.09.05 21:15:31 - Routes, add 2a00:1678:1337:2429:4c19:55f8:dbef:d67e/128 for interface "Eddie (Eddie Tunnel)".
. 2022.09.05 21:15:31 - Flushing DNS
I 2022.09.05 21:15:31 - Checking route IPv4
Edited ... by canada00
